05-29-2012, 11:52 PM | #1 |
Gas tanks?
Can someone share with me the options of bed tanks for efi motors? I'd like to keep fill neck in bed. Do I really have to spend $700 on a Boyd tank to accomplish this?
Thanks Posted via Mobile Device |
05-30-2012, 09:28 AM | #2 |
Re: Gas tanks?
I just picked up a 89 Jeep wrangler 2.5 liter 15 gallon tank from Advance auto parts. I got the idea from mrhino's build http://67-72chevytrucks.com/vboard/s...=427417&page=2
I have not installed it yet but here is what I think Pros: I like that the bumper almost completely hides it. Cheap paid about $100 for a brand new one. Appears to accept common GM sending unit/pumps with slight modification Internally baffled Cons: Filler tube is only 1 inch Only 15 gallons hope that helps Mike |
05-30-2012, 02:03 PM | #3 | |
Re: Gas tanks?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-30-2012, 02:17 PM | #4 |
meowMEOWmeowMEOW
Re: Gas tanks?
1 sheet aluminum, 2 AN bungs, tank foam, ruler. Doesn't get a whole lot more bare bones than that. It has a sending unit as well, although its not hooked up. Holds about 15gallons, doesn't slosh, and its sumped to run an external FI pump without issue.
05-30-2012, 07:50 PM | #5 | |
Re: Gas tanks?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-30-2012, 08:19 PM | #6 |
Re: Gas tanks?
05-30-2012, 11:57 PM | #7 |
Re: Gas tanks?
Truck is 72 lwb , I would like to use as large of tank as I can get. I would like to fill tank from the bed, do not want to put side door or behind plate fill( hoping to install hitch there)
05-31-2012, 10:24 PM | #8 |
Re: Gas tanks?
The pump was from a full size blazer. 1990 i think. It has to be fuel injected and a 15 gallon tank. Not the 21 gallon tank... look it up on rockauto.com
05-31-2012, 10:45 PM | #9 |
Re: Gas tanks?
CPP has a 22 gallon tank with a fill neck going through the bed floor(if that's what you mean) for $500. Not cheap but the fab work is great and it comes with the sender, neck, cap and fittings.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
06-01-2012, 10:50 PM | #10 |
Re: Gas tanks?
Here is what I plan on doing for mine.
http://www.73-87.com/7387garage/chas...ellinstall.htm |
06-02-2012, 11:58 AM | #11 |
Re: Gas tanks?
I am doing an ls swap as well, and am considering the '87 fuel tank. Apart from the fuelpump and pickup, what is the difference between that my '84 tank? Can I simply stick the efi crap in my existing tank?
06-02-2012, 02:01 PM | #12 | |
Re: Gas tanks?
Bv Posted via Mobile Device
06-04-2012, 09:59 AM | #13 |
Re: Gas tanks?
i had bought a 99 Z28 tank for our swap but ended up buying a boyd tank instead of using it..
66 LWB/BBW work in progress 68 Camaro SS bigger work in progress 95 Roadmaster Wagon 12.36 @ 107.74 99 Hayabusa 8.72 @ 162 00 Hayabusa 9.33 @ 153 |
06-04-2012, 10:06 AM | #14 |
Re: Gas tanks?
Thanks. I will use an inline walboro external for now with the c5 reg mod until I can find a good 87 tank.
06-04-2012, 05:47 PM | #15 |
Gone Fishing
Re: Gas tanks?
So do you need a baffled tank to have the ls motors run properly? I was just going to run an aftermarket burb tank since i'm running a frame rail mounted pump.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
06-04-2012, 09:21 PM | #16 |
Re: Gas tanks?
you dont have to run a baffled tank, but it is better if you do....it keeps fuel starvation to a minimum, when the fuel level is low, and you're on the throttle....I have a normal blazer tank, and I have to keep the fuel tank level above 1/8 if I'm gonna be foolin around....lookin back I wish I woud've bought the 87 blazer tank...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
06-04-2012, 09:38 PM | #17 | |
Re: Gas tanks?
06-04-2012, 10:17 PM | #18 |
Re: Gas tanks?
Does it matter what tank? My truck only has one on the passenger side. Only reason I was going to use the inline and C5 reg is because I have them left over from another project.
06-04-2012, 11:02 PM | #19 |
meowMEOWmeowMEOW
Re: Gas tanks?
If you have an unbaffled tank, get tank foam, it will aid in sloshing and help concentrate fuel around a sump (if you have a sumped tank). Either way it will help the slosh, as a fix.
06-04-2012, 11:40 PM | #20 |
Re: Gas tanks?
Forgive my ignorance but what is tank foam?
06-05-2012, 08:12 AM | #21 |
Re: Gas tanks?
Forgive my ignorance as well please.
If I use one of these what else would I need to complete it for LS efi motor? http://www.summitracing.com/search/Y...yword=gas+tank |
06-05-2012, 11:25 AM | #22 | |
A guy with a truck
Re: Gas tanks?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-07-2012, 10:00 AM | #23 |
Re: Gas tanks?
Tank Foam I believe is a way of baffling the fuel it is like a chunk of sea coral.
06-07-2012, 11:36 AM | #24 |
meowMEOWmeowMEOW
Re: Gas tanks?
http://www.evomx.com/fuel-tank-foam-information/
I didn't use this stuff in particular, but its a nice explanation. (I think the link is a mx racing company or something, just use it for the info)
06-08-2012, 12:21 PM | #25 |
Re: Gas tanks?
I used a 87 blazer tank in my blazer. I had to move the rear crossmember back a few inches. 87 sender with EP381 and stock filler.
I used a 89 Jeep tank in my C-10 long bed because I didn't want to move the crossmember. With this, I used a 87 sender with EP381. The Jeep tank fit pretty good...I added a small crossmember below the bed to have something the front end of the tank to rest on. The only issue is the filler size, 1". I'm running an in bed filler from the same jeep. The tank is barely visable below the rear sport bumper and otherwise would not be an issue if the truck were lowered.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
