Old 05-08-2011, 08:59 PM   #26
prostreetc10
prostreetc10's Avatar
Re: my 86 prostreet c10
love the look of the raised wood floor, but kinda was wanting to show off those big wheel tubs. i think it part of the prostreet look. but i do agree, there is alot going on back there
prostreetc10 is offline   Reply With Quote
Old 05-08-2011, 10:34 PM   #27
85/05Silverado
85/05Silverado's Avatar
nice truck man it looks awesome love the prostreet looks of a truck and i really like the dual intake tubes i was looking to get some for my truck,
keep up the good work
Hows it goin Eh!
1985 Chevrolet C10 Silverado SWB-395 Stroker 490hp,700R4 12 bolt 3:73 posi,inferno red crystal pearl coat with black ralleystripes,custom leather seats, carbon fiber gauges
2005 silverado 1500 ecsb, Z71, 33x12.5 dick cepek
http://www.cardomain.com/id/Kearney
Stephen
85/05Silverado is offline   Reply With Quote
Old 05-09-2011, 09:48 PM   #28
mooseknuckles
mooseknuckles's Avatar
ya but you could hinge it and show it off that way?
mooseknuckles is offline   Reply With Quote
Old 05-10-2011, 02:53 AM   #29
prostreetc10
that does give me somthing to think about, because it could also be a bed cover in a way.
Old 05-10-2011, 09:27 AM   #30
spudz
spudz's Avatar
Bed cover is nice and all for a 4 linked bagged truck or something... But prostreet you GOTTA SEE THE TUBS and cell.....
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 05-10-2011, 01:48 PM   #31
prostreetc10
dont like the idear of a bed cover ether, but right now it sits out in the weather, and with the sun shining on the cell really heats the gas up. and when it rains i dont know if water gets into the fuel. i put a piece ply wood on the cell to keep the water off of it, but that is starting to be a headache.
Old 05-14-2011, 11:06 AM   #32
BoredJoe
I recently bought those same seats to put in mine but they arnt fitting just right, they sit alittle high andtIe mounts hang over the ''hump'' in the floorboard. What did you end up doing to make them fit as good as they do? Thanks
BoredJoe is offline   Reply With Quote
Old 05-14-2011, 11:12 PM   #33
prostreetc10
i built a box out of 1'' angle for it to sit in. first the seat slider had to go. so it is custom fit to my height. then i had to cut the seat brackets to get it to the right height in the truck. and the mounting points are welded to the 1'' angle. i will take some close up pics.
Old 05-15-2011, 02:14 PM   #34
prostreetc10
hope this helps
Old 05-15-2011, 02:15 PM   #35
prostreetc10
here a pic of the hole seat
Old 05-16-2011, 01:43 AM   #36
BoredJoe
Thanks for the close ups that helps a lot. THe seats I have had electric adjustments, did yours have that? RIght now I have the bottom pad you sit on and the back pad seperated because I figured I would have to ditch the electric part (makes the seats to high) which is what held the two together. Now I'm trying to figure out how to build a bracket to hold them like a complete seat if you know what I mean lol. Once I figure that out I was thinking about using the old sliders from the bench seat and somehow connecting the bucket seats and console to it. Does yours have any adjustments with the way you have it, like forward or backwards? Love the way they look can't wait to get mine in, and thanks for the help. Love your truck btw.
Old 05-16-2011, 01:40 PM   #37
prostreetc10
there is no adjustment. i just mounted them to fit my hieght. besides nobody else drives it but me,lol. what i did was took the adjusters off of the seats and welded them to the frame i built. then i cut the legs down on the center console, to fit the hieght of the seats. and one more thing, had to modify the floor to make the frame sit flush. drew up a sketch to give you an idear on the frame i built. hope it helps
Old 05-16-2011, 03:26 PM   #38
BoredJoe
Ok thanks man they look good. I'm hoping I can make mine adjustable but like you said I'm the only one driving my truck to. What did you do as far as leaning the seats forward and backwards or can you not access behind them now. I kinda want to put a speaker box behind mine so I'm hoping I can get em to lean. If I cant come up with a way to make them slide I'm doing it like yours. Also I was wondering how hard it was to weld the center console legs, there alittle thin did that make it hard?
Old 05-16-2011, 08:39 PM   #39
CoggedBelt75
CoggedBelt75's Avatar
Your truck is looking great!!! What is the present color called and what are you planning on changing it to? The raised wood bed idea would look good too. Maybe just below flush with the cell? Then it and the tubs would still be exposed.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 05-17-2011, 12:32 PM   #40
prostreetc10
mine still can recline, the only thing i done was un bolted the factory sliders. to get the hieght i wanted. it wasnt hard to weld the center console, i used a lincoln 110 wire feeder. those welders can weld some thin stuff. i also took the side cover off the drive seat to get pics of the side.
Old 05-17-2011, 12:46 PM   #41
prostreetc10
the color is torch red. although my camera cant seem to get it right. it will go back the same color. i was thinking the same thing, its best of both worlds. can get the fuel cell out of the weather and still show off the tubs. and by the way, your truck looks great to, love the blower set up. cant go wrong with eye candy.
Old 05-17-2011, 01:32 PM   #42
BoredJoe
Thanks those last side pictures of the seat helped a lot, thank you for taking the time to take them. Now I gotta find time to get started on mine.
Old 01-29-2014, 11:45 PM   #43
Lv84c10
What length rear end re you using ?
Lv84c10 is offline   Reply With Quote
Old 01-29-2014, 11:46 PM   #44
Lv84c10
What length rear end are you using ?
Old 01-29-2014, 11:58 PM   #45
mud.man.rj
mud.man.rj's Avatar
Welcome to the site, that sure is a nice truck, front to back, not much of a box left anymore but sure you will think of something interesting. Love the rear tire size, mean machine. How does it ride with that much tire.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
