Old 09-11-2008, 05:02 PM   #26
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: My 57 Pro Street
Wow, nice work Kim.
Do you do all the breaks and bends on the sheet metal?
Looks like you really know how to fabricate.
What type of wheel tubs are you going to use? Are you going to make your own or buy off the shelf tubs?
We just about have the same size rear wheels.
Tri5Nerd is offline   Reply With Quote
Old 09-11-2008, 05:40 PM   #27
OrrieG
OrrieG's Avatar
Very nice work, did you roll the roll pan section your self? On a break? Got me thinking about making mine for my 59 instead of buying one.
I love this site, so much detail on the builds gives us confidence to jump in ourselves.
OrrieG is offline   Reply With Quote
Old 09-11-2008, 08:40 PM   #28
Kim57
Kim57's Avatar
Tri5Nerd and OrrieG
I had the shop where I buy my steel from make the bends in the metal.
I drew up some plans with all the dimensions and had them cut and bend it then I welded everything together.
They bent the 1" tube and then did the sheet for the roll pan also. They weren't able to get the pan as tight as the tubes so I had to finish it at home, thats why you see the straps holding it all together.
I saved a ton of money doing it this way. The bed only has $200 in steel including the bends and the roll pan and 2 front corners was only another $80.
Kim
Kim57 is offline   Reply With Quote
Old 09-19-2008, 11:15 AM   #29
Kabwe
Certified Car Nut
Kabwe's Avatar
Really nice work kim57.
Kabwe is offline   Reply With Quote
Old 09-19-2008, 01:48 PM   #30
mountainkowboy
mountainkowboy's Avatar
Sweet ride, ours is gunna go a little more resto-mod and were gunna see if we can drive more than our bucket (the bucket has no street manners AT-ALL).
mountainkowboy is offline   Reply With Quote
Old 12-15-2008, 02:23 PM   #31
Kim57
Kim57's Avatar
Heres an up-date on what I've been doing to the truck.
Had some time to work on the core support.
The 1st pic is the material I'm using. 2x4 rectangular stock and 1-1/4 round tube.
Pic #2 it is set up to be welded together.
Pic #3 shows how I had to cut it to fit the frame.
Pic #4 shows how I cut my frame horns to begin.
Pic #5 shows it welded to the frame.
Old 12-15-2008, 02:28 PM   #32
Kim57
Kim57's Avatar
Hers some more pics of the core support. I didn't just want it square at the transition so this is what I came up with.
The first pic is some cardboard templates I made to dress up the front of the frame.
Pic #2 is some 1/8 inch plate I cut out.
Pic#3 and #4 shows it welded to the frame.
I still have to clean up my welds some.
Old 12-15-2008, 05:20 PM   #33
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
wow!
What an inspiration!
Keep up the great work. I'm a year behind you but it's coming!
Kenny
87Lowrider is offline   Reply With Quote
Old 12-15-2008, 05:35 PM   #34
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good, keep up the good work!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-17-2008, 04:02 PM   #35
Kim57
Kim57's Avatar
Thanks for the encouragement guys.
Kim
Old 12-17-2008, 04:32 PM   #36
Kabwe
Certified Car Nut
Kabwe's Avatar
See now that's thinking, nice work man
Old 12-17-2008, 06:38 PM   #37
JayG
Formerly ADHDCARGUY
JayG's Avatar
Really good thinking, planning and execution. Fired me up to get after my '54 burb.
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 12-20-2008, 08:23 PM   #38
northern 85
northern 85's Avatar
NICE!!!! Love the fab work
northern 85 is offline   Reply With Quote
Old 12-21-2008, 10:20 PM   #39
50adrod
50adrod's Avatar
impressive metal working skills, looking good
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-21-2008, 11:30 PM   #40
LuckyHenriksen
LuckyHenriksen's Avatar
I really like the way the bed looks
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-21-2008, 11:47 PM   #41
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-22-2008, 12:58 AM   #42
Kim57
Kim57's Avatar
Thanks again guys for the kind words and encouragement.
Kim
Old 02-27-2009, 01:49 AM   #43
Kim57
Kim57's Avatar
Been working on getting the tail lights installed.
The pics are pretty self explanatory.
Also ordered a brake pedal assembly from Pirate Jacks and I have to say the were really nice to work with.
Ordered my lower tubular front control arms also and will post pics when they arrive.
Kim
Old 02-27-2009, 01:52 AM   #44
Kim57
Kim57's Avatar
Here's a few more pics of the tail lights being installed. I still have trouble welding so its good that I can grind and redo them.
Kim
Old 02-27-2009, 01:58 AM   #45
Kim57
Kim57's Avatar
Started working on frenching my license plate also. I had some 16 gauge bent and then welded it up. I had made deeper than it will end up being. I just wanted a little extra to play with the depth on the bed.
Kim
Old 02-27-2009, 02:02 AM   #46
Daniel U
Daniel U's Avatar
Progress is good!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 02-27-2009, 11:42 AM   #47
CAL 58 GMC
CAL 58 GMC's Avatar
Looking good!
CAL 58 GMC is offline   Reply With Quote
Old 02-27-2009, 12:17 PM   #48
hotrodsbyray
from post #44 - man, looking at your work, if that's "trouble welding" then I'm gonna just put my Lincoln welder in the front yard and plant pansys in it! Your work is awesome and shows me how I can salvage the front stubs of my subframe!
hotrodsbyray is offline   Reply With Quote
Old 02-27-2009, 12:47 PM   #49
Kabwe
Certified Car Nut
Kabwe's Avatar
Hey Kim,
Looks like you've been busy. The bed looks great. I like, I really like. Great work man
Old 02-27-2009, 01:00 PM   #50
Kim57
Kim57's Avatar
Thanks for the compliments guys. I really appreciate the kind words.
hotrodsbyray, I still have trouble with the thinner sheet metal but I just keep trying and eventually get something I can live with. Burn through is what really frustrates meat at times. It seems there is a very fine line between not enough power and to much.If I can do it anybody can.
Kim
