Old 10-31-2009, 10:20 PM   #26
watahyahknow
watahyahknow's Avatar
Re: Finally starting my Longhorn 4x4 conversion
you might be able to adapt the engine and trannymount on the chevy chassis though
dunno if you will do a bodylift on the truck but if you do you could make new crossmembers above the ford chassis and mount the cab on that
it would look a little better
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-02-2009, 08:03 PM   #27
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
This truck more than likely won't have any gas engine. LOL I plan on installing a 5.9 cummins in it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-03-2009, 02:07 AM   #28
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Dieselwrencher, I was just checking my 4x4 frame against my Longhorn frame the front is exactly the same width. It looks like an easy swap on front spring hangers and frontend. The transfer case mount looks to the be the same sort of easy switch. If the rearend remains the same you would only have to lengthen the driveline by about 8". What did I miss?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-10-2009, 06:46 PM   #29
Dieselwrencher
I was thinking of putting the longhorn body on a 89 F-350 frame, but that idea has went into the trash.
Ryan
Old 11-10-2009, 06:49 PM   #30
Dieselwrencher
Well this morning I moved the old truck out of the weeds and got it back on some stands. I dug out my donor frame and started cutting hucks or rivets to get my 4wd brackets off. I got the RH side off and tomorrow I plan on getting the LH done and try to get the shackle hangers installed. Here are a few pictures of tear down.
Ryan
Old 11-10-2009, 06:51 PM   #31
Dieselwrencher
I'll post some pictires of the front frame section from the donor and of the cleaned up bracketry later. I just realized today that since I am installing the steering box brace in the longhorn frame, I have to cut the rivets out of the front cross member on the Longhorn frame and remove the front cross member to get the brace in there.
Ryan
Old 11-10-2009, 10:06 PM   #32
watahyahknow
http://chuckschevytruckpages.com/ this one hold a lot of tips and dimentions on the frame you might get some use out of it during the conversion
Old 11-11-2009, 04:07 PM   #33
Dieselwrencher
This morning I got the front bumper off, the front clip is off, the radiator support mounts are off, and I started removing the manual transmission cross member. I put a brace in the middle of the frame to help keep it together so I can remove the front cross member to install the steering box brace later.
Ryan
Old 11-11-2009, 08:18 PM   #34
Dazn9796
Subscription done. Looks good I will be doing the same thing shortly. Just a quick questions, did the 3/4 ton trucks have or use more than one axle. Did they use d44 or d60 or both? just curios so i can start looking at what i need to find here at the junk yard.
Dave
Dazn9796 is offline   Reply With Quote
Old 11-11-2009, 08:51 PM   #35
dammitmitchell
the pollock
dammitmitchell's Avatar
seriously MITCHELLville iowa...
i would give you money to buy me mitchell ville memorabilia and send it to me..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-12-2009, 12:12 AM   #36
Dieselwrencher
Dave
They only used D44's until 75 or 76 then they had D60's in the K30's. And I think 78 or 79 is when the switch started for the corporate 10 bolt front. Just try to find a big hub D44. I have a closed knuckle D44 from my 69 K10 I would sell cheap if you want.
Ryan
Old 11-12-2009, 12:13 AM   #37
Dieselwrencher
Yep, Mitchellville, Iowa. The town has less people in it than the prison has inmates. LOL What kind of memorabilia are you looking for?
Ryan
Old 11-12-2009, 12:32 AM   #38
Dieselwrencher
Here are the fromt spring mounts cleaned up a little bit and painted.
Here is a shackle mount in case you don't have one. And the 73 ups aren't the same as the 67-72 ones just an FYI.
Ryan
Old 11-14-2009, 12:56 AM   #39
Dieselwrencher
Well I got the shackle bushings replaced with energy suspension polyurethanes, also installed the rear bushings in my 6" lift springs, got the front cross member reinstalled, got the steering brace installed and found out the 4x4 frames and 2x4 frames aren't exactly the same in the steering box location. I also cut the e-brake mount out of the frame and installed a flat piece of steel there, and removed the original manual trans cross member. Next week I will install the shackle mount and then move to the RH side.
Ryan
Old 11-14-2009, 12:57 AM   #40
Dieselwrencher
Check out the steering box holes. They don't exactly line up. I guess that just means more work for me.
Ryan
Old 11-17-2009, 12:26 AM   #41
Dieselwrencher
Some more progress, but not much. I have been working on putting a shop up on the weekends and using this as fill since I can't work on the building alone.
Here is the RH frame after I cut out the ebrake mount.
Cleaned up, ground and beveled, with plate in place getting ready to weld.
Partially welded. I couldn't finish because the wind was blowing 30-50mph and it kept blowing my gas off the weld.
Ryan
Old 11-17-2009, 12:29 AM   #42
Dieselwrencher
I welded the inside of the LH rail as well. Hopefully tomorrow I can get the welds finished and ground down and install the shackle mounts in the frame.
Ryan
Old 11-18-2009, 05:32 PM   #43
Dieselwrencher
More progress. Yesterday I ground down the welds I did on Monday and I rewelded them. Today I put one of my leaf springs on and started preparing to install the shackles. I don't exactly like where my spring is going to put the shackle in the frame. My leaf springs are for a 73 up and are a little bit longer. I did check and the center pin is in the same location so I might just use my springs I have, but I would prefer a set of 4"ers. So now I have to make the descion to use these or find some 4" 67-72 springs.
Ryan
Old 11-18-2009, 05:38 PM   #44
Dieselwrencher
I did also go buy some goodies for this truck too. Last night I picked up a rust free radiator support, decent tail gate with no large dents and one bad rust spot, new black high hump carpet, new sound deadener, used sill plates, a new glove box, a used wood grain gauge bezel, reconditioned hood springs that are zinc plated, and new heavy duty radiator mount bushings. This weekend I am getting rust free inner fenders from Brother's69C10. Hopefully by the end of the week I can get the front axle under it and get the front clip mocked up in place.
Ryan
Old 11-18-2009, 06:11 PM   #45
Dieselwrencher
I forgot to add, I decided what powertrain I am going to use. It will be a 1990 5.9 cummins with a 1998 NV4500 and a NP205 from a 92 dodge. I'm still undecided on the rear end. It might get a D70HD from a dually, or a D70 from an 84 ford. I need to measure the dually rear to see how far the wheels will stick out on these style trucks.
Ryan
Old 11-19-2009, 05:15 PM   #46
Dieselwrencher
Finally some real progress! I put a front fender on and slid my extra D44 in to see if the wheel was in the center of the wheel well before I installed the shackles in the frame. What do you think? I think it looks fine.
Here is the RH shackle installed.
I am going to have to notch my body mount braket so the bolt will be flush, but I can do that later. I have to finish the LH tomorrow and get the front clip in primer. I decided to install a 2 1/4" cowl scoop on my hood so hopefully I can get the hood close to done tomorrow. Once I get the clip back on it I will install my D60 and start mocking up for the powertrain.
Ryan
Old 11-19-2009, 08:27 PM   #47
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Looks like your really going to town on it now! I'm not much on the 2 wheel drive stuff and having a hard time understanding what those e-brake mounts are for?? Keep up the good work!! will be watching this one!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-19-2009, 09:17 PM   #48
Dieselwrencher
The ebrake mounts are for the park brake cable system. The LH one is for the cab pedal assembly cable and on the RH frame the end of the cable is secured by a bolt through the frame mount. It is like a big horse shoe set up.
Ryan
Old 11-20-2009, 04:28 PM   #49
Dieselwrencher
Well I got the fenders primered after work last night. Today I drilled and bolted the LH shackle to the frame, and I installed the trim back on the LH fender. Tonight I have to go get new poly bushings for the support so next week I can put the front clip together to start mocking up the engine.
Ryan
Old 11-22-2009, 03:07 PM   #50
roger0080
Those are some damn nice heavy duty jack stands there. Are they home made?
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
