Old 10-16-2013, 05:36 PM   #26
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Ground strap locations
Originally Posted by SCHRUMGMC View Post
How much is a kit normally running? and so the electrical runs through these Straps?
Board member/vendor VH Coachworks sells a professional quality ground strap kit that is second to none and its not very expensive. There is also instructions on where to place the ground straps. I have one of those kits and wil be installing it very soon.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-11-2014, 02:41 AM   #27
WIDESIDE72
WIDESIDE72's Avatar
Can anyone with a step side tell me where the oem ground strap goes on the bed? I already landed one end on the frame using the location shown at the first of this thread. I suppose the other end goes to a crossmember (i have a step side with wood bed and the floor and cross members are not yet installed)
WIDESIDE72 is offline   Reply With Quote
Old 08-28-2014, 02:49 PM   #28
LockDoc
The Older Generation
LockDoc's Avatar
I am going to bump this back to the top and add a picture of the instrument cluster ground clip location.
LockDoc
Leon
Old 11-26-2015, 06:47 PM   #29
67 Burb
67 Burb's Avatar
Originally Posted by GASoline71 View Post
No they ground the vehicle to make all your elecrtical work properly. No current runs through them. A stated earlier... local parts stores should have grounding straps.
Gary
It's not correct that "No current runs through them." All the current runs through the ground wires. If you were to put an ammeter in the ground side of a circuit, and another in the positive side, and turn on the power, you'd get roughly the same reading on both meters.
Like this:
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 11-26-2015, 06:50 PM   #30
davepl
davepl's Avatar
I bought 2 kits because I had done a lot of powdercoating and wanted to be doubly sure about grounds.
For cosmetic restoration purposes, I used laquer thinner and a bead blaster to "restore" my copper originals.
I wonder if the Corvette shops sell the original copper style still? No aluminum strap is going to impress an NCRS judge...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-26-2015, 07:20 PM   #31
midniteblues
midniteblues's Avatar
[QUOTE=davepl;7390010]I bought 2 kits because I had done a lot of powdercoating and wanted to be doubly sure about grounds.
For cosmetic restoration purposes, I used laquer thinner and a bead blaster to "restore" my orignals.
I did the same cleans them up nice. I also grabbed a few of various sizes from the jy. After cleaning then all I clear coated the strands in hoping they keep there color.
Guys don't forget the proper ground washers are important.
Lock doc good call on that ground most forget it. Mine clips too the choke cable.
Also the ground on the heater blower motor.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-26-2015, 08:59 PM   #32
franken
There's no need to run grounds larger than the low current feed from the battery and alternator. The big cables bolted to the battery carry the large starter current.
franken is offline   Reply With Quote
Old 11-26-2015, 09:29 PM   #33
Metaldoc
Metaldoc's Avatar
Proper grounding through out the body to frame to engine redirects static electricity discharge so it doesn't destroy wheel bearings. Discharge straps to earth ground in the wrong place can kill wheel bearings as well.
Metaldoc is offline   Reply With Quote
Old 04-12-2016, 07:42 AM   #34
chrismoore701
chrismoore701's Avatar
Any other thoughts on grounding a stepside bed?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-12-2016, 09:42 AM   #35
LockDoc
LockDoc's Avatar
One of the perimeter bed bolts, header panel bolts, or rear cross sill bolts should work fine unless there is rust between all of the panels.
LockDoc
Leon
Old 04-12-2016, 10:35 AM   #36
chrismoore701
LockDoc
All fresh painted panels. With clean bolt holes. But no metal to metal between the panels. Thinking of a ground strap between the rear cross member and the frame. Then maybe adding wires between the taillight brackets and the frame
Chris
Old 04-12-2016, 03:14 PM   #37
OregonNed
OregonNed's Avatar
On my fleetside, is it recommended to ground to one of the box cross sills? I didn't really think about that too much when I applied all the POR-15 to them. Might make for an interesting scrape job to get to bare metal on one.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-12-2016, 05:27 PM   #38
mike16
as if too manny isnt enough, you should also ground the distributor to the intake manifold and to the fire wall. if you have aluminum heads, ground them to the intake as well and to the block. Dont rely on head bolts to do it.
this is important enough but if you have a large electronic load, its even more important.
Oh and just for the record.... bonding straps complete the circuit, ground straps discharge static electricity.
mike16 is offline   Reply With Quote
Old 04-12-2016, 06:18 PM   #39
geunther
geunther's Avatar
I don't think they grounded the bed from the factory. Reason was probably because it was not rubber isolated like the cab, radiator support, and engine (mounts). At least, I have never been able to find one looking at factory intact trucks.
I am not saying that it is not a good idea to do so.
geunther is offline   Reply With Quote
Old 04-12-2016, 06:33 PM   #40
chrismoore701
I checked my circuits and found out I had a bad bulb. Replaced them all and did some checking and just ground the rear bed brace to the frame and we are off and running.
Chris
Old 04-12-2016, 08:55 PM   #41
chrismoore701
Why use a braided strap vs a wire? I installed a wire tonight for a test and it worked. I was going to swap it out for a braided strap but I ask why? This is between the rear bed cross member and the frame for the tail lights
Chris
Old 04-12-2016, 11:56 PM   #42
Metaldoc
Metaldoc's Avatar
Braided wire is more flexible and your box is mounted on thin rubber washers. You need to ground the box, I would do both sides of the box.
Old 04-13-2016, 12:26 AM   #43
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Good information here. Thank you.........Turns out mine was missing the strap for the bed rail. Correct me if I'm wrong, but the hole for this in the frame is approx. 13" from the end of the frame.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-13-2016, 05:36 AM   #44
chrismoore701
If flexible is the only reason then I am going to stick with the wire. Why change it?
Chris
Old 04-13-2016, 06:14 AM   #45
BrianG
BrianG's Avatar
Were all of the boxes mounted on rubber washes? Can this be confirmed by anyone? I've seen the pads in maybe one online source. I didn't put them under my bed, maybe I should have.
BrianG is offline   Reply With Quote
Old 04-13-2016, 07:31 AM   #46
chrismoore701
I have them installed on my stepside. I think I got them from Classic Parts of America
Chris
Old 04-13-2016, 10:43 AM   #47
OregonNed
OregonNed's Avatar
Working for a phone company definitely has its perks. They have a multitude of different grounding materials. I'm going to upgrade my grounds to this half inch strap. I can cut to necessary lengths.
Old 04-13-2016, 12:35 PM   #48
RustyBlueTruck
Great Idea! I am going to pay more attention to grounding before I go chasing anymore of the gremlins that live im my electrical system.
Blue 1972 Chevrolet C-10 Camper Special 350ci/Muncie M-20 4-speed
RustyBlueTruck is offline   Reply With Quote
Old 04-13-2016, 12:58 PM   #49
67 Burb
67 Burb's Avatar
We should all do the same. It seems that many of us have got caught in that mindset when chasing an electrical problem until you think you're going nuts, only to find that it was a bad ground all along. Just remember that wiring is not a one-way trip. What goes out must also return.
For example, newer vehicles don't rely on a tail light's housing to provide a ground. A ground wire comes out of the housing and is grounded at another location. If GM had done that back in the 60's we probably wouldn't be having this discussion now.
Bob
Old 04-13-2016, 01:00 PM   #50
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by Lee H View Post
Ground strap kits are a good way to go for restoration purposes. If you just need to make sure you are well grounded use any battery (I perfer black) cable about 12 inches long and run from head or motor mount to the frame, clean contacts of course.
Exactly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
