Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-16-2012, 07:02 PM   #26
Dale99
Re: Project 30 years sitting
Sadly, same motor if I dont eff the block up getting the dizzy out tomm.
I cant really afford what I want right now..... 6.2 with the 4l80e and undecided tc. I just need to get it running, do some body work, and then decide where I want to take it.
Dale99 is offline   Reply With Quote
Old 11-17-2012, 02:38 PM   #27
Dale99
Block out, dizzy out. Lots of sludge inside. Time to clean!!!
Old 11-18-2012, 12:00 PM   #28
Dale99
pics of the mess.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Old 11-22-2012, 08:59 PM   #29
Dale99
Old 11-24-2012, 12:14 PM   #30
Slinger60
Slinger60's Avatar
Motor looks a heck of a lot better. Like the crossmember you put in too.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 11-24-2012, 11:41 PM   #31
Dale99
Thanks. Motor actually looks like a motor after today. 14hrs and it honestly doesnt look like I got much done. But 2 trips to junk yard, and 3 trips to parts store will kill time quick.
Old 11-25-2012, 12:28 AM   #32
Dale99
Old 11-25-2012, 05:31 PM   #33
Dale99
It runs!!! Video soon
Old 11-25-2012, 06:21 PM   #34
Dale99
http://www.youtube.com/watch?v=fBWQk...ature=youtu.be
Old 11-25-2012, 08:54 PM   #35
jaros44sr
jaros44sr's Avatar
Damn, that was quick...well done
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-25-2012, 09:05 PM   #36
Dale99
4 days of nothing to do but work on it.
Old 11-26-2012, 09:23 AM   #37
hgs_notes
GEARHEAD
hgs_notes's Avatar
Sounds good. Congratulations.
hgs_notes is offline   Reply With Quote
Old 12-05-2012, 12:02 AM   #38
Dale99
Since Ive gotten it running, Ive been doing lots of piddly things.
Plumbed brake booster and pcv valve
re-plumbed some of the fuel line (its going to get changed later though)
installed elbow on power steering line
have gas tank hanging in place (waiting tell weekend to weld braces)
cleaned and tinkered with transfer case selector box. I think I have all 5 positions now.
removed clutch peddle
mounted fuel pressure regulator for elec tank
installed new detent cable
changed trans pan/fluid/filter
installed dust shield for tq conv (it didnt have one)
have the first few feet of exhaust routed. Cant figure out where I want to dump it.
started on some body work testing my new stud-weld gun and slide hammer.
Old 12-08-2012, 09:48 AM   #39
hgs_notes
GEARHEAD
hgs_notes's Avatar
Its been a few days now. Where are the pics?
Old 12-08-2012, 10:50 AM   #40
Slinger60
Slinger60's Avatar
Nice work on the motor. While working on a project it seems you almost put as much time running around to different places for parts and shopping on the internet. Also the research eats a lot of time too.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 12-08-2012, 10:27 PM   #41
Dale99
Havent been taking pics as there is really nothing to see IMO.
Agree on running around, research, etc.
Big snag today, went to back it out to weld on it and it wouldnt stay running. Turned it around yesterday and did just fine??? Compression test showed 6? to have zero compression. Yet will somewhat hold air when doing a leak down test. WTF? Rockers are moving as well.
Old 12-08-2012, 10:41 PM   #42
Dale99
Here is a pic from last night after turning it around, before I went out for the evening. Still in same spot, but has gas tank bolted and partly hosed up, also has drivers mirror on it.
Old 12-09-2012, 09:26 PM   #43
Dale99
No clue what the motors problem was, but it started today and ran fine. So while it was running we did a quick tune on the carb.
Power wire routed but not hooked up for the tank
06an fuel line routed but not hooked up for fuel supply.
Old 12-09-2012, 10:35 PM   #44
Dale99
http://www.youtube.com/watch?v=SjleM...ature=youtu.be First drive heading out.
http://www.youtube.com/watch?v=Sa5LK...ature=youtu.be First drive returning
Old 12-09-2012, 11:12 PM   #45
hgs_notes
GEARHEAD
hgs_notes's Avatar
Just kidding with you. Its the common theme for all threads on this board. MORE PICS!!!
Congrats on getting it down the road, and especially back again.
Old 12-09-2012, 11:43 PM   #46
Dale99
You would think being a photographer, I would take out the good camera and be posting millions of pictures. But most of this is just cell phone shots
I guess next time I'm under it I could get pics of all the sexy aluminum parts on the bottom side that will never be seen otherwise
Old 12-10-2012, 07:07 PM   #47
Dale99
Talked to previous owner today, he thinks he may have the original 205 transfer case that has a transmission tailshaft snapped off in the input. Hopefully I can get that off him
Old 12-11-2012, 09:36 AM   #48
Dale99
Was under it measuring for mufflers, so I snapped this. Looks like tonight will be a wiring night to upgrade the size of wire for the HEI, and wire in the fuel pump.
Old 12-12-2012, 05:38 PM   #49
Dale99
I have a dis-assembled 205 transfer case on my floor. YES. When I'm feeling better I will sort everything out to figure out what I need n have. Time to find a diagram.
:edit: Figured out is a dana 20, dangit.
Old 12-16-2012, 01:51 PM   #50
Dale99
Productive day yesterday....
Frame horns fixed with parts from a board member I got a while back.
Pass door hinges replaced from a board member I got a while back.
rear shocks installed
due to frame horns getting fixed, I could finally bolt down the front and install fenderwells with bolts I got from board member Brian A.
This morning I ordered my tires
plan to work on my exhaust more, rewire my fuel pump relay I fubar'd. Maybe get the grill installed. Depends on how many people come help.
