Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-08-2009, 12:33 PM   #26
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Re: 67 SWB 4x4
I painted the transmission and transfer case with a single stage dark grey high gloss metallic paint.
It cleans easily and gives a nice contrast to the other colors, and is the same color as the rims.
The engine got rebuilt and shot with Krylon. We also shot the airfilter with semi gloss black acyrlic enamel, the same as the frame. Came out great.
I need a dipstick for this motor, it bolts to the exhaust manifold, and also a breather.
I am having trouble getting my 3 core radiator to fit. I am heavily modifying a 2 core cushion to make it work.
Ordered a custom aluminum 30 gallon tank and should have it mounted next week, along with the radiaitor support and radiator.
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 02-08-2009, 12:40 PM   #27
msgross
msgross's Avatar
Re: 67 SWB 4x4
nice progress
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-08-2009, 03:00 PM   #28
rmorelan
Re: 67 SWB 4x4
I was wondering if you could post some infromation on the 30 gallon tank you ordered? I'm working on a 72 and want to relocate my tank. Trying to find a tank that I can hang under the rear and fill it with ease. I really don't want to cut a hole in bedside to fill it. Got any ideas?
rmorelan is offline   Reply With Quote
Old 02-08-2009, 06:57 PM   #29
glimmertwin01
glimmertwin01's Avatar
Re: 67 SWB 4x4
SWEET! i could use the side mouldings if you decide to toss em . I could use some for my 67
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 02-08-2009, 08:21 PM   #30
msgross
msgross's Avatar
Re: 67 SWB 4x4
Here is one that I designed and had built for some guys. The company did an ok job, I basically copied the no limit engineering (brothers) tank. You can make it deeper to hold more gallons if you want...
http://67-72chevytrucks.com/vboard/s...d.php?t=289083
The Garage:
Old 02-08-2009, 11:20 PM   #31
Conroe trucker
Re: 67 SWB 4x4
I looked at MSGROSS's tank drawing and his bracing is similar to mine, a leaf spring truck. But, we used the same guy so now I am comfortable.
Wish I had seen that string earlier.
If yours is a coils spring truck your tank design is much easier.
Mine is a 4x4, so it has to have cutouts for the leaf spring perches to attach to the bottom of the frame.
But, it is clear all the way to the rear axle.
So my tank can be much longer.
I also could have made it deeper, but I kind of want it hidden under the truck.
It will be protected by the hidden hitch almost completely.
I plan on using a flush bed fill cap, and have it come up lined up on a the raised metal strip in the bed, to the far left.
My tank goes up to the curve up in the frame, and has the forward tank bracing at an angle to support the front of the tank in that curve. I use about 3/8" rubber pads to allow some movement of the frame and tank, and I spot weld the nuts in the frame after drilling and fitting evrything since they are almost impossible to get to with the tank in there and the trailer hitch.
Call Dave Boyd, boydwelding@bellsouth.net
352-447-2405
I have not seen mine yet, but it should be here anyday now. When it comes in I will post some pictures.
It is 27x22x11, which works out to roughly 28 gallons or so.
If you want my dimensions send me a private message with your email.
01 C5 convertable
08 Z06
Old 02-08-2009, 11:26 PM   #32
Conroe trucker
Re: 67 SWB 4x4
I do have cab moldings and windshield moldings in very good shape, the crystal horn button in perfect shape, a 4" lift kit with rear blocks, the big trailering mirrors, a pretty rough but no rust SWB feetside wood bed and I am sure other stuff.
I have not put it on the "For Sale" forum yet.
I prefer to get rid of this stuff all at once, but soon.
01 C5 convertable
08 Z06
Old 02-09-2009, 07:20 PM   #33
rmorelan
Re: 67 SWB 4x4
Thanks for the information. I got a copy of the print. What are going to do for an accurate reading sending unit? Would that come w/tank?
Old 02-09-2009, 11:39 PM   #34
Conroe trucker
Re: 67 SWB 4x4
No, Dave will recommend what he has cut out for.
01 C5 convertable
08 Z06
Old 02-10-2009, 12:45 AM   #35
msgross
msgross's Avatar
Re: 67 SWB 4x4
for sending units I bought this one from JC Whitney...
$29
http://www.jcwhitney.com/autoparts/I...D:100000163634
The Garage:
Old 03-08-2009, 08:04 PM   #36
Conroe trucker
Re: 67 SWB 4x4
Here is the tank before being bolted up.
It is a roughly 28-30 gallon tank done by Boyd's Welding.
This thing is hell for stout.
I had it made to follow the curve of the frame, and leave 1" for axle travel if it ever moves about a foot........
The tank has about 1/4-3/8" clearance around the frame.
It will not hamper mounting the hidden hitch at all.
When we coat the inner fenders with the hard epoxy bed liner I will shoot the tank bottom also.
This will hang down 1 1/2" below the bumper, and be almost perfectly hidden and protected by the hidden hitch.
To make it real easy to drop, I have tacked the 6) 3/8" bolts in the frame rail, and will use nylon lock nuts.
01 C5 convertable
08 Z06
Old 05-16-2009, 07:33 PM   #37
Mike Massingill
Re: 67 SWB 4x4
Here is the tank installed with the hidden hitch mounted.
It will give the tank alot of protection from the bottom and the back.
Truck goes to paint Wednesday, so we will be humping it to finish all the chassis work within two weeks.
Mike Massingill is offline   Reply With Quote
Old 08-05-2009, 07:38 PM   #38
Conroe trucker
Re: 67 SWB 4x4
Have not posted in a long time.
The chassis has been waiting for the body to be painted.
We blasted it and primed it in DP90, then gave it to the body man.
This is the Old Air compressor and brackets mounted on the small block.
We rebuilt the carb.
I need a 66-68 keyed PS pump pulley.........
01 C5 convertable
08 Z06
Old 08-05-2009, 07:45 PM   #39
Conroe trucker
Re: 67 SWB 4x4
The body man ran into some problems with bad clear product on the car before mine, so we got pushed back about 2 months before it got sorted out and he got back to mine.
We have the vent cowl, cab, misc. parts, doors, and front fenders painted now.
These pictures are before it was cut and buffed.
The firewall has been filled and smoothed.
The round hole is for the lines to come out of.
We welded the mounting studs to the inside.
Hopefully next week I will have the doors hung, cab mounted, and maybe even fenders mounted.
01 C5 convertable
08 Z06
Old 08-20-2009, 09:53 PM   #40
Conroe trucker
Re: 67 SWB 4x4
Finally making some headway.
Got the cab set, but not bolted down tight.
Doors are hung, and need a final buff.
Had to put the rims on my other truck so I had this set powder coated and the tires mounted.
Firewall is smoothed for an Old Air unit.
Cab bottom is coated with Raptor, a hard epoxy type bed liner.
Working on it after the fenders get on will be a *****.
01 C5 convertable
08 Z06
Old 08-20-2009, 09:59 PM   #41
Conroe trucker
Re: 67 SWB 4x4
We trial fitted the bed and I am glad we did.
Filled the stake bed holes and cut the gas filler hole.
The only real problem was one inner fender was off on some of the holes.
It actually fit decently.
I will have the original SWB fleetside bed for sale soon, along with a 4" lift kit, and a bunch of misc. parts.
01 C5 convertable
08 Z06
Old 08-20-2009, 11:30 PM   #42
Rack Man
Re: 67 SWB 4x4
Awesome Man...Looks GREAT!
Is that a "Vintage Air" system your installing?.....Also, are you changing out the fan to a six blade - clutch style?....I thought I read where it is recommended for the aftermarket AC systems....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 08-21-2009, 08:07 AM   #43
Conroe trucker
Re: 67 SWB 4x4
This is an Old Air system.
While they are almost identical, I preferred the warranty of Old Air better.
I may have to go to a 6 blade eventually.
I will wait and see after I get it running.
01 C5 convertable
08 Z06
Old 09-08-2009, 03:02 PM   #44
Conroe trucker
Re: 67 SWB 4x4
Finally a little more headway.
We have the tailgate painted but not installed.
Then we have the new bed mounted.
I went with a totally new bed with a metal floor.
It actually fit decently, with just a few mods.
I prefer the easy maintenance of a metal bed.
On this truck we used Raptor to undercoat the cab, bed, bed inner fender bottoms, and both sides of the front fender inners.
This will make it much quieter, almost rust proof, and you can just wipe it off with a sponge to clean it.
01 C5 convertable
08 Z06
Old 09-08-2009, 03:06 PM   #45
Conroe trucker
Re: 67 SWB 4x4
I think Tuff Country miss shipped me a 6" set of front springs instead of a 4" pair. We will have to change them out, since the truck is way too high as it is.
I will take better pictures this weekend when we mount the mirror stalks, tailgate, and maybe the front fenders.
01 C5 convertable
08 Z06
Old 09-08-2009, 11:16 PM   #46
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 67 SWB 4x4
Awesome truck dude, cant wait till mine is there
Tony
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-27-2009, 07:59 PM   #47
Conroe trucker
Re: 67 SWB 4x4
Had a small problem, Tuff Country sent me 6" front springs versus 4" as ordered.
So here it is with the new springs and on the ground versus dollys.
IT is 1" taller in the front and almost 2" taller in the back than my 70 with the same lift.
Once it breaks in and has 35 gallons of gas in the rear it should be perfect.
We Rapture coated the bottom of the cab, rear inner fenders, both sides of the front inner fenders, bed bottom, and the transmission cover.
01 C5 convertable
08 Z06
Old 09-27-2009, 08:28 PM   #48
Conroe trucker
Re: 67 SWB 4x4
I started installing the Vintage Air kit at this time.
The fenders are off, so while waiting for the correct passenger exhaust manifold I thought I could knock this out.
If your manifold is not a straight dump, it will exit almost on top of the starter and may hit the cab on the passenger side.
Sure we could have made it work, but we would have baked the starter.
We shaved the firewall but cut an opening for the lines to come through.
I may have to drill one more hole for the hot water feed valve.
Pretty clean and easy.
The radiator support required drilling two holes for the lines to go through.
Have not run those yet, the grommet was still drying.
I am using RAM Audio sound deadening stuff for the cab.
Used it on the last truck, and we could not hear the engine running at stop signs.
This stuff will stick to anything, but is hard to work with above 80 degrees,it gets too sticky.
01 C5 convertable
08 Z06
Old 09-27-2009, 08:44 PM   #49
Conroe trucker
Re: 67 SWB 4x4
The rest of the AC pictures and some shots of how close a small cap HEI is on a K10.
I will move my cab back about 1/4 inch, and I will have less than 3/4 inch.
Pretty close, and surprised it dropped in.
01 C5 convertable
08 Z06
Old 10-12-2009, 10:19 PM   #50
Conroe trucker
Re: 67 SWB 4x4
Shortened the steering column about 2".
Also when taking the seat to be upholstered we found the original build sheets.
They are pretty tender, but I can get them back together and scan them for records.
01 C5 convertable
08 Z06
