03-02-2013, 03:05 AM | #26 |
Scrapper 1
Re: Pics of plug wire routing with hei and ram horns
1973 corvette plug wires are the wire you need to run the front 2 wires to 1-3 2-4 they are long enough to run throw the motor mounts and the Corvette used the RamHorns exhaust up to 1973 so when ordering HEI plug wires ask for the 1973 Corvette cus in 1974 they went to a different exhaust system no more Ramhorns
03-02-2013, 08:24 AM | #27 |
Watch out for your cornhole !
These are 76 Vette wires. They fit perfectly to route them as the stock wires were but these have the HEI ends. No reason to go to the trouble of custom making them.
Yes, I know you can't see the plug wires on the engines I build. That's the point of my pictures. They are there but out of sight. When plug wires are properly routed, they last a long, long time. |
09-21-2014, 03:25 PM | #28 |
Does someone have a part # or link to the correct wires? I would like to route under the manifolds but the corvette wires I ordered are not quite long enough. I would like to not mess around with ordering a bunch of different wire sets. It's for an hei distributor.
11-30-2014, 09:12 PM | #29 |
I am having a hard time finding the valve cover bolts that are long enough; any advice?
11-30-2014, 11:14 PM | #30 |
Here's mine. I built the plug wires. straight plugs.
Figure out what you want--then figure out what you are willing to give up to get it. |
11-30-2014, 11:51 PM | #31 |
12-01-2014, 12:42 AM | #32 |
subscribed.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
12-01-2014, 12:53 AM | #33 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-01-2014, 10:51 AM | #34 |
I got my bolts and lock washers at Lowes and cut the spacers from stainless steel tubing. I've been surprised how well the wires keep their shape over time. Now that I have the wire lengths, it will be easy to build them when they need to be replaced. Good luck
12-02-2014, 03:45 PM | #35 |
Thanks!
12-02-2014, 07:30 PM | #36 |
Here's three pictures, HEI with Rams, 1st is looking down, 2nd is front cylinders, 3rd is rears. Forth picture just for kicks, 72 C10, hedman 68608 headers, AFR angle plug heads.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-02-2014, 08:02 PM | #37 | |
12-03-2014, 05:15 PM | #38 |
beautiful!
12-03-2014, 06:28 PM | #39 |
Newbee
Thats how mine are, and it works great. I need to install the nomex sleeves on the ones behind the downspout though.
12-04-2014, 12:31 AM | #40 |
Ordered wires and loom tonite!!
Couldnt fine the r&m loom but subed the one Jegs sells under their name. Oughta work!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
06-20-2015, 09:52 AM | #41 |
02-04-2016, 02:47 PM | #42 |
Thread is old but really helps.I am trying to route wires like the factory.
02-04-2016, 03:25 PM | #43 |
Accel makes a set they will fit almost any SBC as they are a custom set for a BBC.
Part # 5040Y On my second set in 100k. Have a set in waiting. |
02-04-2016, 05:23 PM | #44 |
45 degree ceramic plug wires. Jeggs wire holders
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
07-28-2016, 09:00 AM | #45 |
Is most people using a cut to fit wire?
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
07-28-2016, 10:20 AM | #46 |
I used 75-77 vette wires, Car Quest P/N 35-8155. I haven't got them exactly where I want them yet but it gives you an idea. Some are definitely too long, I'll cut to fit later. One is slightly short, I may move things around to get it right. the wires will be loomed on the rear of the heads using later mode GM looms replicating the original style.
Bobby |
07-28-2016, 12:18 PM | #47 |
yup, custom built worked for me. That way they curve and fit perfectly. 180degree SP connectors. Suggestion-if you go this route, build 2 sets at the same time. That way you have a replacement already built for when they need to be changed..imho.
07-29-2016, 10:53 AM | #48 | |
Is part numbers 1713723, 1713724, and 1713726 the correct part numbers?
05-07-2017, 10:27 PM | #49 |
Looking for wires holders too.
08-16-2017, 10:12 PM | #50 |
So that 4-wire support at the very rear of the engine, right above the oil filter - what is the thread size and pitch on the bolt that secures it to the block? My engine is already installed in the chassis. Want to make sure I have used he right hardware before I torture myself trying to finesse it in with those tight quarters.
