Old 01-12-2011, 03:07 PM   #26
swamp rat
swamp rat's Avatar
Re: Fuel filler options
Originally Posted by Critter View Post
I've pondered on this as well. I like the taillight idea and especially the marker light idea but it looks pretty cumbersome trying to get the pump nozzle in there. I've never seen it done in person so maybe I am wrong. At this point I am leaning towards grafting in a fuel door. I think everyone I have seen is a square door, I am considering using an 88-98 style truck filler which is round. I think it might go better with the body lines, not sure though...
Heres a random pic for reference.
I have read that if you go to a gas pump that requires the fume nozzle to be compressed to activate the pump handle it can be a pita to fill a side marker light filler.
I have seen a few round doors here on the forum that were from an S-10, thats what i got from the junk yard, that and a 1 1/2" filler neck as they also have a 1" one that i read to stay away from for slow filling reasons.
I have not installed the door yet but hope to soon, you will need to make a tunnel that goes on the inside of the bed and wall to allow for the filler neck to pass at a decent angle but if ya plan it right it will be a pretty small tunnel, you may also want to modify the filler neck to lessen the angle.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-12-2011, 04:00 PM   #27
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
This is what I did for my 67 panel. I don't like the recess for the finger so I decided to go with one from a Plymouth Voyager Van and use a cabe to pop the door open. Here is a link, it's not done yet but it gives you a good idea.
http://www.classicheartbeat.com/panel_12.htm
I will look for better pics. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-12-2011, 04:08 PM   #28
Classic Heartbeat
better pic....
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-12-2011, 04:26 PM   #29
thesledhead
thesledhead's Avatar
Originally Posted by bigblock68 View Post
i like it hidden,mines behind the lh side marker.used a streetrod style and modified for my blazer.
Nice!! what did you use as for the flip out???
Originally Posted by TL's72CHEVYSWB View Post
We installed a late model fuel door in the rear panel.
I used a filler neck cover out of a 80's model blazer to cover the filler neck in the bed.
It looks great. I don't have a pic of that but you'll see the result when you look at the way its used in the blazer.
I am a big fan of moving the tank to the rear. More room in the cab . The interior really opens up behind the bucket seats.
Good Luck
Very nice I like the round doors
Originally Posted by Classic Heartbeat View Post
better pic....
Cool, I think Ill go to the scrapyard this weekend and snoop around for some ideas
thanks guys
thesledhead is offline   Reply With Quote
Old 01-12-2011, 06:11 PM   #30
tinkerdad
I used a Perko filler cap that is vented to the tank for filling and to outside air for running (won't pull a vacuum)
I welded a ¼-20 nut inside my light housing and a fender washer outside. A ¼-20 bolt is my hinge.
The bulb housing was cut out of the lens frame; a back and bushings were welded in place. The bottom is slotted to route wires
This plate was welded in the stake pocket
A 1 ¾” piece of muffler pipe was bent to 90 with one end stretched to 2” to match the filler on my fuel cell. A piece of 1-1/2” muffler pipe was welded in the other end to match my filler neck.
A push/pull cabinet hinge was used to hold it closed and open it.
I’ll need to drop my FCG tank ~1” to keep filling downhill.
I still have some trimming to do and I’ll close up my stake pocket. I’ll also weld my 90 in to keep things from rubbing.
tinkerdad is offline   Reply With Quote
Old 01-12-2011, 07:32 PM   #31
swamp rat
swamp rat's Avatar
Wes that filler cap looks great, maybe i'll think about getting one.
Also per the taillight filler, it does require some trimming of the structural supports so if your going to hual stuff in the bed its something to concider also.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-12-2011, 09:32 PM   #32
pdr510
Junior Member
pdr510's Avatar
Here's mine.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
pdr510 is offline   Reply With Quote
Old 01-12-2011, 09:43 PM   #33
Classic Heartbeat
Thank you.. It came to me when I was scouting wrecking yards for ideas... That was when I had time to go to them.. I think that it fits the bill perfectly. Not too large, not too small... and best of all no finger groove. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-12-2011, 10:38 PM   #34
Big-Blue
Big-Blue's Avatar
Has anyone seen one in the top of the bed rail?
Big-Blue is offline   Reply With Quote
Old 01-13-2011, 12:46 AM   #35
Critter
Future TOTM Winner
Critter's Avatar
There was a blue fleetside on the board with that setup. The owner used a stainless boat flush mount filler cap if I remember correctly. It looked real nice! I can't remember whose it was but I'm sure someone will chime in.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-13-2011, 08:50 AM   #36
71sierragrande
Petroleum User
71sierragrande's Avatar
You read my mind. That seems to make the most sense.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 01-13-2011, 10:30 AM   #37
Chris4x4Gill2
pdr510 ...... do you have any more pictures of your setup? That is the method I have been considering for mine as well.
Chris4x4Gill2 is offline   Reply With Quote
Old 01-13-2011, 10:33 AM   #38
Chris4x4Gill2
There are several guys on here that have the filler in the top of the bed rail, I can not remmber their screen names though. Here are a few pics i have saved on my computer from someone on the forum, I'm sure someone will recognize the truck.
::: again, these are not my pics so I dont have any information on the setup. I just saved them while researching for my own setup:::::
Old 01-13-2011, 10:48 AM   #39
HuggerCST
HuggerCST's Avatar
Nice work tinkerdad, yours is alot like mine. I think it was John Fabris that made the nice stake pocket filler. For a hidden filler, I like the side marker light option too, but I think if I went that route, I would use the Hagen cap that doesn't require it to be removed to fill your tank. Here is mine.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-13-2011, 01:58 PM   #40
tinkerdad
Thanks HuggerCST, I read your thread several times before starting. I hope my finished project looks as nice as yours.
Old 01-13-2011, 04:43 PM   #41
thesledhead
those both look sweet!
Old 01-13-2011, 05:03 PM   #42
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Huggercst and tinkerdad, those both look great and look to be very functional. One question though, what holds the light in the "up" position, and how do you lower it when you want to fill up?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-13-2011, 05:28 PM   #43
HuggerCST
HuggerCST's Avatar
Mine has a spring attached to the side of the leans backing plate. That spring is mounted at an angle so that it cams over and holds it open, or closed. I simply push on the bottom of the lens to open it.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-13-2011, 07:32 PM   #44
tinkerdad
Mine has a magnetic cabinet latch in the upper right hand corner. When you push on the top it pops out. You can then pull it down.
Old 01-13-2011, 07:58 PM   #45
69step4x4
69step4x4's Avatar
Originally Posted by dixietruck71 View Post
i have a buddy that hinged the left rear marker lite and had the filler in that hole. it worked awesome. thats what im in the process of cathering parts for now. i will post pics of it during the process. since he has sold the truck and i cannot get pics of it.
this is mine on my stepside, but truck is painted now
Lowered 2002 PT Cruiser ONLY for mileage.
1969 Stepside 4x4 ( under construction )
69step4x4 is offline   Reply With Quote
Old 01-14-2011, 02:02 AM   #46
Jacfourteen
Oops trying to figure out the Multiqoute thing, I figured it out below.
Old 01-14-2011, 02:05 AM   #47
Jacfourteen
Thanks for the replies.
That is a slick idea, I would have never thought of it.
This is what came to my mind when I was trying to figure it out, seems like it would work well.
Old 01-14-2011, 12:59 PM   #48
swamp rat
swamp rat's Avatar
One comment or concern that was brought up in a different thread that i was reading that i have not seen here is that some folks have been a bit concerned about the possibility of sparks, bad wire or connection and gas fumes after filling. I cant speak first hand of this but thought at least you should be aware of it if you do a light filler mod be it ether tail light or rear marker..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-14-2011, 01:25 PM   #49
Slick67
Sofa King Crazy!!
Slick67's Avatar
Not as nice as some on here, but still effective and out of the way. This is before it was bolted down.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 01-14-2011, 01:47 PM   #50
502ss
502ss's Avatar
Yeah I thought about that too. Mixing electrical and gas fumes could end badly. I plan to convert the tail lights to led and because the light will be hinged the harness will need to be redone anyway so all connections will be soldered and all wires will be incased in an abrasive resistant jacket. There will be a plug where the new harness connects into the existing harness but this plug will be located under the truck far away from the filler neck.
It doesn't hurt to take the extra steps to avoid a possible issue!
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
