Old 02-09-2011, 07:13 PM   #26
tmoble
Re: Let See Seats On Your 55-59 Truck
oops, duplicate
tmoble is offline   Reply With Quote
Old 02-09-2011, 07:14 PM   #27
tmoble
looks like he still logs on:
# Last Activity: Today 09:45 AM
Old 02-09-2011, 10:47 PM   #28
entourageguy
Yellow truck club
entourageguy's Avatar
The front seat that was in it before was out of a gm product. The PO said it was out of a lumina. It worked ok but was getting worn out and I wanted a bench seat for the extra person.
I wanted to put my own look to the interior and brighten it up inside. I have a friend that does upholstery.
I don't really have a build page as it looked like this when I bought it. I've changed the suspension, wheels, interior and redid the box with tank under floor.
I'm glad some people like my truck.
You can see where the base sits between the two raised parts on the floor
Name:  seat change 012.jpg
These seats are also available with an arm rest. Some of these had the upholstery glued to the foam making it very hard to recover. Mine had a zip off cover from the factory.
Name:  92 bench with arm rest..jpg
This is what the headliner looks like now
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-09-2011, 11:20 PM   #29
tmoble
"some" like your truck???? what's not to like? I think you've built a killer deal. I'm planning to do that exact same thing with the 3-point seat belts. Did you dye those to match?
Have any info on the rear suspension and install? Pics? Vendor? How is the air ride?
Old 02-10-2011, 09:11 AM   #30
entourageguy
Yellow truck club
seat belts came from here ...
http://www.seatbeltplanet.com/
They were great to deal with. Lots of colours to choose from.
rear suspension is A.R.T was for a 88-98 full size that I bought off ebay.
Works really well.
Name:  truck rear end 004.jpg
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 02-10-2011, 11:43 AM   #31
marks 59
Not to keep pestering but will the seat fit with the tank still in the original spot behind the seat. I've got to say NICE JOB to what you have done as the upholstery really compliments your truck. Thanks again for taking the time to respond, Mark
marks 59 is offline   Reply With Quote
Old 02-10-2011, 11:59 AM   #32
entourageguy
Yellow truck club
I would think it will still work with the tank. The seats that were in it before cleared the tank before I moved it to the frame.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 09-09-2011, 08:31 PM   #33
marks 59
Finally got it done and wanted to say thanks for the ideas. I finally just took a seat from an early 70's and cut out a chunk and welded it back together and even managed to get the brackets and holes to match up. Thanks again
Old 09-09-2011, 11:51 PM   #34
texascowboy593
texascowboy593's Avatar
Excellent two-tone truck! The seat looks good!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 09-10-2011, 12:18 AM   #35
OrrieG
OrrieG's Avatar
looks like it came from the factory..
OrrieG is offline   Reply With Quote
Old 09-10-2011, 10:45 AM   #36
Denee007
Denee007's Avatar
These are my seats out of a Tahoe, 2nd row temporarily installed in my '59 apache. I'm not sure about the front seat height yet, I may have to do some modifications, the drivers part is a little off center to the steering wheel, but tolerable and not noticeable unless you know what you're looking for. I'm pleased with the comfort level and the part you sit on lifts up for access to the underneath the seat for Stuff and access to the master cylinder. I also got the seat belts from the doner~ I hope to make it all work. ; )
Denee007 is offline   Reply With Quote
Old 09-10-2011, 12:05 PM   #37
Speedbumpauto
Speedbumpauto's Avatar
Used the seats from a 99 Silverado with power driver seat. After you cut the rivits and remove the orig. mounting flanges that also raised the seat height in the Silverado, it was easy to fabricate a bracket out of strap and bolt/weld it to the seat. I was able to use the stock front mounting holes on the hump but chose to weld in some rears in the floor pan to get the correct angle. Removing the headrests make the seat backs flush with the rear window opening.
Speedbumpauto is offline   Reply With Quote
Old 12-12-2011, 01:26 PM   #38
55metalmonkey
any updates on your seats? I'm interested in how they turned out and how much space you have between the seats for a center consol
55metalmonkey is offline   Reply With Quote
Old 12-13-2011, 12:55 AM   #39
parkwood
parkwood's Avatar
Wise Guys seat frame covered in leather.....
parkwood is offline   Reply With Quote
Old 12-13-2011, 09:21 AM   #40
Kim57
Kim57's Avatar
That's a nice looking seat.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-13-2011, 01:07 PM   #41
oldcouple
oldcouple's Avatar
My buckets came out of a Olds, or Chevy Venture, flat on the bottom, driver is electric, and need four bolt holes each. Way better than the Pontiac car seat on wood 4x4s that was in it when I got it.
oldcouple is offline   Reply With Quote
Old 12-13-2011, 06:44 PM   #42
hopped up
hopped up's Avatar
Entourageguy nailed it!! Very nice interior!! Seat and headliner finish off a very nice truck. I'm a bench seat kinda guy and don't think buckets or late model seats look right in old trucks. But his bench is done in some nice two tone tuck&roll . Nice
hopped up is offline   Reply With Quote
Old 12-13-2011, 08:59 PM   #43
mknittle
mknittle's Avatar
looks nice! did you do the stitching?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-13-2011, 09:13 PM   #44
parkwood
parkwood's Avatar
I would love to know how to do it but no i didn't, i have a guy who does all the interiors for me...
Old 12-14-2011, 12:06 AM   #45
1956chevtruck
1956chevtruck's Avatar
Here's what I did with mine. Stock bench seat with a new stock Cameo cover from carsinc.com. I like it and it's simple and nice and stock.
Byron
1956chevtruck is offline   Reply With Quote
Old 12-14-2011, 01:39 PM   #46
mknittle
mknittle's Avatar
Looks great.I am teaching myself upholstery There isn't many people around this area that are good at it that are willing to teach. it is a lot of fun though.
Mark
My GMC build.
Old 12-14-2011, 02:11 PM   #47
parkwood
parkwood's Avatar
Hey you're not that far from shingle springs, come down sometime and i'll set you up with the guy who does my upholstery i'm sure he would be willing to show you some stuff and help you out.. he does it as a side job.. His name is Shawn.
Old 12-14-2011, 02:53 PM   #48
Spitshineschwinn
Stock seat in a 59 Apache. I was pleased with the way it turned out.
Spitshineschwinn is offline   Reply With Quote
Old 12-14-2011, 05:39 PM   #49
entourageguy
Yellow truck club
Kim
I like that as well
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 12-14-2011, 09:23 PM   #50
mknittle
mknittle's Avatar
Sounds good, i worked over there a couple times when i was driving a dump truck
When it starts raining i will start sewing more. my machine is as old as my truck but in better shape{ for now}
Mark
My GMC build.
