Old 03-07-2011, 11:16 PM   #26
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Ultimate work truck/ 70 K10 diesel
SWEEEEETTT!! I love 6.5s!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-09-2011, 05:38 PM   #27
woodwright
Enjoying left field
woodwright's Avatar
I've been asking around on a few different boards about how the gauge clusters work in the newer, 88-98 trucks. I would like to do a dash similar to this, but use a 95-? cluster as the back.
Its sounding doable. I found a 96 diesel cluster from a guy here for $50.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-10-2011, 12:13 PM   #28
woodwright
Enjoying left field
woodwright's Avatar
I got started on my rear mounts. I made them out of the same 3 1/2" square tube that I made the fronts. The rearend is 40" between spring perch centers, so I used some scrap flat bar, and made a jig that holds the mounts level and the right width apart. That way I can square and level the whole thing as one unit.
Once I got them clamped where I wanted them, I started building the hangers.
I still need to make a few more braces, and final weld everything, and I want to take a few more measurements so the truck doesn't crab walk on me.
Clint
Old 03-10-2011, 12:57 PM   #29
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 03-10-2011, 07:59 PM   #30
onebadbowtie
onebadbowtie's Avatar
killer fab work!
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 03-15-2011, 02:36 AM   #31
woodwright
Enjoying left field
woodwright's Avatar
I got my rear shackle mounts built this weekend. I got a little picture happy so bear with me First I cut and squared 2 pieces of 1 1/2" sch 80 for the hangars. I laid them in a piece of angle iron to keep them straight, and welded a smaller piece of tube inside them to keep them there.
I cut two pieces of 3"x3"x1/4" for the mounts 6" long and bolted them on the frame. Then I tacked the tube with the shackle mounts up where it needed to go.
Then I started tacking the support braces on.
Once I got the 2 supports on and everything was stable, I was able to take the jig apart, and finish weld everything.
I think they turned out pretty good
Clint
Old 03-15-2011, 02:38 AM   #32
MrBeast
high-Tech Red Neck
MrBeast's Avatar
hell yeah man, nice work! I like your meathod.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-25-2011, 12:21 PM   #33
propanemudtruck
updates?
-Kevin
Old 03-27-2011, 02:15 PM   #34
woodwright
Enjoying left field
woodwright's Avatar
I have made some progress, but the wife had a class in seattle and she took the computer. If she gets home early enough tonight I'll. Post up some more pics.
Clint
Old 03-27-2011, 09:40 PM   #35
70 beast
Certified Hobbiest
70 beast's Avatar
Id say thats some damn good fab skills.
very cool step by step pictures
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 03-27-2011, 11:35 PM   #36
woodwright
Enjoying left field
woodwright's Avatar
I got my rear springs rebushed and mounted.
I set the frame down on my old running gear, and the motor and tranny in place and threw the cab and fenders on.
the tires are 245/70-16. I think with 33"s it'll look good.
Clint
Old 03-28-2011, 12:09 AM   #37
woodwright
Enjoying left field
woodwright's Avatar
Got a new little wrinkle. I found out the other day that the flywheels for the 6.2's and the 6.5's are different. My flywheel and clutch is from a 6.2. So now I'm on the hunt for another flywheel.
Clint
Old 03-28-2011, 02:40 AM   #38
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Advance auto might be able to get you one, they were the only place I could find that could get me a flywheel for my 6.5 when I was running it.
Of course you know you if you cant find a flywheel, you can always find a Cummins!
Old 04-04-2011, 12:55 AM   #39
woodwright
Enjoying left field
woodwright's Avatar
I pushed the truck out again to make room for my parts truck so I could pull my 6.5 out. The driveway's a little muddy so I hooked onto it with our durango and had the wife pull it out of the way. I remembered too late that the axles weren't bolted to the springs.
I dragged my cherry picker out in the mud and got everything back where it was supposed to be. So far, I haven't found any damage except my ego.
Clint
Old 04-04-2011, 01:20 AM   #40
dmartin1
dmartin1's Avatar
LOL its ok i drove my truck not too long ago without tightening the 2 lug nuts that were on(8 lug truck) and the driver rear wheel fell off.glad to see im not the only nuts one out there haha.jkk
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-04-2011, 05:30 AM   #41
propanemudtruck
Oh boy that could have been much worse! Good to see it's gonna be ok.
-Kevin
Old 04-15-2011, 10:14 AM   #42
my4by2
my4by2's Avatar
Look forward to seeing sitting back up on the axles man.....
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-18-2011, 03:20 AM   #43
woodwright
Enjoying left field
woodwright's Avatar
Work has kept me either busy, or exhausted, but I finally got my 6.5 out of my 93. By far the biggest pain in the ass to get that out.
I built a platform to reach the back of the motor. works good if you need to be that way for a while.
Now I just need to figure out which sensors and wires I need, and then I can get the 93 out of here. Anybody know if you can convert the newer style ac pumps to an on board air compressor? I also need a layout of the wiring and sensors for a 93 K2500.
Clint
Old 04-18-2011, 12:11 PM   #44
jbclassix
Junk Yartist
jbclassix's Avatar
Head in this direction... They helped me out a lot with my 6.5L
ssdieselsupply.com
-Jeremy
Rebuilding an NP205
Old 05-05-2011, 01:37 AM   #45
woodwright
Enjoying left field
woodwright's Avatar
Makin progress slowly. I'm trying to get the frame finished so I can clean and paint it. I needed to clearance a couple of crossmembers for the 4" exhaust, and patch a few holes. I'll post some pics soon.
Clint
Old 05-11-2011, 03:45 AM   #46
DBear
DBear's Avatar
what are those 16inch steel rims off of? they are 6 lug I see.....I have been looking some of those but dont know what years or models to look for...btw, nice build. I am about done with my 6.2 swap into my 71 burb!
DBear is offline   Reply With Quote
Old 05-13-2011, 02:00 PM   #47
woodwright
Enjoying left field
woodwright's Avatar
I'm pretty sure they are the stock rims that came on my 70 k10. Do you want them? I'm not gonna use them.
Clint
Old 05-13-2011, 02:32 PM   #48
DBear
DBear's Avatar
Yes sir....I do want them. Send me ur number bud. Thanks. Tommy
Old 05-21-2011, 01:01 PM   #49
Average Joe
Average Joe's Avatar
Sweet build!!! I will be following along with great interest.
Average Joe is offline   Reply With Quote
Old 05-29-2011, 11:49 PM   #50
woodwright
Enjoying left field
woodwright's Avatar
Finally got the frame done,cleaned, and started painting. I'm useing napas version of por-15.
A while back I borrowed a 33" and bolted it on to see how it looked.
I'm gonna have to run 35's I think. While the frame was upside down I built my rear shockmount crossmember.
I'll get some pics soon of the painted frame.
Clint
