08-10-2013, 02:40 PM | #26 |
Re: caddy CTS-V oil pan info
Using ece mounts I would say forward.
Posted via Mobile Device |
08-10-2013, 03:09 PM | #27 | |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
08-10-2013, 04:38 PM | #28 |
Word of advice pay attention to fan space when moving forward. I'm using electric fans since my pull out and ECM was programmed for this anyway. The mounts I used also allowed the ece trans crossmember to line up with original holes on tithe frame.
08-11-2013, 05:10 PM | #29 | |
01-31-2016, 03:29 PM | #30 |
thanks for posting this it really helps.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
01-31-2016, 09:53 PM | #31 |
I did some measuring and the truck pan sits about 1.75" below cross member and the cts-v appears to be a little over 2" shallower. I did find a couple of vendors for around $160 just for the pan.
01-31-2016, 10:05 PM | #32 |
I went with the caddy oil pan on mine, I don't have any pictures of it but it looks just like Daaaanz67's that he posted. It fit great no issues at all. I bought the pan, pickup tube, and dipstick & tube from a local GM dealer, and paid about 250 for all of it. It also came with a gasket and new bolts.
01-16-2017, 12:08 AM | #33 |
subscribed
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
01-18-2017, 11:07 AM | #34 |
BMW & ASE Master Certified
If anyone needs a cts-v pan, I have one off of my 99camaro engine swapped bmw... I changed it to the holley pan for more clearance. If anyone is interested, pan, windage tray, dipstick tube 100 plus shipping.
Only posted this here since it specifically was a out cts-v oil pans Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 01-18-2017 at 11:08 AM. Reason: Update |
01-18-2017, 04:13 PM | #35 | |
02-12-2017, 08:32 PM | #36 |
has any one tried removing truck pan and switiching with motor still in the truck?
02-28-2017, 01:04 AM | #37 |
I did, you have to lift or rock the engine up to clear it. Be very careful. Use a cherry picker if you do.
