Old 08-21-2008, 05:50 PM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Senior Project Build
Here is my attempt at a build thread. The truck is a 1968 Chevy LWB, and I am rebuilding the suspension, motor, switching transmissions, and adding disc brakes. This is my Senior Project for high school.
Here are some pics of when I first brought it home. The blue one is my '62 that I wrecked, being parted out.
Truck came with a crusty 350 and the original 3 speed on the column. The linkage was mostly broken so I had an interesting time getting it from Battle Ground WA. to my house in Oregon. The motor leaked oil like a champ, so I tore it down hoping it was the front main seal.
I fixed that and it still leaked like a seive. I found a fairly straight tailgate on craigslist for cheap and brought it home and rattlecan primered it.
Next step was to remove the lame rear bumper and stickers from the back window.
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 08-21-2008, 06:18 PM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Senior Project Build
Nice looking truck!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-21-2008, 06:23 PM   #3
LuckyHenriksen
The manifold was in bad shape too
And heres a couple pics of the poor '62
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 06:24 PM   #4
LuckyHenriksen
Originally Posted by Riveted1 View Post
Nice looking truck!
Thanks!
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 06:50 PM   #5
LuckyHenriksen
Now it was time to remove all the old stuff and clean it up.
There goes the rusty, oil soaked exhaust.
Then comes the motor and trans.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 07:32 PM   #6
LuckyHenriksen
I tore the motor down to a short block, and replaced all the seals and gaskets, added a new oil pan, timing chain cover, water pump, fuel pump, starter, and a new Edelbrock performer intake and 650 CFM carb. I also repainted it, those are just iron heads that I painted with aluminum paint.
Then I started the suspension tear-down
I am switching from 6 lug to 5 lug, so I have new axles to install in the rear and a set of 2.5in drop disc brake spindles to install up front. At the same time I will be installing 4'' drop coil springs to bring the rear down and 3'' drop coils up front. Combined with the spindles I should have a 5.5 /4 drop.
This is one of the new 5 lug axles
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 07:35 PM   #7
rcrahn
rcrahn's Avatar
Tell me you were not in that '62 when it was T -Boned? If you were you are one lucky kid!
rcrahn is offline   Reply With Quote
Old 08-21-2008, 07:41 PM   #8
LuckyHenriksen
Yes unfortunately I was. I DIDN'T have a seat belt on, so I was thrown against the opposite side. The doors jammed shut, but I was able to crawl out the window hoping the fire bomb gas tank behind the seat wouldn't ignite. I guess thats why my friends call me Lucky
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 10:27 PM   #9
LuckyHenriksen
I pulled off the upper and lower control arms, cleaned, painted them, and had new ball joints pressed in at NAPA.
Then I installed everything, including the new spindles, shocks, springs, and suspension components.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 10:31 PM   #10
LuckyHenriksen
Next came the new disc brakes. The calipers were gold, and it didn't look right, so I painted them red with high-temp paint.
Here are the new braided steel lines, compared to the old rubber ones.
And here is a test fit of a junky 5 lug rally wheel.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 10:41 PM   #11
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
looking good, keep up the good work
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 08-21-2008, 10:45 PM   #12
rcrahn
rcrahn's Avatar
Wow, I believe "lucky" is an excellent nickname for you now.
Nice work on your new ride now.
In the future buckle up.
Old 08-21-2008, 10:57 PM   #13
LuckyHenriksen
Thanks man
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-21-2008, 11:55 PM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Lookin good! Keep it up! How old are you? 18? Guessing because you are a Senior.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-22-2008, 12:10 AM   #15
LuckyHenriksen
I'm actually 17, my senior year started thursday
My school lets us get our senior projects approved at the end of your junior year, so you can have the summer to work on them. Kinda cool
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 12:39 AM   #16
68 short step
looks good
68 short step is offline   Reply With Quote
Old 08-22-2008, 01:09 AM   #17
LuckyHenriksen
Thanks for the comments guys
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 01:20 AM   #18
LuckyHenriksen
I found a set of stock wheels on CL for a good price, so I grabbed them and cleaned them up a bit. I needed new wheels because I switched to 5 lug. I had them sandblasted at this sweet old shop in town, then rattlecanned grey primer and "clearcoat" over them.
Then I mounted the tires that came on it so I could get it on the ground. They were way too big but at least it is a roller now.
So far plenty of ground clearance
This shows my freshly rebuilt TH400 with 2000 Stall converter, and the clean shiny engine ready to rock.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 01:31 AM   #19
LuckyHenriksen
Finally the day came to drop the motor and transmission in. For this job I enlisted the help of a friend.
My so called "help"
It is all nestled down in the engine bay, looks empty
Then I squeezed in the Hooker Comp. Headers
The weight of the drive train pushed the front down even more
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 02:11 AM   #20
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
nice lookin' truck man. what are you plans for the rear end?
IvelDesigns is offline   Reply With Quote
Old 08-22-2008, 02:13 AM   #21
LuckyHenriksen
Here are the latest pics. It now moves under its own power. I know a guy who works for Goodyear, and he got me a good deal on some new Eagles. They fit much better than the old tires. They are too skinny in the rear for my taste, but they were cheap. Had the driveshaft shortened and rebuilt. Most everything is hooked up and working. The stance is pretty aggressive, and I only have like 2 inches of clearance between the header collectors and the ground. Thats a bit of a problem. But other than that I'm happy about the way its turning out.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 02:15 AM   #22
LuckyHenriksen
I like rake, but this is a bit too much. Theres not enough clearance in the front. I have new springs ordered to fix this problem.
And I also have a chrome bumper on order to fill in the back end.
Next up is exhaust and alignment
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 02:18 AM   #23
LuckyHenriksen
Thanks Im glad you like it. I have a chrome bumper on order through LMC right now
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 02:32 AM   #24
LuckyHenriksen
I was having lots of trouble chasing electrical gremlins, and nobody could help me, so I enlisted the help of a shop across town. I used my AAA card and had it towed over there and back for free. They cleaned up some of the wiring harness and set everything right.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 08-22-2008, 02:48 AM   #25
IvelDesigns
sorry, i was talkin about the ride height. but it sounds like you're gonna get new springs up front to balance it out? or are you getting springs for the rear?
