Old 03-24-2013, 08:14 AM   #26
Benlugchev
Benlugchev's Avatar
Re: 71 Turbo 6.0L-LWB**Build Thread**
Update: Completed assembly of the engine, heads, cam, lifters, pushrods & rockers. Cut the flanges off the outlet ends of the stock manifolds and mocked up my clearances around the power steering pump. Using the stock 6.0L front accessories. I Just have to reroute the power steering lines and she will clear by about 1". My Plan is to use 2" sch10 304 Stainless hotpipes from both manifolds to the turbo mounted near the passenger side headlight. I Still need to powder coat the intake manifold and buy a set of good looking valve covers. Ordered a Mcleod RXT clutch and flywheel. It should be here next week then the tranny and engine can be set for mockups and fabrication of the engine mounts.
While waiting for the clutch, I decided to strip the interior. Floor was very solid. I put a new sheetmetal patch where the shifter penetrates the floor. Stripped out the stock fuel tank. I POR15 the floor and install new soundproofing and carpet. Then re-install the bench seat that came with the truck.
Before:
AFTER
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs)
00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs)
Benlugchev is offline   Reply With Quote
Old 04-03-2013, 09:55 PM   #27
Benlugchev
Benlugchev's Avatar
Re: 71lsx-LWB**Build Thread**
UPDATE: Fuel rail brackets completed
Custom Engine Mounts fabricated and engine set in truck at a -2 degres angle with a very low CG.
Started mockups for the turbo location and piping. This is about where the turbo will sit. 5" downpipe will run straight back duck under the cab and exit before passenger side rear tire. Air filter will stick through the radiator support up to the grill, for some fresh breathing air.
Old 04-03-2013, 10:54 PM   #28
bigguy69
dazed and confused
bigguy69's Avatar
I like this build!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-06-2013, 10:06 PM   #29
Benlugchev
Benlugchev's Avatar
UPDATE: Picked up some seats from a 97' chevy, fabricated some brackets and they fit nice. Installed the closed cell foam and mounted my amp.
Fabricated a transmission cross-member and installed it. (still needs to be painted)
Old 04-29-2013, 10:28 PM   #30
Benlugchev
Benlugchev's Avatar
UPDATE:
Lightened up the radiator support, made room for the turbo. fabricated the passenger side hot pipe from 2" sch.10 -304SS. the plan is to merge the drivers side manifold into the 90 degree elbow just before the turbo. fabricated the T6 turbo flange from a piece of 3/8" stainless plate. Powder coated the intake manifold. elbow.(sour apple green) valley cover and timing cover (black). hope to get the drivers side hot pipe fabbed by end of the week and then yank the engine repaint the chassis. install my clutch and put the engine back in place.
Old 05-17-2013, 08:29 AM   #31
Benlugchev
Benlugchev's Avatar
UPDATE: Installed the RXT clutch/flywheel from Mcleod. Put another coat of POR15 on the chassis and reinstalled the engine for its final time. started finishing up all the small things like fuel, front accessories, ect. Cut the hole in the 3/8" SS plate, merge and waste gate hole with Plasma. Everything seems to me lining up nicely. 5" Aluminum exhaust tubing came in and 4" aluminum cold tubing. Hopefully Saturday I will finish cold tubing and install the alky control meth system.
Old 05-19-2013, 12:08 AM   #32
Benlugchev
Benlugchev's Avatar
Finished up all the hot side and exhaust today.
Old 06-16-2013, 08:48 PM   #33
Benlugchev
Benlugchev's Avatar
well she is running and man does this thing fly. here is a little idle clip that doesnt do it much justice. Ill get a fly by video in the next day or so
http://youtu.be/u36uuXqywK8
Old 06-18-2013, 05:48 AM   #34
bigguy69
dazed and confused
bigguy69's Avatar
Sounds great!
Old 06-18-2013, 10:04 AM   #35
Wasted Income
Boosted Member
Wasted Income's Avatar
Interesting turbo placement. I like it.
How are you bracing that pig of a turbo? Or is the hotside what's holding it up?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-18-2013, 10:39 AM   #36
67cheby
67cheby
67cheby's Avatar
WOW...man some great fab work going on with all that engine stuff !
67cheby is offline   Reply With Quote
Old 06-18-2013, 01:53 PM   #37
mcbassin
Still Learning
mcbassin's Avatar
Man, this is a cool build LS build up. What kind of HP numbers are you throwing to the ground with it?
mcbassin is offline   Reply With Quote
Old 06-18-2013, 02:27 PM   #38
72C20RestoMod
You must have a solid engine mount setup? Otherwise that turbo is stuck between a rock and a hard spot...
-1972 Chevy C/20
Plans: 4wd conversion, restore, update, drive it till the wheels fall off.
72C20RestoMod is offline   Reply With Quote
Old 06-19-2013, 09:28 PM   #39
Benlugchev
Benlugchev's Avatar
thanks man.
turbo is supported off the hot pipes 2" sch 40. so far so good.
Old 06-19-2013, 09:30 PM   #40
Benlugchev
Benlugchev's Avatar
Not sure on the HP numbers yet, hopefully get to a dyno or track sometime soon. My guess is with the 8psi spring in there now its around 500rwhp. She still has plenty more left in here once I figure out a good tire/wheel combo
Old 06-19-2013, 09:32 PM   #41
Benlugchev
Benlugchev's Avatar
Motor mounts are custom made, they are deff stiffer than the stockers were. But other than that turbo has clearance all around no rubbing or vibrations issues
Old 06-20-2013, 11:33 AM   #42
72C20RestoMod
It looks to be bolted to the exhaust flange, then hard mounted to a v-band at the intercooler. I don't see much give. Other than flexing the pipe that is already having to hold a behemoth of a turbo.
You have a nice rig. I don't mean to pick on your setup, just concerns I see of the layout is all.
-1972 Chevy C/20
Old 06-20-2013, 09:58 PM   #43
Benlugchev
Benlugchev's Avatar
i think i forgot to post this updated photo of my new intercooler mounts
Old 07-29-2013, 09:51 PM   #44
Benlugchev
Benlugchev's Avatar
my buddy finally to a dive by video today.
this is how she sounds, granny shifting ive only got one good arm right now due to shoulder surgery.
Turbo c10 - YouTube
Old 07-30-2013, 08:09 AM   #45
mcbassin
Still Learning
mcbassin's Avatar
That thing sounds great!
Old 07-30-2013, 11:48 AM   #46
Hardesty454
Hardesty454's Avatar
Cool build. Like where you're heading with this.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 09-15-2013, 08:57 AM   #47
Benlugchev
Benlugchev's Avatar
Got to the track yesterday.
I was being a big baby at the line and never launched hard. Best time was 11.88 @128mph, just under 15# of boost rolling start 2.40 60'. Truck weighed 3700lbs with me. Shes got more in it, messing with the tune and launching harder.
Number 860
Old 09-15-2013, 12:15 PM   #48
El Campo
El Campo's Avatar
I like builds like this!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-15-2013, 09:19 PM   #49
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
nice ET and MPH!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-16-2013, 10:37 AM   #50
Benlugchev
Benlugchev's Avatar
Originally Posted by 68GMCCustom View Post
nice ET and MPH!
Thanks Kurt, Im going to work on my tune a bit more and head back to the track in a few weeks, going to launch harder and should get ET down to low 11's with that MPH
1971 c-10, lsx swap, lwb, muncie, street strip
