07-01-2012, 10:47 PM | #26 |
67-72 parts collector,…
Re: Lowered rear suspension question?
There should be a stud for the lower shock mount.
Call ECE if you didn't get it.
07-01-2012, 10:52 PM | #27 |
A guy with a truck
What he said. You can use a pair of front studs in a pinch...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-01-2012, 11:29 PM | #28 | |
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
07-02-2012, 10:47 AM | #29 |
Talked to ECE this morning and he said just drill out the shock bracket and use the front shock mounting studs I already have and I will be good. Hope the exhaust repair is that easy.
07-04-2012, 08:03 PM | #30 | |
the old lower shock bolt (rear shock) i removed was worn 1/6 through from years of wear. and the shock bolt hole was actually rideing partially on the bolt threads..... i wonder if those bolts were stock ? anyway appreciate yours and others help as my rear is in similar shape except i am running bags not coils on my 66 fleetside. thanks paul |
07-04-2012, 08:07 PM | #31 |
I think your local parts house should have them.
This is one I found on the internet. http://*************/shock-relocating...ck-stud-button This is what they look like.
07-04-2012, 09:46 PM | #32 | |
07-05-2012, 08:22 AM | #33 |
Just seeing this one, .. yes much better. Looks good man. It's much easier to re-work the exhaust anyway. I bet it rides a lot better too.
Question. I noticed your Pinion angle appears to be +3 deg or so. Have you considered pinion angle shims? This might (likely) smooth things out even more they're cheap too and will keep from popping the Ujoints unexpectedly. I have some good info on this if you want to PM, or just reply and I'll post it here. Lolife99 -- Does it look a little high to you? I think I might look at ~2 or 3 deg shims for it if it were mine. Just sayin ..
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
07-05-2012, 08:40 AM | #34 |
It's hard to tell about the pinion angle.
A quick check with an angle finder will answer that,... but you have to compare it to the tailshaft of the trans to know if it's correct.
07-05-2012, 08:41 AM | #35 | |
When I first lowered it with the set up I have now I tried rear end shims and set the angles where I was told they should be and it vibrated (never had before with the heated springs) so I removed them and I think it feels fine. I put u-joints in it when it was first put together and have not had to replace them since. The truck does eat carrier bearings. I think I am on my 5th or 6th bearing. Some have got loose, one had a bearing fail and one I broke the bracket loose from the mounting plate (may have been playing to hard). I would like to see what you have on this if you want to send me a link to a thread or post it here. I do have a cross member that changes the swing arm mounting locations that I was going to use when I redo the truck and make it a short bed.
08-21-2012, 08:34 AM | #36 |
Ok I am finally driving the truck again. While I was fixing the rear suspension, the engine developed an oil leak at one of the pipe plugs in the rear of the block. I finally got the oil leak fixed and the truck back together. I have put over 100 miles on it and it is driving good. Thanks for the help.
09-19-2012, 01:39 PM | #37 |
I took a trip to Michigan last weekend and drove over 950 miles in 4 days. The truck was loaded and did pretty good but I still have a couple issue to address. While driving with minimal load, the headers drug when hitting dips on a 2 lane highway. So my header collectors hit before my front suspension bottoms out. I am going to have to raise the front or install short tube headers. The second issue was when the truck was loaded (possibly loaded to heavy, LOL) and driving down the Interstate, the rear suspenion was hitting somewhere. I think that might be the driveshaft yoke bottoming out in the transmission. I am not sure if I need to shorten the driveshaft or what to do there.
10-07-2012, 07:13 AM | #38 |
great info guys, im looking at a 4.5/6 drop and would like to know if it essential to change the track bar??
10-07-2012, 07:51 AM | #39 |
With a 5 inch rear drop on mine I had to change the track bar and install shock relocators so with 6 I am sure you will need to. It was scary to drive at time before I changed the track bar. The shocks just make it bounce to much. I went with the super trac arm kit that relocated the right mounting to the right axle u-bolt instead of the diff. housing. Rides and drives good now but with a load in the bed my driveshaft is bottoming out so now I need to fix that problem.
