Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer > projects and builds
Old 09-14-2012, 06:20 PM   #26
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Current S10 build project 350 swap and 4" bodydrop
You do good work.
The S10 area doesn't see many visitors here on this board.
Keep at it!
Keith
Convert to disc brakes.
Old 09-15-2012, 01:23 AM   #27
likaroc13
Rollin' Old Skool
nice progress! I like that '51 as well...yeah, this part of the forum is pretty slow...i check in from time to time to see if anything is new...keep up the good work
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-22-2013, 10:27 AM   #28
98layinframe
98layinframe's Avatar
Actually worked on this thing a bit. Got all new brake and 3 fuel lines ran out back. Lucky my buddy owns the fancy expensive tool that makes all the crazy gm fuel line flares.
Got the firewall all welded up and started to smooth the welds.
Hooked up a rear brake line, it runs down the link bar for a clean look and cause of the needed travel range.
And laztly pics aird up and laid out.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 01-22-2013, 10:38 AM   #29
98layinframe
Aird out.
Also the vette sitting in the back ground... I bought to strip down and use motor tranny and all front and rear suspension under the 1951 AD truck.
Old 01-22-2013, 01:28 PM   #30
Indian113
Indian113's Avatar
Lookin Good! I like your idea on the 51 too.
Indian113 is offline   Reply With Quote
Old 01-22-2013, 01:29 PM   #31
likaroc13
Rollin' Old Skool
looking good! just sold my '93 S-10 & moving back to a fullsize (Tahoe), but I'll keep checking in with ya
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-08-2013, 02:27 AM   #32
76C10Stepside
76C10Stepside's Avatar
Dang, just read through this thread for the first time. You have some great skills!
When do you expect to have it back together?
76C10Stepside is offline   Reply With Quote
Old 04-11-2013, 10:55 AM   #33
98layinframe
I'm really shooting for this summer... i wanna drive this thing!!
I'm horrible at taking pictures while working but progress is being made.
Cabs back on along with front sheet metal
started working on a homemade sheetmetal intake to clear the hood
driveshaft installed (shortened, rebalanced, new u joints),
crazy 4" tall driveshaft tunnel bent up and welded in,
the notches in the back cab wall also bent up and welded in
rad support was cut out in the center and radiator flushed in
dual 12" electric fans bought , working on making a shroud for them
Exhaust started with a bunch of prebent mandrel sections (Xpipe under tranny tail shaft, flowmaster 40's then dumped out in front of the rear wheels.)
Picked up a set of camaro seats, cutting tracks to sit as low as possible
I think thats the mentionable stuff for now..
Old 04-11-2013, 11:02 AM   #34
98layinframe
Also been working with my buddy on his truck. Setup to lay on 22's, 3" body drop, fully built 6.0 lsx v8. Should be fun when its drivable. If ya look at the driverside front tire can see how close the tires sit to the outer skin... the real 22's will probably touch the skin due to camber and wider tires.
Old 04-20-2015, 09:29 AM   #35
tommys72
tommys72's Avatar
What I can see looks good man, a lot of the pics are gone though
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
