Old 05-16-2008, 03:17 PM   #26
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: my radical 60 build
Sick!
I want to see the expression on ladies face when you go to have it registered!
"It's a what?"
Joey~AP is offline   Reply With Quote
Old 05-16-2008, 03:58 PM   #27
Joey~AP
TexasBowhunter
Joey~AP's Avatar
If you could work the back fender wells into a fleet bed.....it would be slick!
Old 05-16-2008, 04:35 PM   #28
Hoser's Girl
Chevy Chica
Hoser's Girl's Avatar
WOW! That's some heavy work!
~La 'Mona' Lisa
Hoser's Girl is offline   Reply With Quote
Old 05-16-2008, 05:09 PM   #29
283 Man
283 Man's Avatar
Thumbs up Re: my radical 60 build
different is good your project rocks!!
283 Man is offline   Reply With Quote
Old 05-17-2008, 02:49 AM   #30
dallas77
64' Chevy C10
dallas77's Avatar
Sick ride cant wait to see some more pics
dallas77 is offline   Reply With Quote
Old 05-24-2008, 06:14 AM   #31
bigblock79
67 Chevy Stepside
bigblock79's Avatar
you got any more pic of pink freak
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 05-24-2008, 08:49 AM   #32
muddpile
muddpile's Avatar
I'm liking this build thread, but of course, I'm into cutting these trucks up and making them into monsters.
muddpile is offline   Reply With Quote
Old 05-24-2008, 02:14 PM   #33
scotts62
One day...
scotts62's Avatar
Ya thats freaking awsome!!
Can't wait to see it done!!
Scott
93 crew cab build
Project 62
Old 05-25-2008, 05:38 PM   #34
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Holy cow!!!!m Theres some work involved here...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-25-2008, 05:47 PM   #35
62 C60
62 C60's Avatar
WOW... thats all I can say.
Subscribed!!
-Jake
1962 C60 261 I6 5+2spd I like to be different
Interior- Puke green dash, brown vinyl seat from an 87.
Exterior- Rust
1993 Full Size Blazer 4x4 Stock for now.
If you have a truck everyone is your friend. When they need to move.
62 C60 is offline   Reply With Quote
Old 05-29-2008, 04:44 PM   #36
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Here is the doner car:
it is an 84 pontiac wagon, It is a canadian version, so it has a chevy motor and sheet metal , with pontiac badges.
I put the wheels on and got the ride hiegth, which is 6 inches on the front of the frame rail and 7 at the rear.
you can't tell, but it is all unbolted and almost ready for the camper jacks!
check out that snakepit of emissions junk!
Hiding under there is a relitively new goodwrench 350 with a 2004r !
Old 05-29-2008, 05:35 PM   #37
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Hurry!
Old 06-18-2008, 03:39 PM   #38
jonzcustomshop
1961 crewcab
Some progress:
I got the wagon body off, and stripped all the stuff I needed, the body weighed almost 2000 pounds!
I put the front clip on the frame, the inner fenders contour to the frame rails like they were made for each other, and the front bumper brackets are in the right place too.
The frame was 6 inches off the ground with the wagon body on it, now it has raised up to 11 inches.
I was hoping to chanel the body a little bit,and not do any major lowering, but I don't think the truck will push the frame down as far as the wagon did, so I will probably have to cut a few coils , and Z the frame in the front.
There is about 5 inches between thee hood and air cleaner now, so I have some room to work with.
Old 06-18-2008, 03:50 PM   #39
jonzcustomshop
1961 crewcab
I have just as much time in the doors as the cab, however he 2nd door is going alot faster than the first. I had a little rust repair to do on the bottom of the right door, and you can see the new nuts I welded on for the door panel.
Instead of cutting and welding through the skin on the door bottom, I just trimmed off the excess, and folded it over- alot less body work that way!
I set it up so that my cut on the inside was under the door panel - more body work avoided!
Old 06-18-2008, 04:04 PM   #40
jonzcustomshop
1961 crewcab
I am finally getting the cab welded up.
I have one footwell left to go, and for some reason I have been trying to save the data tag. I should probably just pull it and hang it on the wall before it gets messed up.
some how I screwed up the measurement across the back of the cab, so I had to cut a filler piece off the scrap I had cut out; this is why it is good to hang on to all your scraps until the project is done.
I had to make a couple relief cuts on the corners to get them lined up.
I also had to do a little extra work on the driver rear corner, because I dropped it when I was putting it up on jackstands!
You can also see a little more of the finished (90%) door.
Old 06-18-2008, 05:23 PM   #41
nhtc33d
The thread title really fits! I can't imagine how you even figured out where to start a project like that! Have you done anything like this before? I cant wait to see more pictures of this project. It's looking great!!
nhtc33d is offline   Reply With Quote
Old 06-18-2008, 05:32 PM   #42
scotts62
One day...
scotts62's Avatar
Sweet dude! That thing is looking good! Keep the pics rolling in
Scott
93 crew cab build
Project 62
Old 06-22-2008, 09:00 AM   #43
jonzcustomshop
1961 crewcab
I am setting up the new cab mounts now, I ended up just C notching all four cab support braces, that dropped the cab down enough that the rockers hang below the frame rails , which is what I wanted.
The hood just clears the aircleaner,so I won't be Zing the frame, the rocker is still 9 inches off the ground, so there are some cut coils in my future...
After a ton of measuring, and cutting an extra 3 inches out of the front fenders, and moving the cab forward, I am almost (1 inch short) to the dimensions and wheelbase of a short fleet.
Old 06-22-2008, 09:06 AM   #44
jonzcustomshop
1961 crewcab
nhtc33d, I was inspired by the pink freak ,and I have sectioned and chopped my 60 elcamino, but that build keeps getting interrupted by other projects, the 26 T, this, and my 65 dd..... it is next though, after this one is roadworthy.
Old 06-22-2008, 10:12 AM   #45
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Great progress man....Awesome frick'n build bro.
You planning just a static drop on the suspension ?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-22-2008, 12:12 PM   #46
Frizzle Fry
Frizzle Fry's Avatar
Ya man! Looking real good. Nice work! Can't wait to see more.
Frizzle Fry is offline   Reply With Quote
Old 06-22-2008, 12:26 PM   #47
Rogue 64
Ol' Blue Viking
Lets see a pic of the 26T.
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 06-22-2008, 02:45 PM   #48
jonzcustomshop
1961 crewcab
chief, I am planning to do the static for now, until I get some $$$$ for an air system.
rouge.. there are some shots of the T in this post
http://67-72chevytrucks.com/vboard/s...d.php?t=284229
Old 06-22-2008, 03:18 PM   #49
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
OOOOOOOOO some got a chassis, looking good Jon. I need to get up there to see you man. Check with your buds for some decent front fenders for me. See you soon.
kdrodworks316 is offline   Reply With Quote
Old 06-24-2008, 11:50 PM   #50
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
You have an awesome vision for a great project. I'll let you know the next time I'm up your way. I'd like to see this in person if you don't mind.
Alan's Classic is offline   Reply With Quote
