Old 02-23-2010, 02:30 PM   #26
roadracer9
Retired from a track near you!
roadracer9's Avatar
Re: "All Out Original 72"
Originally Posted by 100gold View Post
Roadracer,
Very nice project you have going on! Are you using original springs?
Also, do you have a pic of the front of your motor? I need a pic showing pulley placement if you can.
Thanks!
I am using the original springs, I blasted , primed, and painted as well, I lost those pics of them being prepared.
I do not have the pulley's on yet, I will in a week or so, sorry. They are simple though, and I have them painted, and ready.
roadracer9 is offline   Reply With Quote
Old 02-23-2010, 02:32 PM   #27
roadracer9
roadracer9's Avatar
Originally Posted by 71blksuper4x4 View Post
looking great, good luck on the project. Trevor
Thanks Trevor! It's been alot of work, totally by myself!
Old 02-23-2010, 02:42 PM   #28
roadracer9
roadracer9's Avatar
Well, here's a rolling chassis, finally! Every maintanance part has been replaced, brgs, seals, ball joints, rotors, calipers, control arm shafts & bushings, new posi rear carrier, every steel brake, & fuel line new, and clearcoated, all rear end bushings, complete park brake system new, and so on, and so on....it's a brand new chassis! Hope you like , I sure am proud!
Old 02-23-2010, 02:49 PM   #29
roadracer9
roadracer9's Avatar
A few more chassis. I hope the Mods/admins are ok with all the pics.
Old 02-23-2010, 02:55 PM   #30
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Roadtacer, something I thought I'd mention.
You should remove the bolts from your upper ball joints and reinstall them the other way, with the nuts on top. The reason is that once you fill the grease boot full of grease and it pooches out, the threaded bolt ends will rub against the boots as they are now when the suspension cycles through it's range.
Most brands of ball joints have a little instruction sheet in there that warns to do it this way. I know it seems wrong, having bolts in upside down, but in this case it is right.
Old 02-23-2010, 02:57 PM   #31
roadracer9
roadracer9's Avatar
Couple more...
Old 02-23-2010, 03:00 PM   #32
roadracer9
roadracer9's Avatar
You are correct sir! I just couldn't do it though, LOL ! It will never see a hundred miles probably.
Old 02-23-2010, 03:02 PM   #33
roadracer9
roadracer9's Avatar
Oh, and I have already greased it, with juuuuust enough not to "Pooch". LOLOL!
Old 02-23-2010, 03:05 PM   #34
Tx Firefighter
So you're building it just to have and keep? Not going to be a driver ?
Old 02-23-2010, 03:17 PM   #35
roadracer9
roadracer9's Avatar
Oh I will drive it, just not as a daily. Some showing, probably sell it later on. Build something else...
Old 02-23-2010, 03:28 PM   #36
roadracer9
roadracer9's Avatar
Transmission before, and after. High heat cleared, etc.
Old 02-23-2010, 03:34 PM   #37
roadracer9
roadracer9's Avatar
The engine building pics were lost as well, D$#%^T ! So here's a few , I don't have many yet, haven't spent much time there yet.
Old 02-23-2010, 03:37 PM   #38
roadracer9
roadracer9's Avatar
Some more engine...
Old 02-23-2010, 04:11 PM   #39
roadracer9
roadracer9's Avatar
How bout some cab action?
Old 02-23-2010, 04:16 PM   #40
msgross
msgross's Avatar
wow, nice build.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-23-2010, 04:19 PM   #41
roadracer9
roadracer9's Avatar
Wet sanded and buffed entire cab, inside, out, and under the floorboard. Dark olive and white. Replaced front cab supports, and rear cab corners. Rocker panels had been replaced already. Cab was sandblasted, all new seamseal, etch primmed, base coat, and six coats clear, PPG materials.
Old 02-23-2010, 04:23 PM   #42
roadracer9
roadracer9's Avatar
Originally Posted by msgross View Post
wow, nice build.
Thank You very much! As most everyone knows.....That's what it's really all about! Just that complement ! At a show, pumping gas, or on a forum such as this.
Old 02-23-2010, 04:28 PM   #43
roadracer9
roadracer9's Avatar
Well let's get it on, get it? LOL
Old 02-23-2010, 04:30 PM   #44
roadracer9
roadracer9's Avatar
Thought this was a cool pic, wish I had it complete in this photo.
Old 02-23-2010, 04:34 PM   #45
roadracer9
roadracer9's Avatar
More cab on the truck...
Old 02-23-2010, 06:19 PM   #46
GREASEMONKEY72
GREASEMONKEY72's Avatar
awesome build, love seeing it go back all original
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-23-2010, 07:41 PM   #47
epashhans
epashhans's Avatar
Just curious...why so many shims on those upper control arms? Is that normal? Mine has maybe 1-3 on my 67 if I remember correctly.
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 02-23-2010, 07:42 PM   #48
epashhans
epashhans's Avatar
OH, and I forgot...very nice build! I can't wait to see more!
Old 02-23-2010, 08:11 PM   #49
roadracer9
roadracer9's Avatar
I added extra shims, so when I have it aligned, they will take shims out, that I have already clear coated, and will not add their un-cleared ones. I want this thing to look this way in 10 years, maybe.
Old 02-23-2010, 08:13 PM   #50
roadracer9
roadracer9's Avatar
Mine also had several shims in it before disassenbly. Thanks, epashhans!
