Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-22-2011, 07:40 PM   #26
kpeztruck
kpeztruck's Avatar
Re: cage question
Mine was certified to 8.50 without the connectors to the frame, but would not certify to 7.50 without it. Again, as stated by others, an NHRA/SFI spec manual will be your best friend, followed closely by someone that has had to deal with the person that performs the inspections, and certifies the chassis. You really want to have everything in order, before going to have certified, and by all means, don't argue with the chassis cert guy. Just ask questions and comply, as he will be most likely the only person in your area, and NHRA does not care! I will try to post the photos soon, I have to get over to the shop to take some. Paul Baxter
kpeztruck is offline   Reply With Quote
Old 12-22-2011, 11:31 PM   #27
prostreet1967
prostreet1967's Avatar
Re: cage question
cool appreciate it
prostreet1967 is offline   Reply With Quote
Old 12-23-2011, 05:26 PM   #28
raceman6135
Dino burner
raceman6135's Avatar
Re: cage question
Further to Paul's excellent points, don't be afraid to contact your division's Tech Director during the build, and e-mail photos to him/her with questions.
Be polite and respectful of their time, and you'll find that they're quite helpful. After all, they are just trying to make things safe for everyone.
raceman6135 is offline   Reply With Quote
Old 01-04-2012, 11:18 PM   #29
kpeztruck
kpeztruck's Avatar
Re: cage question
Originally Posted by bcdeutsch731 View Post
I would like to see that if you could get some pictures.
Brett
Here are some long awaited photos of my cage work. Don't hate on me for paint wearing thin on my cage in places. I had no idea the paint looked that bad, until I looked at the photos. Looks like I have some touch up to do come spring.
The first photo is self explanatory, but you can see the 2x3 sank into the floor just inside of the rocker.
The second photo just shows that the cage goes through the dash, and the 2x3 extends far enough forward to connect the front of the cage to.
The third shows the 2x3 just under the carpet, with weld beads to the floor.
The fourth shows the 2x3 from under the truck, here you can see it set into the cross cab braces, and the forward round tube that connects the 2x3 to the outside of the frame, even with the trans crossmember.
Finally the fifth shows the round tube that connects the inside of the frame together at the rear of thw cab.
Please note: the trans crossmember is able to be bolted in, and considered part of the structure, connecting the frame together at the front. I hope this is helpfull.
Paul
Old 01-05-2012, 01:01 AM   #30
Super73
Super73's Avatar
Re: cage question
Paul,
I am assuming the 2x4 allowed you to remove the bar that normally runs from the main hoop to the bottom of the A-pillar? It does open the bottom up a bit.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-05-2012, 11:39 AM   #31
vin63
It's Better With Nitro
vin63's Avatar
Re: cage question
Originally Posted by kpeztruck View Post
Here are some long awaited photos of my cage work. Don't hate on me for paint wearing thin on my cage in places. I had no idea the paint looked that bad, until I looked at the photos. Looks like I have some touch up to do come spring...
Paul
If it helps, This is what I did...I fabricated a couple of door bar guards from sheet aluminum. I also got tired of touching up the paint in the same area.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-05-2012, 05:32 PM   #32
kpeztruck
kpeztruck's Avatar
Re: cage question
Super73, I am not sure I follow you on this one. Are you talking about the bar from the main hoop that runs forward and down the a-pillar? If so, it is still there, but runs through the top edge of the dash, behind the dash, and down to the 2x3. The crossdash bar is behind the dash even with the speedo/tach holes in my bezel. Hope this helps, if not, we can try again. I may not understand what you are asking. I'm kinda thick headed at times. Lol Paul
Old 01-05-2012, 06:17 PM   #33
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cage question
I have also heard people taping this are off and rolling or spraying auto parts store bed liner or trimming carbon fiber stickers to cover entry scuffs .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-05-2012, 07:40 PM   #34
kpeztruck
kpeztruck's Avatar
Re: cage question
I have meant to do just this for some time. I believe I will touch it up, then add the scuff guards in that area. I had fought to get the truck to hook the way it does, that details like this slipped under the radar. I hope to rewire my truck with either Speedwire, or Spaghetti Menders systems, add a Racepak data logger, and tidy up these details during this year. Thanks, Paul Baxter
Old 01-05-2012, 09:05 PM   #35
Super73
Super73's Avatar
Re: cage question
Paul,
Here is what I am talking about. See the bar that runs below the X in my door are, you don't have that in yours. Did the 2x4 in the rocker allow you to keep that out?
The other 2 pics are just another angle on it.
Old 01-05-2012, 11:06 PM   #36
kpeztruck
kpeztruck's Avatar
Re: cage question
Ok, I get it now. Just a little dense here at times. lol Yes, the 2x3 took the blace of the lower bar you are referring to. When it was inspected previously, and only certified to 8.50, the chassis inspector said that all I needed was the tubing from the inside of the 2x3, to the frame on both sides, and the trans crossmember had to be round tubing,and another round tube between the frame rails at the rear. You can see the rear in one of my photos. I can't wait to see yours completed. Too bad we live on opposite sides of the country, we would have to meet at a track otherwise. The work is looking great. Paul
Old 01-05-2012, 11:14 PM   #37
bigboybodry
bigboybodry's Avatar
Re: cage question
I had a 7.50 roll cage put in my car in KY. at k&bracecars and would have passed with a 25.3 certification there with the chassis guy there looking at the car telling us what to do. I brought the car back to MS. to find out it needed 9 more bars to pass my certification guy here. its best to contact the chassis guy in your area before/during the install.
I like the carbon fiber bar wrap but it is pricey
I will be adding a roll cage one day to the old truck so thanks for the great input!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-05-2012, 11:28 PM   #38
kpeztruck
kpeztruck's Avatar
Re: cage question
I could not agree with you more. First line is the chassis specification manual, second is to have the chassis inspector on speed dial. Again, i can not stress enough, be nice...someone cusssed out the only one in this area, and he made their life miserable. I do not agree with that line of thinking, if it has all the bars nesc. according to the manual, it should pass. The tech guys have way too much authority to make your life miserable without just cause. Paul
Old 01-06-2012, 12:12 AM   #39
Super73
Super73's Avatar
Re: cage question
Paul,
I am afraid that if we met at the track I would have to ask for a little space
Old 01-07-2012, 10:25 AM   #40
kpeztruck
kpeztruck's Avatar
Re: cage question
Originally Posted by Super73 View Post
Paul,
I can give a little space. But I will be cautious on how much. I have a feeling when you get yours lined out, it will be quicker than expected. I can not wait until I test again. I covered mine up for the winter last night. Paul
