Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-19-2008, 12:22 AM   #26
lyrikz
PITbut
lyrikz's Avatar
Re: mild 454
Originally Posted by d10s69c10 View Post
i picked up a 85 4 bolt 454 turn key for $500. pretty high miles but im redoing everything and so far my block has checked out.
if you got a motor in the truck and got time just dont rush it and find a good deal and have it rebuilt with some good light Balanced internals. along with you cam intake and Carb, "the toilet bowl isnt nessicary".
i think you will be completely satisfied with results.
Big blocks are about 40% more expensive for all parts across the board. compared to sbc's
Thats what i did. I bought a 1981 gmc 2500 with the original running 454 for 900 bucks. Pulled the motor/trans/carb/kickdown switch and sold the truck for 200 bucks. ahaha. Carb was damn near perfect. Had that rebuilt... I want my truck runnin so bad. I have wanted a 454 since i was 16 years old.. 17 years later and i have one.. just cant start it. ahaha.
lyrikz is offline   Reply With Quote
Old 08-19-2008, 03:38 PM   #27
85sqbdy
85sqbdy's Avatar
Re: mild 454
http://static.racingjunk.com/63/ui/3...7277211377.jpg HERES MINE 454BBC CAN'T GO WRONG. WORTH THE STREET CRED. AND THE RESPECT. I SHOULD HAVE DONE IT THIS WAY A LONG TIME AGO. ONCE YOU GO BIG BLOCK, IT'S HARD TO GO BACK
85sqbdy is offline   Reply With Quote
Old 08-19-2008, 03:39 PM   #28
85sqbdy
85sqbdy's Avatar
Re: mild 454
Old 08-19-2008, 03:45 PM   #29
85SBC400
Re: mild 454
yeah i think i'm going to go that way.......now i just gotta find me one lol.
85SBC400 is offline   Reply With Quote
Old 08-19-2008, 06:25 PM   #30
70rs/ss
70rs/ss's Avatar
Re: mild 454
I have found 3 Vortec 7.4's in the last year or so for $100 each. Two had a rod knock, no biggie, I am going 496 and the stroker kits run about $1400, so a 4-bolt main block, 496 stroker kit (crank, rod, pistons, ring, etc, etc) and the 96 and up Vortec oval port heads. The heads have a 100cc chamber and the fast burn combustion chamber, they flow as good as most aftermarket iron and or aluminums, but open up the valves a bit, bowl blend, etc and you have an excellent set of heads on your hands. 550-600hp is super easy with this set up and I'd guess cost around $3k for a long block ($300 for intake {edel rpm air gap}, dist, carb {750 or 850 vac or mech secondaries) turbo 400 and tada!
The 40% more may not be all that true since a BBC starts out making power in gobs where as the SBC needs to be wrung out, don't compare BBC to SBC in cost, look at it in terms of $$$/hp and the BBC is nearly a wash. I built a wicked 383 from an iron 97 iron Vortec 350 and have $2600 into the longblock and might be able to put down 450-500hp, now that same $2600 and $400-600 more and I am tossing 550-600hp, so how much more is it to build a BBC???
70rs/ss is offline   Reply With Quote
