07-24-2013, 04:58 PM | #26 |
Re: Dually Swap?
Already have everything. So no more outta pocket. Half way theough a 4spd/205 swap so gonna need new shafts anyway. I want to do this so i'm going to. I asked the people here a question about converting my 10 bolt front axle to dually hubs. Not what people opinions o what i should do with my money. My bills get paid every month and my wife and i keep food on the table. I put 10% of my weekly check into my 401k and make sure everything is takin care of. After that i do as i please. If you wana give me advice fine idc. I'm doing this just to do it. Unless you're going to help me with my 10b problem send me a pm.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
07-24-2013, 09:17 PM | #27 |
Re: Dually Swap?
I've never had a problem with my 1/2 ton 2wd.
Well, here's the thing about it, people are giving you crap about this because a 10 bolt is a light duty axle, there is no dually conversion for it. IIRC, 3/4 ton 4WD have a Dana 44 front axle, not a 10 bolt. 1 tons have a heavier duty frame. C30's actually have a highest GVWR of all the squares, they are rated at 12000 gross. K30's are actually rated lower. Just the facts, man. You asked for help. |
07-24-2013, 09:18 PM | #28 |
Re: Dually Swap?
This is for a 1978 model year truck |
07-24-2013, 09:26 PM | #29 |
Re: Dually Swap?
My trailer fully loaded with all 3 horses and equipment is 7k... So it'll be alright i think... Don't dana 44 and 10 bolt parts interchange?
07-24-2013, 09:48 PM | #30 | |
Re: Dually Swap?
Don't forget GVWR includes the truck weight, so add that in. My C10 in bone stock form (with 5 leaf rear springs) handles a 4500lb load great, can barely tell it's there. Thats a little over 8k combination, truck, trailer, and scrap car. Towed a Ford explorer once, that was real scary. Had to be over 10k. It pushed me thru a stop sign (No trailer brakes). Honestly, I think 4WD is an attitude thing. No offense to you, since I don't know you, but it seems 4WD is so popular because of the "go anywhere" marketing of 4WD vehicles. I get passed my people in jeeps and suv's all the time in raging snowstorms. Like thats real safe. My personal opinion, I would keep the C30 as a tow pig and the K10 as a fun truck. But thats just me. Do what you will, I've thought breifly about a dually conversion myself but seems overkill. An easier solution would be 3/4 ton springs front and rear on the 1/2 ton axles, It'll ride a little rougher but will not sag when you load it up with gear and trailer. |
07-25-2013, 07:35 PM | #31 |
Re: Dually Swap?
I can't afford 3 trucks lol. Insurance by myself (just ranger full coverage) is 500 every 6 months. All 3 would be about 800. Also i jus want 1. Looking at everything on the 2 the c30 will go on the 1/2 ton frame and it'll stay 1/2 ton until i can get all the bugs worked out. (4 spd swap and everythin associated with that. Inthe mean time i'll keep puttin back for a d60 like meatwagon. Do it right the first time! It will become a k30 just 1/2 ton frame. Now that i got a game plan we'll see what happens.
07-25-2013, 07:41 PM | #32 |
Re: Dually Swap?
nevermind
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
07-25-2013, 10:35 PM | #33 |
Re: Dually Swap?
What do you tow that you need a dually?
07-26-2013, 09:43 PM | #34 |
Re: Dually Swap?
Hey man, if you're hellbent to do something, you have to do it.
We had a dually jacked blazer running around our town years ago, bright yellow w/38" looked insane. Sometimes its all about doing something different not what you need. You have to have a d44 8 lug at least and you could probably use wheel spacers to get the bud wheels on. I would strongly recommend the d60, usually the dually ones are more common and cheaper, I see them for $300-$400ea. (I have 2). The single fronts are where the money is. The rear is where your work will be, the shock mounts and the spring pads will have to be relocated. Both are mounted inboard further on a 1 ton. I have never swapped a dually rear into a 1/2-3/4 ton frame, I am just offering you some info that may help you decide what to do. I would agree that dually swap will be a little work by the end. Last edited by chevy1ton; 07-26-2013 at 09:53 PM. Reason: correction |
07-26-2013, 09:58 PM | #35 |
Re: Dually Swap?
Thank's oneton. It will be a lot of work. But... Hell why not? Got the axle and will power. Do it to it!! Jacked up dually blazer?? Sounds different, unique, BADA$$!!
07-30-2013, 07:36 PM | #36 |
Re: Dually Swap?
Temporary solution!! Found my adapters this'll be a temporary solution until i can get a dana 60. Sad part is i can't even afford this lol.
http://www.ezaccessory.com/Wheel_Ada...6550-8650v.htm Posted via Mobile Device
07-30-2013, 08:38 PM | #37 |
Re: Dually Swap?
Well you better get used to being nickled and dimed because projects like what you want to do tend to yank on your pockets every step of the way not to mention any fabrication work.
I don't think anyone meant to bring you down with your project as much as trying to make you aware of the 'real life' work/ money involved. Do yourself a favor and at least wait till you get all your ducks in a row before spending money on those adapters. Get that rear mocked up and figured out and when you're ready for wheels/ tires in the front cross that bridge then. You just may have found a d60 by then. Make sense? This last truck I just finished took me over a year before it was driven again, it will take some time. That rear isn't going to fall into place, that is your mountain right now. Just like the others have mentioned you will also have springs (you have the short rear springs on a short bed), brakes, driveshafts, shocks, tires etc to deal with still. As far as GVW capacity goes I wouldn't be hauling pallets of brick or towing skid steers, keep it reasonable and you'll be fine. I'm not trying to bring you down either but go into your project prepared, thats all. |
07-31-2013, 09:48 AM | #38 | |
Re: Dually Swap?
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
07-31-2013, 12:07 PM | #39 |
Re: Dually Swap?
I know and it sucks, but what can ya do? Lille bit here some there. And it'll get done. Just later than sooner lol
08-02-2013, 04:04 AM | #40 |
Re: Dually Swap?
personally id just buy a dually. the amount of money your looking at spending to converting a 1/2 to 1ton will add up quickly. also the labor. my dad has a c30, hes slowly restoring the body...and not by his choice. unless you buy brand new, trying to find a decent dually bed, and if you get lucky with the bed trying to find good quality rear fenders is not easy.
79' c20 std cab 292 3speed granny - daily driver. 77' c30 std cab 454 th400 4.10 - fathers truck then mine. 95' ford bronco 302 4speed overdrive. 2002 mustang auto v6 - girlfriends daily driver. Debt just means that you had more fun than you're suppose to have |
Tags |
dana 60, dually |
