Old 04-10-2011, 12:54 PM   #26
rideharder
Re: road less traveled
Not yet. Waiting on parts.. Painting my cab soon then onto interior and hangin\painting panels
rideharder is offline   Reply With Quote
Old 06-12-2011, 10:43 PM   #27
cumminschevy
I am also doing this build. And i would also like to know what intercooler that is. it looks like a stock 94-98 dodge cooler??? The guy who did his sub had a banks kit and his cooler looked similar but upside down. p.s. very nice build
cumminschevy is offline   Reply With Quote
Old 06-12-2011, 11:07 PM   #28
rideharder
Ya stock ic but yes upside down
Old 09-28-2011, 09:55 PM   #29
rideharder
well kinda forgot about my loyal followers lol, update time
first time moving under its own power
dont mock the milk crates
http://www.facebook.com/video/video.php?v=1806164693340
hope u like it... cabs in the paint booth with my fender and hood.
Old 09-29-2011, 02:16 AM   #30
VA72C10
VA72C10
VA72C10's Avatar
Nice
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-29-2011, 03:35 AM   #31
vivid2012
that's so cool, I have to say.
vivid2012 is offline   Reply With Quote
Old 09-29-2011, 10:22 AM   #32
67cheby
67cheby
67cheby's Avatar
WOW...too cool more updates!!
67cheby is offline   Reply With Quote
Old 09-29-2011, 12:22 PM   #33
Ackattack
Ackattack's Avatar
Are you still going to be able to run the stock hood latch with the IC?
Are you going to run A/C. My understanding is stock cummins AC compressor gets into the frame rail.
I'm looking to do a cummins suburban, but my thought right now is to use the 3/4ton 4x4 dodge frame with the 'burb body to avoid the compressor interference issue.
Ackattack is offline   Reply With Quote
Old 09-29-2011, 01:44 PM   #34
heeroyue2002
fat old dude
heeroyue2002's Avatar
looks great
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-30-2011, 05:43 PM   #35
rideharder
no factory air in this rig, don't even have the factory heater lol running my dads left over 55 heater box. But ya the compressor is in the frame rail if I were to use it. If I really wanted a/c idhook up a winch motor to a compressr and and mount it else where.... My goal for my airbag air supply at least
Old 03-06-2012, 12:07 PM   #36
68GenIII
Any undates? What is that rack out of? Im working on this same conversion, Im trying to get the motor as far back and low as possible but its getting in the way of the steering. How is the bump steer? Thanks.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 05-06-2012, 10:38 PM   #37
rideharder
Rack is from a dodge Dakota 2gen 2wd I believe.
Old 05-06-2012, 11:16 PM   #38
Tinkermc
nice looking job so far would like to see pic of console not that you finished mock-up . Would also ask why just 1 cup holder, do you always travel alone?
Tinkermc is offline   Reply With Quote
Old 05-06-2012, 11:41 PM   #39
67c10rustbuket
67c10rustbuket's Avatar
Cool, crazy! I dig it.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-11-2012, 02:00 PM   #40
rideharder
Well turns out I haunt updated for a while, well here's my progress..
Shiny front
12" shorter and siting on bags- decided to go swb and didn't want to cut up the frame... So I shortened the trailing arms and will cut 20" off the rear of the frame
Old 07-14-2012, 01:03 AM   #41
67c10rustbuket
Nice job on welding/shortening the bed. I always wondered how the rear section fit because it seems to taper down on the upper body line. May just be an illusion,or maybe I am crazy. I am concerned that your new bed floor may not be safe for transporting brew, seems a little shallow. Looks like you need a huge notch now! What are the two sections in the front of the bed for with no floor?
Looks sweet!
Dan <---(my name)
Old 07-14-2012, 09:20 AM   #42
bigguy69
dazed and confused
bigguy69's Avatar
Wow
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 07-14-2012, 12:40 PM   #43
rideharder
Looks sweet!
2dry storage boxes and the rear is a open tailgate to access dry storage out back.. A big notch isn't going to happen I can't go any lower than that with the Cummins up front
Old 07-14-2012, 12:44 PM   #44
shok
Do you have more details on what you did to get the rack and pinion steering in there?
shok is offline   Reply With Quote
Old 07-14-2012, 04:20 PM   #45
rideharder
What do ya need to know. I held it in place seen how I needed to mount it. Welded plate and bolts to the members member
Old 07-15-2012, 02:10 AM   #46
shok
Well now you make it sound so simple
Any specifics on what you bought/made to get it connected to the column, which tierod ends etc? Is it connected to a stock gm pump?
Old 07-17-2012, 02:38 AM   #47
rideharder
Stock dodge pump, Dakota pressure line, Dakota r&p, Chevrolet trans cooller back to the pump.
I looked though a catalog to find a ball& socket inner tie rod end that had the right lenth and thread and 3/4" hems on the knuckles.. I filled in the ball joint taper and drilled and taped it for 3/4" fine and put the heim on the bottom and nut on top. I'll take more pics tomorrow if ya want
Oh ya and for my column I shortened it 4" I believe? Pushed the bell of the columb to my gauge cluster and ground the end of the steering shaft square and used a ford super duty intermediat shaft between my r&p and column. The mid shaft uses u joints instead of the rag joint they had stock.
