07-05-2010, 10:34 PM | #26 |
Resistance is Futile
Re: Dual Compressor Wiring
Here's a pic of the project box location.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
07-05-2010, 10:41 PM | #27 |
Happy to be here
I found a nice piece from Scosche today in an area Super Wal-Mart car audio section. It's odd that they had several of these in stock, but the part# doesn't readily come up on the Scosche site.
What the pic doesn't show is the clear cover that comes with it. It is low profile and lets the fuses stick through so they are clearly visible. The Scosche site list it for 24.95, but Wally had it for 9.99. They diagram that comes with the "Fused Distribution Block" recommends the dual fuse block be mounted near the device, with a "High Amperage Wafer Fuse Holder" mounted near the battery.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-05-2010 at 10:47 PM. |
07-05-2010, 10:54 PM | #28 |
Thats the one I used N2TRUX. You can make out Scosche on the block. I should add another up front, too.
07-05-2010, 10:59 PM | #29 |
Happy to be here
After I posted I went back and looked at your again, and realized it was the same one. For point of reference, the distribution block is part # PDM48x2 and the large fuse holder is part# PWFHI
07-05-2010, 11:04 PM | #30 |
low n' slo
thats perfect..one clean wire to the battery. looks like ill be picking one of those up.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
07-05-2010, 11:20 PM | #31 |
why not run the compressors off of one 80 amp relay wired to a pressure switch from the tank? seems like less wiring to me.
07-05-2010, 11:36 PM | #32 |
One motor/compressor could be having a problem and not blow the shared higher amperage fuse. It is always safest to fuse motors separately.
Ray Last edited by raycow; 07-05-2010 at 11:37 PM. |
07-05-2010, 11:43 PM | #33 |
why could you not fuse them individually
07-06-2010, 12:25 AM | #34 |
Individual fuses would be fine. For some reason, I envisioned a single fuse ahead of the relay. That was my mistake.
Ray |
07-06-2010, 09:50 AM | #35 | ||
Happy to be here
From what I have found, a single heavy gauge wire should be fused near the battery, then ran to the distribution block. At the block it is split and fused individually then ran to separate relays. The relays are triggered by a single pressure switch. I am curious if it would cause problems if you ran two pressure switches as well. Anyone have any experience with this?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-06-2010 at 10:29 AM. |
07-06-2010, 10:34 AM | #36 |
AIRBAGPARTS.COM
http://www.avsontheweb.com/home.php?cat=323
http://www.avsontheweb.com/product.p...cat=323&page=1 protrash64- Wiring looks good hidden in the project box. Also, 6awg is not overkill on those AZ comps. They draw a lot of amps and I would actually bump it up to 4awg if I were running them. |
07-06-2010, 11:48 AM | #37 |
Happy to be here
Thanks for dropping in Jason. What do you recommend for the battery post? I am running side posts and didn't want the bulk connectors that Scoshse offers. I was thinking of something simple like the SoundQuest side post extension.
07-06-2010, 02:05 PM | #38 |
67cheby
setting here looking at all this wiring , i opened my desk drawer i have the exact same SCOSCHE fuse block in my top desk drawer..... i knew i saved that for a reason !!!
07-06-2010, 09:27 PM | #39 | |
After thinking about this thread, I remembered that I did not fuse my power wire because I thought I mite add a second battery in the back of the 'burb and routed all the extra wire underneath to keep the extra length.
07-07-2010, 10:16 AM | #40 |
AIRBAGPARTS.COM
A basic extension will work fine. Found one here at work a few months ago that my bro used on his caddy. And that one worked great.
07-14-2010, 11:09 PM | #41 |
Happy to be here
It's been rather hectic lately as I prepared for a local fun run to Galveston last Saturday. With that out of the way I was able to get back to my research. I stumbled across a couple things that really got my attention on the Ride Tech Forum. It was a quote by Britt answering a question about running dual compressors.
He stated "The (E3) LevelPro is designed to run two compressors (the secondary compressor turns on shortly after the primary to lower inrush current). So all you have to do is call the sales guys, purchase a harness, and plug it in." That comment got me to thinking about the amount of amp draw it would take to run two pumps on start up. I felt all along it might be excessive, and this was a viable solution. Granted it helps that I already have the Ride Tech "Big Red" 4 way valves, so it made sense to dig deeper. The Ride Tech site has a LOT of information to cover their extensive line of products, so it took some drilling to find what I needed. I ran across the "Suspension Tech" section and found an "instructions" page. On this page there is a long list of .pdf files that covered a plethora of detailed product info. Under "e3 Compressor Guide" was the answer to my questions- "If using two compressors, an additional harness will attach to the main power harness (part #WIR8162). Attach the blue wire from this harness to the black wire on the second compressor and the second compressor red wire to +12V. • If you are running two compressors you will need an additional harness. • Thomas Compressors (black) will require a 20 amp fuse (each). • Viair Compressor (silver) will require a 30 amp fuse (each). NOTE: The e3 system switched ground on the compressors, the compressors are provided power at all times. Hmm? So the e3 system will eliminate the need for relays at the compressor, AND it turns them on individually to reduce amp draw at start up. I think I have found what I am looking for.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-14-2010 at 11:10 PM. |
07-15-2010, 12:30 AM | #42 |
looks great/expensive
07-15-2010, 08:17 AM | #43 |
I've always wanted to convert my RidePro E1 over to E3. If you go that route, would you be kind enough to take some pics?
And, here's another diagram I found over on S-10 Forum:
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ! My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342 My 2013 Camaro 1LE: https://www.youtube.com/channel/UCxa...wL5d6RnmfdJa1A 86 C10 "Build Thread”: http://67-72chevytrucks.com/vboard/s...d.php?t=668777
07-16-2010, 12:17 AM | #44 |
Laid Lo
Wow N2TRUX, you really got me thinking on this one.
I really like the idea of the compressors kicking on a bit apart to minimize the draw. I'm not about to buy the set up you mentioned (very nice but not in my budget) but it got me thinking about what else someone could do to setup their compressors like that. Does anyone know how you could setup 1 compressor to have a delay off the relay? I've been searching and perhaps my terms are wrong or something but surely someone has thought of this. I'm assuming that I would need some sort of a timer board? Thanks in advance.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
07-16-2010, 06:14 AM | #45 | |
low n' slo
07-16-2010, 09:14 AM | #46 |
I was wondering that too. The only thing I can figure is the wire was meant to go to the guy's stereo power.
07-16-2010, 09:34 AM | #47 | |
07-16-2010, 08:14 PM | #48 | ||
Happy to be here
It's not the cheapest route by any means, but I have multiple reasons for going this way.
07-16-2010, 08:30 PM | #49 |
Happy to be here
Yesterday I took a trip to Best Buy to purchase a 42" monitor for work. While I was there I went by the "Car Audio" section to see what they had. They stock rather limited product from three different manufacturers line. After a bit of comparing price, quality, etc I realized that Rockford Fosgate still holds up well to it's competitors.
Many years ago I competed in car stereo competition and was sponsored by Rockford Fosgate. In a show of loyalty to my roots, I loaded up on the latest RF supplies. Let me point out that their price was cheaper than the other brands available, so that had an impact on my decision too. The first item on the list was a side post battery adapter. I needed a clean way to gain a good power source, and looking at all my options this worked best for my application. For reference, I am posting the RF price compared to the "other" well known brands. Rockford Fosgate #RFDGM $2.81 compare to $7.99 for other brands
07-16-2010, 08:33 PM | #50 |
Happy to be here
I know I will need a length of 4AWG to provide power to the main fuse block, 100 amp relay, and fuse distribution block. I picked this kit to fill those needs.
Rockford Fosgate #RFCK-4 $18.78 compare to $29.99 for other brands
