Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-15-2008, 11:36 PM   #1
85SBC400
mild 454
hey guys, i'm debating on building a mild 454 to go into the 85 chevy. its got a smallblock 400 in it now that i've told ya'll about. and my plans for it.
what do ya'll think of the idea of instead of doing all that to the 400 just building a mild 454 and dropping in there?
85SBC400 is offline   Reply With Quote
Old 08-16-2008, 12:46 PM   #2
Rodms
Rodms's Avatar
Re: mild 454
It would run like hell thats for sure but gonna cost more for parts
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-16-2008, 04:55 PM   #3
1FAST68
Re: mild 454
I just built a sbc 400 for a friend that runs 11.80's on pump gas in a 71 swb. The only thing expensive was the heads.
1FAST68 is offline   Reply With Quote
Old 08-16-2008, 05:09 PM   #4
lyrikz
PITbut
lyrikz's Avatar
Re: mild 454
I just built a "mild" 454. Mild was 520 hb and 540 pounds of torque.. 4500 bucks later.. wooot.
lyrikz is offline   Reply With Quote
Old 08-16-2008, 06:38 PM   #5
Ford Assassin
Ford Assassin's Avatar
Re: mild 454
BBC are more money to build, but not a sure huge difference. Plus BBC under hoods are instant respect because of so many SBC normally found.
I like all GM V8's, but BBC are my bread and butter. I'd say go for it.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 08-16-2008, 07:51 PM   #6
85SBC400
Re: mild 454
yeah i think it would be cool to have that wow factor too of just saying i have a bbc under the hood lol. street credit lol
now what tranny should i go with behind it? th400?
Old 08-16-2008, 08:31 PM   #7
Ford Assassin
Re: mild 454
Depends on how wild.
I ran a mild TH350 behind my 550+HP 454.
Cable
Old 08-16-2008, 08:48 PM   #8
85SBC400
Re: mild 454
well it'll be a nicely built th350 if it'll hold up.....it'll have a manual valvbody and brake. looking for around 550-600 out of the 454. th350 should be able to be built to hold that huh?
Old 08-16-2008, 08:54 PM   #9
Ford Assassin
Re: mild 454
If you are going to run a brake, I'd just go with the TH400. Transbrakes are pretty hard on the trans. Better to build one tranny once and have the piece of mind.
Cable
Old 08-16-2008, 09:14 PM   #10
85SBC400
Re: mild 454
what if i didn't go with a brake......i'm going to be running the foot brake class anyways
Old 08-16-2008, 11:13 PM   #11
71Dragtruck
71Dragtruck's Avatar
Re: mild 454
A mild 454 won't make 550-600hp.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 08-16-2008, 11:38 PM   #12
85SBC400
Re: mild 454
ok well what i mean by mild is basically a head/cam/intake 454
nice dominator carb of some sort
i dont really know much when building a big block if i do it then it'll be a learning experience for sure.
Old 08-17-2008, 02:38 AM   #13
Super73
Super73's Avatar
Re: mild 454
What's yhour budget?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-17-2008, 11:28 AM   #14
Ford Assassin
Re: mild 454
I wouldn't run a dominator on anything making less than 800+HP, even then with a race only setting. Dominators are not the most ideal street carb. A Holley 4150 HP series is more than enough for all but the most serious race engine and can be made to be pretty street friendly.
Building a decent street/strip 454 or 496 is easy enough. GM iron oval port heads with 2.19/1.88 valves and a mild port job on top a 9.5:1 compression 454/496 and decent size cam (like Lunati Voodoo series) and you'll have tons of torque and more horsepower than your tires can handle. 12's are pretty easy at that point.
Don't get wrapped up in the 'bigger is better' problem that lots of folks end up doing. Things like single plain intakes, huge cfm carbs, 2"+ primary headers, 3500+ stall converters, manual valve body trannys, and 4.56+ gears are not needed on anything but the more serious race car/trucks.
Cable
Old 08-17-2008, 11:31 AM   #15
Ford Assassin
Re: mild 454
Here is a good example, I ran this 454 in my little Datsun Z car:
Bottom End:
-454, 4 Bolt Block w/ARP Main Studs
-Bored to 4.280" (0.030" overbore), Honed w/Torque plate
-Stock 454, 4.00" Stroke Cast Iron Crankshaft
-Stock Big Block Chevy I-Beam 'TRUCK' Rods w/3/8" ARP Wave-Loc Bolts
-TRW/Speed-Pro L2465F Forged Pistons (25.7cc dome volume) appox 9.5:1 Compression w/119cc Heads
-GM .020" Steel Shim Head Gaskets (Copper-Coated, pre-torqued)
-ARP Head Bolts
Up Top:
-Chevrolet '049' Large Oval Port Heads, 2.19/1.88" S/S Valves, Pocket Ported
-UltraDyne Designed, Lunati Ground 402A2 Solid Flat Tappet Cam: .550"/.570", 272/282 adv dur, 238/248 dur@0.050", 112 LSA and 4* advance ground in
-EDM Oil Pin 0.021" Hole Solid Lifters
-3/8" Chrome-Moly Racing Pushrods
-1.7:1 Crower Stainless Endoro Roller Rockers
-Edelbrock Performer RPM 'Air Gap' Intake Manifold
-Holley 830HP Carb
-HEI Billet Distributor
Tranny/Exhaust:
-TH350 Tranny w/Trans-Go Shift Kit
-ATI Streetmaster 11" 2500 Stall Converter
-Nissan R200 VLSD w/3.45:1 gear ratio
-Ground Control Adjustable Coilover Conversion
-Tokico Struts
-Custom Block Hugger Headers, 2" primaries, 3.5" collectors
-Dual 3" exhaust, Dynomax UltraFlo Race Magnum round mufflers
Cable
Old 08-17-2008, 12:08 PM   #16
85SBC400
Re: mild 454
well as far as budget goes, i'm not going to be throwing his together in a few months. i'll run this 406 that is in the truck while i'm building the 454. so i lots of time to be able to piece the engine togither. if it takes me 6 months to get a nice 454 built then it takes me 6 months. i'm willing to wait to make sure i get the right parts and good parts to get it together.
and i dont even have the 454 yet. i'm still trying to scroug one of those up right now.
Old 08-17-2008, 01:40 PM   #17
Ford Assassin
Re: mild 454
I have one.
Too bad you aren't closer.
Cable
Old 08-17-2008, 03:08 PM   #18
chevy72blu
chevy72blu's Avatar
Re: mild 454
PICS!!!!!!!!!!!!!!!!!!!!!
(sorry for the hijack, but I need to see this)
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 08-17-2008, 03:44 PM   #19
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: mild 454
X2 on datsun pics(my friends 383ci is a MONSTER)the THING must rule the streets
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 08-17-2008, 04:09 PM   #20
85SBC400
Re: mild 454
bummer lol
Old 08-17-2008, 04:59 PM   #21
Ford Assassin
Re: mild 454
http://www.cardomain.com/ride/685533
http://videos.streetfire.net/video/M...454_132909.htm
Cable
Old 08-18-2008, 12:31 AM   #22
Super73
Super73's Avatar
Re: mild 454
Starting with what you want it in finacially will give a better understanding of what motor/setup to run. That's just me though..
Old 08-18-2008, 12:52 AM   #23
lyrikz
PITbut
lyrikz's Avatar
Re: mild 454
Mine is considered mild. Its not 540 to the wheels but puts out 540 on the engine dyno.... Thats cast heads to. Not aluminum...
Old 08-18-2008, 11:50 PM   #24
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: mild 454
I just finished installing a mild 454 into my '87 SWB.
Here's what it looked like recently;
All the info about the build is in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=279281
I don't think it's as BADAZZ as that Z but it's pretty nasty. It's around 450 hp / 500 ft. lbs at the flywheel according to software.
Kenny
87Lowrider is offline   Reply With Quote
Old 08-19-2008, 12:18 AM   #25
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: mild 454
i picked up a 85 4 bolt 454 turn key for $500. pretty high miles but im redoing everything and so far my block has checked out.
if you got a motor in the truck and got time just dont rush it and find a good deal and have it rebuilt with some good light Balanced internals. along with you cam intake and Carb, "the toilet bowl isnt nessicary".
i think you will be completely satisfied with results.
Big blocks are about 40% more expensive for all parts across the board. compared to sbc's
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
