05-10-2009, 08:00 PM | #26 |
Re: ECE front disk brake/drop kit = wider front end!
Thanks! As for the 3 inches I guess I should have made sure my toe was right before making a comment like that. I still plan on starting a build thread so everyone can see what I’ve done.
05-10-2009, 08:12 PM | #27 |
sharp as a marble
mine did the same thing. Kevin is correct. A cheap fix might be to get a set of spacers made for the rear, and some longer lug studs to move the rear out to match the front? When I did mine I was already aware of this, so it did not bother me as much. I did think about sending the front wheels off and having the off set changed ( rally 6 lug wheels ) but found another set of used wheels that make it almost not noticeable.
05-10-2009, 08:41 PM | #28 | |
BlahBlahBlah
Nice truck...Ill have to leave the tech stuff like this to Tx Firefighter, sounds like he's done more of these than anyone.
05-11-2009, 12:09 AM | #29 |
Here's what the same set up looks like with 8X15X4inchBS (255s) & 10X15X4inch BS (275s).... not that you want to spend more money on wheels
05-11-2009, 04:56 PM | #30 |
i agree with TXfirefighter, put smaller tires... i had the same issue, i went from a 275/60 to a 245/60 and it looks straight with the rear now, considering that i have 295/50 on the rear, if you go with a smaller in the rear like a 275/60 then i would definately look into a 225 or 235 for the front...
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
09-12-2012, 09:06 PM | #31 |
Rather than start a new post I used the search feature to find this old one. I also installed the ECE 3.5 / 5 drop with disc brake conversion on my C-10 longbox and it looks excellent. I am currently running 235/75 15's on all 4 corners because that's what I had when I dropped it. The backs are excellent but the inner fenders bottom out on the tires occasionally over large bumps. Got some questions:
1) is the drop not installed correctly because the front end feels soft and bounces a bunch? The rear end does a tad bit as well. Are these drops supposed to feel so mushy and soft? 2) I want to run 275/60 15's on the back with a 15x8 rim, and I was considering running a 235/70-15 up front on a 15x7 rim. My question is will this be too tall a tire if question 1 above turns out as though the drop is functioning properly? I live out on a country road and don't want to send the tires through the inner fenders, I've seen that happen once before...
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, Monster Transmission 700R4, 3.73 gears Good judgment comes from experience, and experience, well......that comes from bad judgment. 1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then. |
09-13-2012, 07:47 PM | #32 |
I am getting ready to do a slight drop and brake conversion{ece}so this thread has been very helpful,thanks everyone.Looks like I will have 2 275/60/15's for sale.LOL!
09-13-2012, 08:34 PM | #33 | |
67-72 parts collector,…
You need drop shocks, a set of rear shock relocators and an adjustable track bar. Removal or trimming of all 4 bumpstops is also recommended. What about a front end alignment?
09-13-2012, 11:51 PM | #34 |
Drop spindles, springs up front, springs in the back, shock relocator, adjustable bar in the back, lowered shocks on all 4 corners. Also redid the entire front end suspension before the wife realized what I did with the tax return. I did all of this myself, and had a guy align it. Seems a little cushiony for my taste, is the rude supposed to float or did I do something wrong? How about my intended tire sizes?
09-14-2012, 06:18 AM | #35 | |
I have 215/70's and 275/60's on 15x7's and 15x8's. I think your 235/70's up front might be too tall.
