Old 03-19-2009, 08:42 AM   #26
FormerMember
Re: 71 4x4 BBC Swap: Doing what I should have done the first time!
Originally Posted by Ridin' High View Post
I have a problem only because I don't have a sway bar yet. One of things on the list with this rebuild
The leverage that steering link has at bind has to be phenomenal. I'd try a 3" riser block on under the steering arm to ease up some angles there. Might even bend and gusset the linkage to prevent bind at the rod ends.
I am not sure a sway bar will fix that...
FormerMember is offline   Reply With Quote
Old 03-19-2009, 02:38 PM   #27
onlyifihadachevy
now im going really off topic but are those mile marker classic hubs?
because i need that style front hub and i ordered the warn for the 67-80s blazer hub because they didnt have 3/4t hubs for a 72 truck.
they didn't work!
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-19-2009, 09:55 PM   #28
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
they didn't work!
I originally had mile markers on the 44, but i have warn hub on there now.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 03-19-2009, 10:22 PM   #29
onlyifihadachevy
i ordered the special piece and it was another 100 bucks. I belive you go offroading so if you do where do you go because i would love to watch your truck after you put in the new motor.
My 72 thread
Old 03-20-2009, 12:34 AM   #30
Chevy1TonFun
Grease Monkey
I go mud bogging out in madera
Old 03-20-2009, 01:05 AM   #31
onlyifihadachevy
whats the mud like and how deep? last oct in hollister it was about 2-3feet deep and pretty slick seeing as it was clay. a lot of people got stuck unless they had boggers or when slow.
My 72 thread
Old 03-28-2009, 11:10 AM   #32
Chevy1TonFun
Grease Monkey
Ok change of plans... I got with my buddy from AirFlow Performance and since I needed to by a new crank, He suggested that I build a 486 Stroker! My buddy has the specs and list of internals. I dropped the block off thursday at Fresno Performance to complete a deck, bore, balance, and clearance. I also found some bare large oval port heads, the 681 I believe, for $40. My buddy from Air Flow specializes in Port and Polishing heads. He is going to do a stage 2 port and polish. So thats where I at for now.
Anyone have a 1000cfm Demon carb? I need one.
Old 04-18-2009, 12:20 AM   #33
Chevy1TonFun
Grease Monkey
Still waiting on my new crank, 4 week shipping, but everything else is ready to be picked up. So, while I am waiting I finished with the body lift, painted the engine bay and put the 39s back on. Take up too much space in the garage, plus I wanted to see what the spacing was with the BL. So here are some pics. I hate the bumper gaps. I will be fixing those later. Also I'm trying to pick a color for the block. I am thinking about a med silver gray. Let me know of any ideas you might have.
Before BL:
After BL and no drivetrain:
Old 04-18-2009, 02:45 AM   #34
onlyifihadachevy
I really really "liked" your truck because it look until i saw the gaps it still looks great just need to move the bumper mounts or something up. But i think the best idea would be to build a bumper because if you move the stock bumper you have the frame showing. i think you will find something to make the gaps not look asbad.
My 72 thread
Old 04-30-2009, 11:33 PM   #35
Chevy1TonFun
Grease Monkey
I've really busy with work lately, but I did get some time to work on it this week. I was able to clean up the turbo 400 and paint it. I was also able to clean up the engine bay, frame, and wheel wells.
Old 05-09-2009, 12:47 AM   #36
Chevy1TonFun
Grease Monkey
Sorry for the delay in updates, I've been busy at work and saving up cash to buy parts. So this is where I'm at. I got the block back last week. Fresno Performance decked, bored, honed, line honed, and clearanced the block for the stroker setup. This last weekend I was able to get some paint on it. My first order from Summit Racing came in on Thursday and got a shipment from my buddy today. Another thing is while moving the truck around I broke my rag joint on my steering shaft. I was able to find a nice used one, and broke that one first try. So I call around, did some searching, and found a really great price for a heavy duty steering setup from Borgesen. I ordered a 24" telescoping shaft and two HD U-Joints for just over $200. I also ordered my DIY4X Cross member. I'll be getting that in the next week or so. Currently I have a bare 489ci BBC Stroker Block that is waiting for innereds. I have H Beam Connecting Rods, Keith Black Pistons, Edlebrock Air Gap Intake, MSD HEI Distributor, and Doug Throley Header. I'll be ordering the rest of the internals next week. For now here are the pics of my progress.
Old 05-09-2009, 12:59 AM   #37
onlyifihadachevy
how much is this 489 setting you back if you don't mind? And from my understanding correct me if im wrong but a 489 stroker is a standard 454 blck with different internals.
My 72 thread
Old 05-09-2009, 09:55 AM   #38
Chevy1TonFun
Grease Monkey
I'm into in the motor about $2500 so far. The stroke is increased to 4.250 and the block is bored .030 over ia a 489.
Old 05-09-2009, 12:11 PM   #39
72chevyk10
I built it
72chevyk10's Avatar
man that thing is gonna be a screamer! 'bout how much compression/hp/torque do you think its gonna run?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-09-2009, 04:47 PM   #40
Yukon Jack
Post Whore
Yukon Jack's Avatar
Very nice progress - it's looking great!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-09-2009, 09:44 PM   #41
Chevy1TonFun
Grease Monkey
My guess is 600+ HP, 750+ lbs Torque, and the compression is 10.5:1 ( i think). Well have to wait and see what it really puts out after I dyno the truck.
Old 05-09-2009, 11:41 PM   #42
72chevyk10
I built it
72chevyk10's Avatar
Old 05-10-2009, 09:57 PM   #43
Chevy1TonFun
Grease Monkey
Stupid Photobucket deleted a folder of my pics, so if you guys want me too i'll repost the pictures.
Old 05-11-2009, 09:44 AM   #44
Yukon Jack
Post Whore
Yukon Jack's Avatar
If it is just pulling the pics from a different folder, but same pic names, that should be an easy fix for me - just post up a single pic that is coming from the correct folder and I'll get the other ones working for you.
Old 05-20-2009, 11:22 PM   #45
Wildstreak
"something witty here"
Wildstreak's Avatar
Subscribed! I plan on swapping a 454 hopefully one day, this just motivates me . That thing is gonna fling hella mud!
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 05-20-2009, 11:59 PM   #46
Chevy1TonFun
Grease Monkey
Update:
Made my last order from Summit today. I believe I have everything ordered, but the internals for the heads. I've spent about a $1200 with them alone and about $1500 through Fresno Performance. I'm tired of spending money. Is that weird to say? Anyway I am about ready to start assembly of the motor. I have been waiting on the cam, which I will be ordering next week. So, I should have lots of progress and pics soon. One other really cool thing. My truck is in the July issue of Peterson's 4wd and Offroad magazine! So check it out!
Old 05-21-2009, 12:02 AM   #47
Wildstreak
Wildstreak's Avatar
well I get that magazine regularly, it'll be nice to to see a 67-72 in it. Is it a main feature? or.....
57 chevy 4x4
68 burb 2wd:
Old 05-21-2009, 08:09 AM   #48
Chevy1TonFun
Grease Monkey
No its in the reader's ride section. One step closer to a feature.
Old 05-21-2009, 09:52 AM   #49
Wildstreak
Wildstreak's Avatar
Still something to be proud of!
57 chevy 4x4
68 burb 2wd:
Old 05-21-2009, 10:26 PM   #50
Chevy1TonFun
Grease Monkey
Look what I got today. Its the revised DIY4X First Gen Crossmember. The modified it to allow you to remove the center bar support to allow you to drop your oil pan.
