Old 03-02-2009, 10:22 AM   #26
Redline
Redline's Avatar
Re: Where is my 60-66 Chevy or GMC vin number?
Ya that was the same thing I saw when I typed it in. I am sure that this cab did not come with this frame. I'm going replace the cab with one that is less rusted. But it would be nice to know what frame this is.
Thanks,
Redline
Redline is offline   Reply With Quote
Old 03-03-2009, 03:14 PM   #27
Redline
Redline's Avatar
So I found the VIN on the frame and this is what I came up with....
VIN S113673
Model Year 1961
Chassis (unknown code)
Body Style Motor Home
Series (unknown code) with optional 7800 GVW (1 ton) Plate
Assembly Plant GMAD Detroit
Sequential Number
Any ideas????
Old 03-03-2009, 03:46 PM   #28
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
ok, I think that other # you found on your frame, was a part#, and a poduction date- 9-28-62, which would be right in the thick of 63's production.
you new # that you found, matvhes your vin, on the cab (I think the 3 is an 8), every thing else matches up.
all the frame had for a code, was :
the last digit of the production year
the letter of the assembly plant
the sequential #
check out the pics in post #3, with the frame vin, and the 65 body tag.
sand around in front of that s, and you should find a 3, I am 99% sure that yoour frame is the original for that cab.
Old 03-03-2009, 04:30 PM   #29
Redline
Redline's Avatar
Ok, sounds good.... its starting to make a little more since. Has anyone ever heard of a 3/4ton dually???
Old 03-08-2009, 01:29 AM   #30
jason65
Registerd User
jason65's Avatar
So what about the 3 digit code on the door pilars between the door hinges?
I got a 001 on the left and a R72 on the right. Never noticed them untill I sanded over them today.
jason65 is offline   Reply With Quote
Old 03-08-2009, 08:07 AM   #31
jonzcustomshop
1961 crewcab
.... probably just a part #, you wouldn't believe all the stampings that you would find if you had your cab acid dipped....
pretty much every piece has a # stamped on it somewhere.
Old 03-27-2009, 06:34 PM   #32
towrecker
this might be a stupid guess i bet that frame is one of a bread or milk truck ...i have done that with a 65 that was killed in the rear ...bread truck 100.00 wrecked 65 c-10 250.00 ...i moved and still do lots of hay with it ...i will check mine to see if it could maybe be an unknown too...
towrecker is offline   Reply With Quote
Old 03-31-2009, 09:17 PM   #33
protrash64
Resistance is Futile
protrash64's Avatar
stick 'n it btt
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-12-2009, 03:20 AM   #34
Woogeroo
This thread should really be a sticky in the 60-66 forums or a FAQ article.
-W
Woogeroo is offline   Reply With Quote
Old 05-12-2009, 11:49 PM   #35
Captainfab
60-66 Nut
-W
I agree
Old 05-12-2009, 11:51 PM   #36
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by Captainfab View Post
I agree
Alan's Classic is offline   Reply With Quote
Old 05-15-2009, 08:43 AM   #37
jonzcustomshop
1961 crewcab
BTT
post # 3 I added a pic of the under cab vin location!
Old 05-31-2009, 01:57 PM   #38
jonzcustomshop
1961 crewcab
btt
Old 07-20-2009, 12:22 AM   #39
likaroc13
Rollin' Old Skool
can somebody help me figure this out?
Vin tag located on driver's side door jamb:
it's stamped: GMC truck 1002 P F6261A
thanks for any help
Old 07-20-2009, 07:19 AM   #40
jonzcustomshop
1961 crewcab
here's what I deciphered from www.6066gmc.org/ :
10=1/2 ton
02=127" wheelbase
P= pontiac michigan assembly plant
F= 64-66 model year* see the pharagraph below for more on the F code.
6261= sequential production #
A=6000 pounds or less GVW
*The series letter for 1964 to 1966 is "F". There was not any
more major changes for this body style. But there was a series letter "E" used on some
1965 trucks (have not seen any yet) & "D" used on all inline engined 1966 trucks. More
info has been found for "F" Series Trucks, GMC built truck in two plants from 1964 to
1966, the Pontiac Michigan plant & one of two plants in California, Oakland or Fremont.
If your trucks vin shows "HF" it was built in the Oakland California plant which GMC shut
down after the 1964 Model year, so all "HF" trucks are 1964. Production was moved to an
ALL NEW plant built in Fremont California for 1965, so "ZF" trucks are 1965 or 1966.
So here is a brake down of the series letters;
N = 1960-1961, J = 1962, G = 1963, F =1964-1966, E = 1965, D = 1966
Old 07-27-2009, 08:09 AM   #41
jonzcustomshop
1961 crewcab
btt, I've seen alot of vin ?'s lately...
Old 03-18-2010, 10:04 PM   #42
daxloves
daxloves's Avatar
Having trouble identifing the plant that this truck came from, the rest of the vin I got. From what i gather its:
Chevrolet 0C1540112583
0= 1960
C= 2WD
15= 1/2 ton LB 127'' WB
4= Pickup
0= ?? Plant is ??
112583
Anyone know what plant is 0?
daxloves is offline   Reply With Quote
Old 03-19-2010, 08:04 AM   #43
jonzcustomshop
1961 crewcab
pretty sure that "O" is for the oakland plant in calif...
Old 08-11-2010, 03:27 AM   #44
old_1966_GMC
help decode my vin lost in mind 1502ZF11071B
15---->1500 serise
02---->127'' wheel base
Z----->Made in Fremont CA
F----->1964-1966
11071---->Production line (this where im confused)
B----->6,000-10,000 GVW class
so far this is what i got.The only thing that im confused with is the 11071 production line, From the info i got from http://6066gmcguy.org/GMCID1.htm looking at the way bottum where it says GMC Truck Production Figures it shows for the production in 1966 there where only made 10,488 in Fremont CA i need all the help i can get to figure this one out.
Thanks all u people that are in this forum for all the info and help.never though i would have this truck after grandfather in law past away never new anything about these trucks till i joined this site thanks.
old_1966_GMC is offline   Reply With Quote
Old 08-11-2010, 04:59 AM   #45
jonzcustomshop
1961 crewcab
The next group of numbers is the Serial number or unit built number, all series at all plants
started with Serial number 1001. For the 1966 year run, GMC started most series with Serial
number 10,001, but some series not used in 1965 started with 1001. I have found that GMC had
a lot of left over trucks from 1965 & they sold them NEW in 1966 as 1966 Models, this was
done to rid the dealers of any older trucks still on the lot to make way for the NEW body
Style coming in 1967. If you have a GMC "PF" or "ZF" series truck titled as a 1966, but the
Serial number is lower then 10,000, it mite really be a 1965 model year truck. One way to
tell is to check the engine for a spin-on oil filter, no spin-on filter, then it's a 1965.
GMC swithed to the spin-on oil filter for the 1966 model year on V6 powered trucks.
with that in mind...yours should be the 1171st built that year.
Last edited by jonzcustomshop; 08-11-2010 at 03:20 PM. Reason: cant do simple math!:lol:
Old 08-11-2010, 11:08 AM   #46
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Stuck !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-11-2010, 01:41 PM   #47
old_1966_GMC
kinda lost still
Old 08-11-2010, 03:19 PM   #48
jonzcustomshop
1961 crewcab
15---->1500 serise
F----->1964-1966
**** production started with 10,001 in 1966, with that in mind yours was # 1071 to recieve a vin plate that year****
Old 08-11-2010, 03:41 PM   #49
old_1966_GMC
so if the production was 1071th then what was the purpose for 11071th being stamped to the vin plate kinda wired to think about.
Old 08-14-2010, 09:32 PM   #50
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
