11-16-2009, 01:18 AM | #1 |
60-66 Nut
Re: Lets see your gauge panel!
Basically yes. The GMC gauge panel is longer and I believe narrower that a 64-5-6 Chevy gauge panel. Plus the GMC's still had the switches in the dash below the gauge panel, similar to the '60-'63 Chevy's
In addition to the gauge panel, you will need the wire harness that connects the panel to the connector that is attached to the pedal bracket under the dash. The oil pressure is a mechanical gauge, so you will need to run a line for that. And of course you will need the correct sending unit for the H2O temp. I believe that is all that is needed.
11-16-2009, 05:50 PM | #2 | |
Junior Member
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
05-01-2017, 08:11 AM | #3 |
02-15-2016, 02:23 PM | #4 |
here b my gauges
02-15-2016, 06:59 PM | #5 |
here is mine ... you cant tell in the pic but the paint is metal flake red
02-15-2016, 10:15 PM | #6 |
I'll play...
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
02-16-2016, 03:41 PM | #7 |
02-16-2016, 11:23 PM | #8 |
eBay, I powder coated the stock bezel and the billet panel satin black, thanks.
05-16-2016, 02:28 PM | #9 |
just redid mine
05-16-2016, 02:29 PM | #10 |
sorry forgot photo
02-15-2016, 02:59 PM | #11 |
Moderator
I can play
02-15-2016, 04:10 PM | #12 |
Here's mine ready for the rebuild
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
02-15-2016, 05:03 PM | #13 |
02-15-2016, 05:17 PM | #14 |
Not a good photo but here you go.
02-15-2016, 11:42 PM | #15 |
Not ready yet . . . but a mockup of what it will look like when done. Getting some new tools (dust collector) to help in my machining process, as milling plastic makes it look like a thousand mice took a poop in the garage.
02-16-2016, 08:26 AM | #16 |
I cut "windows" in the Gen and Oil circles to match the shape of the other gauges then RTV glued ebay (70's Jeep I think) gauges to the back side.
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
02-16-2016, 10:35 AM | #17 |
It's Better With Nitro
The instrument cluster for my '63 Poncho C10:
Faceplate milled from sheet aluminum: Bezel painted, faceplate anodized, polycarbonate lens milled and lettering applied:
02-16-2016, 03:59 PM | #18 |
Here is my mini "restoration" - got new gas gauge and new plastic cover. Sanded and resprayed the frame.
Before: After: |
02-17-2016, 09:44 PM | #19 |
02-17-2016, 10:06 PM | #20 |
Still a work in progress.
02-16-2016, 11:44 PM | #21 |
Active Member
I made the aluminum panels myself. The light switch was easily moved under the dash and mounted vertically so it's not visible. I removed the ignition switch since it's not going to stop anyone from stealing these type of trucks anyway. I used real aircraft switch covers painted black with toggle switches in the center. The switches fit it the ashtray & heater control holes.
02-17-2016, 11:37 AM | #22 |
tryin agin
Last edited by harrison56; 02-17-2016 at 11:51 AM. Reason: diot know what I'm doin |
02-17-2016, 04:37 PM | #23 |
Here's mine. Machined out of 6061 aluminum. Painted myself
02-17-2016, 10:43 PM | #24 |
Senior Enthusiast
After a variety of panels that never really satisfied me, I finally had my son machine up an aluminum panel that fit over the steel back panel giving more of the old original GMC look to it. It's suffered many more changes since inception, but those dash panels have remained the same.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
05-16-2016, 09:45 PM | #25 |
my question is, was your original gauge panel, messed up or did all here just want to make it look different, do not get me wrong, I just wondered.
