Old 06-08-2012, 12:23 PM   #26
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Gas tanks?
Good info, Creek. Do you have pics or a link to build threads?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-12-2012, 12:47 PM   #27
kevinc
kevinc's Avatar
Re: Gas tanks?
Originally Posted by OldCreek View Post
I used a 87 blazer tank in my blazer. I had to move the rear crossmember back a few inches. 87 sender with EP381 and stock filler.
I used a 89 Jeep tank in my C-10 long bed because I didn't want to move the crossmember. With this, I used a 87 sender with EP381. The Jeep tank fit pretty good...I added a small crossmember below the bed to have something the front end of the tank to rest on. The only issue is the filler size, 1". I'm running an in bed filler from the same jeep. The tank is barely visable below the rear sport bumper and otherwise would not be an issue if the truck were lowered.
PLease post pictures if you have them!
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 06-14-2012, 12:13 AM   #28
OldCreek
OldCreek's Avatar
Re: Gas tanks?
Well, I don't know that anything I've got is anything new or isn't already on this site but here's a few pics. In fact, I think I got the wrangler tank idea from Mr. Rhino's thread. However, iirc, he cut his cross sill to fit the tank up against the bottom of the bed. I set mine on the cross sill and added an extra piece of the sill to balance it out.
The blazer has a 4" spring lift and H052 axle. The rear cross member was moved all the way back to the end of the frame. '87 blazer tank and sender with ep381.
Blazer first:
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 06-14-2012, 12:31 AM   #29
OldCreek
OldCreek's Avatar
Re: Gas tanks?
C-10 LWB with '89 Wrangler tank (15gal), '87 blazer sender, '87 blazer tank straps cut down and rewelded. '89 Wrangler filler and hoses from McMaster Carr. The filler will probably be finished with a '72 blazer hose cover or something similar.
The cross members are in the stock position with an added section of a bed cross sill to balance out the tank. I think the tank will fit a SWB but you may have to fit it around the cross sill...I haven't really looked at it that close, yet. Stock height/original springs (I think).
Old 06-22-2012, 07:22 PM   #30
OldCreek
OldCreek's Avatar
Re: Gas tanks?
Fuel filler cover...copied off of my blazer and cut to fit the wrangler filler. Again, this filler was used since it has 1" fill hose and 3/4"(or 11/16"?) vent tube that matches the 15 gal '89/'90 tank.
I made a pattern of the blazer cover and used it to cut out the cover from 22g sheet metal.\
I filled it up today and it worked great! Plus, if I pull in real close to the pump I can pull up on either side of the truck...i.e. less waiting in line!!!
Old 06-22-2012, 08:07 PM   #31
laynrockers
laynrockers's Avatar
Re: Gas tanks?
Here is what i have been looking at, Fully baffled, reasonably priced for coming with sending unit and all necessities.
http://www.performanceonline.com/196...TE-KITS-19691/
laynrockers is offline   Reply With Quote
Old 06-23-2012, 10:13 AM   #32
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Gas tanks?
Looks like a Boyd's Welding tank. Paid about $150 less for mine during a group buy.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-23-2012, 11:39 AM   #33
manimal
manimal's Avatar
Re: Gas tanks?
Now how about mounting a tow hitch with a rear tank? Looks like the blazer tank is a great candidate...but I am working on a Longhorn. Thanks
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
