#26 |
Re: 86 squarebody made2drag
as of right now, i can stand on the rear bumper and the axle touches frame.
after the notch is welded and i cut the rest of the bottom of the frame off on each side, i should be touching the top of the notch. if i step notch it, i'm going to make a 3 inch lowering block out of 2x3 square tubing and my axle should be thru the frame all the way. i have some 9000 sleeve airbag brackets to mount on the frame and leaves ... and i still need to mount some shocks. the truck rides pretty much like stock in the front and the rear isnt as bouncy as i thought it would be since i dont have shocks...well, thats probably going to be it for a couple of weeks, i'll post some pics when i get the bed on........ |
#27 |
oh, i forgot to mention, my trucks 8 1/2 inches lower in the front and 9 1/2 inches lower in the rear and may go down another 1 with the notch done and the bed on
#28 |
some good progress keep the pics comeing
#29 |
sweet, is this a daily driver or fun/show truck?
"As I walk through the valley of rice i fear no honda, for i have torque!" |
#30 |
Home Built '87
Nice truck to start with, nice progress too!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#31 |
Diggin The SquareLife
need some small tires.....get me drop
#32 |
I'm just glad to be here!
In the pic on post #8, where did you get that black "cup" for the lower a arm?
In the pic on post #21, where did that flip bracket for the axle come from? You seem to be moving quick on this one.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#33 |
daily driver
#34 |
#35 | |
i made the flip brackets.... $10 for both axle seats from Tractor Supply and while i was there i picked up a piece of flat bar 1 1/4 or so and almost 1/4 inch thick. when i had everything positioned and my angle finder showing the same angle for the trans and diff...i measured the lengths for each tab....cut them out and welded them to the seats and they fit perfect. when i do a step notch im going to wire brush everything down and por-15 the frame and suspension once i have everything how i want it. i tackled the bags and rear in three 8 hour days. i dont usually have that much time to work on stuff so it was nice |
#36 |
#37 |
Nice build, clean truck to start with. ROLL TIDE!
#38 |
#39 | |
also, make sure you get the 3 inch 5000 lbs axle seats. they have 2 types: 3 inch 5000 lbs and 2 1/2 inch 3500 lbs..... |
#40 |
#41 |
#42 |
nice work man and great progress so far.... on the cups your using for the lca's how deep is that cup? it almost seems like even thought the plate of bag fits in there once the truck is laid out and the bag is deflated the bag may rub agaings the edge of the cup all the way around im not sure it may be just the angle that pic shows.... looking good though keep them pics coming....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#43 | |
http://www.airliftcompany.com/produc...oadlifter-5000 |
#44 | |
#45 |
#46 |
i guess i should have said WHICH truck!....lol, i found the green truck thread on another site and saw you have 4 layed out masterpieces! love them all, but now that ive seen your green one....how about a link to your blue one? thanks
and i'm definitly going to modify my lca like you did....sweet idea |
#47 |
Clean truck you started with, and your making quick progress.
Keep those pics coming, lol.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
#48 |
more pics on saturday...hopefully
#49 |
thanks, i love what your doing to yours with the dodge steelies and the z. cant wait to see it on the ground. yesterday i bookmarked your build to check yours out frequently. i think im going to go with some 4wd leafs. hope they will work with my shackles.
#50 | |
So far I can only see about 1" extra drop with the 4wd springs, but I still need to remove a couple leafs. But I already had them and i'm sure stock 4wd springs shouldn't be hard to come by cheap or free. Don't know why they wouldn't work with your shackles.
