Old 03-27-2013, 10:57 AM   #26
MTCK
MTCK's Avatar
Re: Hydraulic clutch swap time
That's what I was thinking. Technically the adapter is for AA's own bellhousing. It fits now, I'll post up some pictures this evening. Also I have a template for you. It was a little stressful to drill the holes, but the pedal stroke is smooth and there is no binding.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-27-2013, 02:12 PM   #27
argonaut
argonaut's Avatar
Marcus,
That AA adapter looks frustrating. It appears that you'd have to cut into the cylindrical portion of the bracket in order to get the necessary clearance. I think I still have a few parts that I fabricated to make my own slave cylinder bracket, before I switched to a hydro bellhousing. I never got around to welding it up and adding the gussets but I'll look for it if you want and I can send this stuff up to you if you wanted to just cover shipping. I could probably even finish welding it up if you needed. Let me know and I'll look for it.
I also have a dimensioned autocad drawing of it that I could dig up and post. It's pretty easy to make with some plate and tube.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-27-2013, 02:25 PM   #28
Redcap
Originally Posted by argonaut View Post
Marcus,
That would be very cool. I have a friend wanting to go juice, but parts are scarce or very expensive.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 03-27-2013, 04:07 PM   #29
argonaut
argonaut's Avatar
Here you go.
If I remember correctly after making the first one and fitting it, I figured that I could move the slave cylinder about 1/4" closer in toward the motor. Also the distance between the slave cyl mount holes may have been just a hair too big.
I can always update the drawing and repost it if you want. But I don't feel like dismounting my slave cylinder to remeasure it.
Also, I can check measurements on the length of the tube from my notebook when i get home tonight, but the length will depend on whether you prefer to mount the slave behind or in front of the bracket.
This was using a hydraulic clutch fork, not a mechanical clutch fork as they are different.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-27-2013, 08:09 PM   #30
CHEVYLUVR859
Can anyone tell me if an 89 truck clutch pedal would work in my 85 465 hyd swap
CHEVYLUVR859 is offline   Reply With Quote
Old 03-27-2013, 11:42 PM   #31
MTCK
MTCK's Avatar
Thanks Jason! I think I have the AA bracket working (after drilling through the boss and ribs from the bottom with a 9/16" bit). If not I will take you up on your offer. Should know later tonight.
Lover, an 89 from a square truck (blazer, suburban, 1 ton crew) will bolt right in with some new holes. A newer body style 89 truck's will not.
-Marcus
Project Plow Truck
Old 03-27-2013, 11:58 PM   #32
Oilbrnr
Oilbrnr's Avatar
Nothing better than a smooth stroke, err at least that is what she said...
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 03-28-2013, 08:07 PM   #33
obijuan
so now that youve got the bracket mounted, does the bleeder screw hit the motor like mine does? ive got the aa bell and the aa adapter. im heavily frustrated. if the brackets holes were drille a little different then the bleeder would be fine.
obijuan is offline   Reply With Quote
Old 03-30-2013, 12:43 AM   #34
84 400
Sb 400 club
84 400's Avatar
I also did this swap on my 77.
I used the pedal assembly out of an 86 for the hydro clutch pedals. Got the rest of my parts at napa. I made a template off a cab in the junk yard and drilled my holes from that. Worked out reall well. Also it is easier if you remove the steering colum to do this job
The NEW master will NOT have a res with it One of an S10 or chevy truck will work but MAKE sure the rubber line is rated for brake fluid!!
Also to bleed the system I assembled it on the bench and bench bled it. Only way I could find to get all the air out. Then I put the entire assembly in the truck.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-30-2013, 09:40 PM   #35
MTCK
MTCK's Avatar
Sorry for the slow progress, I finally got back on this today.
OilBrnr, yeah
obijuan, yes the bleeder definitely hits the block now. Just barely, but it makes contact. Looking at Jason's pictures, is bracket rotates the bleeder up and away from the block.
84, sweet truck. I've read through your build before and like what you've done. are your swampers TSL's or LTB's? Love the tall skinny tires with a little lift. Thanks for the pointer on bench bleeding - that is a good idea.
I ran into a few more snags. I had to take a little more material off of the bell housing to make it fit, but now the AA bracket is sitting flush and feels solid. once I had it mounted up, I noticed that the existing hole for the clutch rod is nowhere near the slave cylinder. It looks like the other mounting holes on the bracket for the larger bore slave would line up perfectly, but not the further inboard set. I drilled a 3/8" hole in the fork lined up with the slave (PITA!) and got everything bolted up. I'm not wild about how it looks. If I was going to do it again I would grab a hydraulic clutch fork.
The fork was actually contacting the end of the slave cylinder, so I spaced it back with a pair of washers. Now it just BARELY doesn't touch. There is no way the boot would go on the end of the slave cylinder with as little clearance as there is between it and the fork. Pictures below.
-Marcus
Project Plow Truck
Old 03-31-2013, 02:07 PM   #36
argonaut
argonaut's Avatar
Dang Marcus, I really never thought it was going to be so challenging. I'm kind of surprised.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-31-2013, 04:34 PM   #37
MTCK
MTCK's Avatar
Me too. So is my wife! I said I'd have the garage tied up for a day or two. Hahaha. I think if I was going to do it again I would pull the bellhousing and trim it down outside the truck. I would also install a hydraulic fork while I was in there. I bet if I did that, I could mount the slave on the rear side of bracket instead of the front, it probably wouldn't hit the block.
At any rate it is done now. If I don't like how it works ill switch the fork once the weather warms up and I can work outside. My one car garage just doesn't hack it. -26F last week but looks like spring is on the way now.
-Marcus
Project Plow Truck
Old 03-31-2013, 04:36 PM   #38
obijuan
it would be challenging at all if advance adapters got advanced, with their adapters.
if the clocking of this slave was just a little different the breather would be straight up. cant see any reason why its located where its located.
here was my solution. i used the lower hole and rotated it to where i needed it and "bolted" it on with a little piece of scrap. ghetto, yes. can i bleed it now and will it probably work forever? yes. i also had to bend the bracket to get the pin lined up.
Old 04-05-2013, 11:20 PM   #39
MTCK
MTCK's Avatar
Everything is cohabitating nicely now. Will take the truck out and play a little this weekend now that all my shocks are stretched out.
-Marcus
Project Plow Truck
