#26 |
![]() Join Date: Mar 2003
Re: How much does it weigh?
My 68 GMC with a big block and a lumber rack weighs in at around 4500
#27 |
Thought I would add to this since I ran mine over the scales last month.
71 K20 LWB is 5200# Mine has a BB, twin saddle tanks (empty at time), 1 ton axles with HD sway bars, 4" spring lift, dual shocks all around and steelies no AC or radio equipment. Pretty light imho, compared to my Benz and 4Runner it's down right scrawny. 2nd gen 4Runners curb around 5800# same as the 560 SEL and my Runner is around 6500# geared out.
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
#28 |
My 72 Chevy with a built 327 and a turbo 350 weighs in at 4624#
"Repetition penetrates even the dullest of minds" |
#29 |
![]() Join Date: Dec 2006
I think those weights in the Data Book are for standard trucks without options or add-ons. Six cylinder 3 speed etc.
AC, Power steering and brakes, V-8 or big block, 4spd etc. adds weight. My '69 GMC weighed 4680 (when I bought it in '98) on the scale empty but it has saddle tanks, dealer AC (?), wood bed, rear step bumper, etc. (The GMC equivalent of a Long Horn also).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#30 |
Vintage 4x4s
Where are you getting those numbers? that seemed awfully high so I googled them and they are both 3600 to 4000 lbs curb weight.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#31 |
I stand corrected. Could've sworn I got the 4Runner weight off of Edmunds and estimated geared weight from what I've put in it, but looking now and you are correct. Now I've got to go and weigh them both out to fix my mind. The Benz weight I got off the title and will have to check that too.
#32 |
![]() Join Date: Apr 2015
My K20 4x4 Cheyenne Super Custom Camper with weight adding options include a/c, heavy duty camper springs and Eagle alloy wheels + 285/75/16 and 1/4 tank of gas weighted at 4800 pounds! With me and the rubber bed mat in it was over 5000, so I removed the mat and me. For California DMV weight fees under 5k is much cheaper.
I hope this helps someone. [IMG] ![]() |
#33 |
My 1970 C10 weighed 4,010 (after subtracting my own bodyweight) according to the scales at the local landfill last time - it has: Long Bed, HD springs, SB350/TH350, front stabilizer and power steering and original steel wheels, regular chrome bumpers and no bed mat but sacrificial 3/8ths plywood. Factory A/C but that entire system is removed at the moment.
Fleetside and steel floor.. |
#34 |
![]() Join Date: Oct 2011
My 'real deal' numbers on my C10, 8ft. fleets were in keeping with the measured scale numbers here.....ie: all over 4000 lbs.
My last C10, 8ft bed (Cheyenne Super), with 350, a/c, ps, pb...& without me in it was around 4100 lbs on the scale. The numbers listed for weights in a lot of GM literature are absolutely bare bones, stripped weights...often with a 6 cylinder, no options and no rear bumper...so do not use these as the number for you truck. Simple...take it over the scale and weigh it. If you have one of the freeway where you live, just go over there when they are closed and check it out...easy peasy. I'd love someone to post up a 3800# measured scale weight....I've never seen one of those despite the literature. That said, you can count on that C20 being (at least) 4500 lbs if it has a V8, ps, pb and a rear bumper.....and thats probably without you in it. Important operational note: If you have spare fuel tanks you can always fill them with Helium in order to reduce your road weight. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#35 | |
#36 |
Hey guys does anyone know how much the bed itself off a long bed weighs? Going to pick one up for my truck but was wondering if we could just load it up on my buddys truck without a flatbed trailer...my truck isn't running or I would take off the old one and just bolt up the new one.
#37 | |
#38 |
![]() Join Date: Feb 2009
Heavy enough my floor jack told me it stands replacement. It was used to lifting the front of a C10.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#39 | |
#40 | |
#41 |
...just back from dropping off a load full of scrap/rotted wood at the dump (careully packed of course...lol)....so I have another truck weight reference for those interested:
The weight of my truck via the weigh scale there was 4180 lbs. (without people/passengers- truck only) The truck is equipped as follows: '72, C10, 1/2 ton 8' long bed w/ trailing arm suspension (not leafs) Relatively complete option group (ps / pb / a/c, radio, gauges, deluxe trim, etc) 350 / auto / h.duty rad / chrome rear bumper w/ hidden tow hitch. std. tires (235-15") (w/ full spare tire on board) Fuel load: less than 1/2 ....so for sure, easily north of 2 tons..and that is an empty 1/2 ton. All good Coley
#42 |
That's gross... my 70 Longhorn scales around 4250 I think. That's what my lift says, and while it says "+/- 2%" I don't know if it's really within 2 percent or not...
#43 |
6>8 Plugless........
![]() Join Date: Sep 2007
My 72 Longhorn is 6450 with about 8 gallons of fuel before my aftermarket bumpers. That is with 3/4 boxed frame, all 1/4" wall cross members, a Cummins, and D60/D80 axles. I figured it would be higher than that when I was building it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#44 |
My '68 C-10 seems to weigh more at the gravel pit than it does at the County dump. I think someone's got their thumb on the scales...
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#45 | |
![]() Quote:
If you get a chance take it over a community scale or thereabouts...I think you are going to pick up 500 lbs in a hurry for a 3/4 ton Longhorn. all good Coley
#46 |
interesting thread, I am always interested in the weight of a vehicle and how it effects performance and fuel economy. I still havn't driven my truck yet and was wondering how it would do with the 350 that is in it. looks like about 5000 lbs for a K20 probably be not too bad.
#47 |
Post Whore
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#48 |
I weighed my 67 SWB when I got out of the Army in 2013 - had to weigh it empty and loaded for my self move. 283/manual brakes, no AC, no pS, buddy buckets: 3660 pounds with a 1/2 tank of gas.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
