Old 07-23-2013, 09:16 PM   #1
79Betty
79Betty's Avatar
Question Dually Swap?
I'm making my 79 Silverado K10 into a K30 by dually axles and 1 ton springs, actually 1.5 ton springs but i have a problem. As usual. I have a 14 BFF rear dually axle. But a 1/2 ton front 10 bolt. Can i convert it to a dually front axle? Or am i stuck trying to find a dana 60 front dually axle? Been lookin at CL for month.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-23-2013, 09:44 PM   #2
meatwagon83
meatwagon83's Avatar
Re: Dually Swap?
where is jasper, i know a dude that has some, but they aint cheap!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 07-23-2013, 09:48 PM   #3
79Betty
79Betty's Avatar
Re: Dually Swap?
4.5 hours from Cincinnati... 1.5 from Louisville, KY
Old 07-23-2013, 09:48 PM   #4
walkerb
walkerb's Avatar
Re: Dually Swap?
Find the 60. Way Better and really no big deal to swap.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 07-23-2013, 09:50 PM   #5
meatwagon83
Re: Dually Swap?
how far to cincy, im about 30 minutes north of there, last time i was up at his place he had 2, for 1200 each
Old 07-23-2013, 09:50 PM   #6
79Betty
79Betty's Avatar
Re: Dually Swap?
I can't find one on cl with reasonable drivin distance. 1200 each OMG!
Old 07-23-2013, 09:53 PM   #7
meatwagon83
Re: Dually Swap?
yup, like i said, not cheap!! i can usually find them on cl around here but thats about what they bring, 800-1200
Old 07-23-2013, 09:56 PM   #8
79Betty
79Betty's Avatar
Re: Dually Swap?
Wonder what it'd take to convert my 10 bolt. It's a good axle and i don't wheel. Just tow.
Old 07-23-2013, 10:06 PM   #9
meatwagon83
Re: Dually Swap?
dude, check this itsh out!
http://cincinnati.craigslist.org/pts/3951332026.html
Old 07-23-2013, 10:07 PM   #10
meatwagon83
Re: Dually Swap?
even better
http://cincinnati.craigslist.org/pts/3915947747.html
Old 07-23-2013, 10:09 PM   #11
mrolds88
Re: Dually Swap?
79, meatwagon has a reasonable one there. Clean up and fix the chassis, then swap your body over. I personally wouldn't want to put all that driveline on those 1/2 ton suspension.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-23-2013, 10:11 PM   #12
79Betty
79Betty's Avatar
Re: Dually Swap?
I seen the one in hamilton it looks like just what i need. Except twice what i can afford, and doesn't know the gear ratio. Which is making me look like adapters are way to go. Think i'll hit up pukele see what happens
Old 07-23-2013, 10:11 PM   #13
meatwagon83
Re: Dually Swap?
dude here ya go! in brookville!
http://cincinnati.craigslist.org/pts/3895202836.html
Old 07-23-2013, 10:14 PM   #14
79Betty
79Betty's Avatar
Re: Dually Swap?
I'll see if i can find a set of hubs for that one. I'd love an even trade. But can i put those hubs on my 10 bolt? And it's combined 1/2 ton and 1 ton springs in rear and 4" lift springs in front. So no half ton suspension to worry 'bout
Old 07-23-2013, 10:18 PM   #15
meatwagon83
Re: Dually Swap?
hmm.... probably not, i forgot you didnt have a 60 for a second, i had a brainfart!
Old 07-23-2013, 10:20 PM   #16
79Betty
79Betty's Avatar
Re: Dually Swap?
Lol it's ok. My dually that's a 1 ton which is what i'm gettin parts offa is 2wd > but for 800 in southern indiana and rust free almost i said heck ya!! But i need a 60 first and if i gotta get that, i'd rather go ahead and get a dually one so it's a one time thing know what i mean?
Old 07-23-2013, 10:25 PM   #17
meatwagon83
Re: Dually Swap?
i know what you mean, i am gathering parts to convert my dually to 4x4, but as we can see, the right parts are expensive, and im not useing anything but the right parts! so i have to save my pennies for a dually 60
Old 07-23-2013, 10:37 PM   #18
79Betty
79Betty's Avatar
Re: Dually Swap?
I might have found an option??
http://coloradok5.com/forums/showthread.php?t=255536
Here?
Old 07-23-2013, 10:58 PM   #19
meatwagon83
Re: Dually Swap?
Hmm, interesting
Old 07-23-2013, 11:10 PM   #20
V30 mongo
Re: Dually Swap?
There is a lot of diffrences between a 1/2 ton and a one ton. First thing is the frame. The one ton is a lot deeper and thicker. The steering box to frame connection on one tons was known to fail. What will happen if one ton parts are placed on a 1/2 ton frame? The spring mounts are diffrent. The brake system is diffrent, the one ton uses the hydboost on all of the units. The 14 bolt rear was used on the cab/chassis units. The Dana 70 was used on the pickup models. The track is diffrent from the 14 bolt to the Dana. The wheels will be too close to the frame to use a pickup box on a 14 bolt truck. It is a lot easer to find a junk one ton, even if it's only the frame, and use the 1/2 ton cab and parts to make a truck.....
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers.
V30 mongo is offline   Reply With Quote
Old 07-23-2013, 11:28 PM   #21
rs74
rs74's Avatar
Re: Dually Swap?
That rolling chassis is pretty darn cheap if you ask me. I am getting ready to sell my other 84 K30 parts truck but its not going that cheap.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-24-2013, 12:21 AM   #22
MalibuSSwagon
Re: Dually Swap?
If you are just towing and don't really need the 4WD why not just fix up the 2WD dually?
MalibuSSwagon is offline   Reply With Quote
Old 07-24-2013, 09:20 AM   #23
79Betty
79Betty's Avatar
Re: Dually Swap?
I won't have a 2wd truck. Been there got stuck too many times. I'd rather have 4wd and not use it than need it and not have it. And i'm taking the doghouse, cab, and flat bed off the one ton, Using vacuum brakes From the 1/2 ton until i can convert that over as all that is new to me. It'll all be 1ton pretty much except the frame. I think what will work for me is taking my 10 bolt front, putting 8lug axle shafts in it so it's "3/4" ton, then using dually adapters. It all sounds good in my head lol.
Old 07-24-2013, 09:36 AM   #24
legendman
legendman's Avatar
Re: Dually Swap?
What about car-part.com ?
Try prirate4x4.com too, trouble is they take dually front ends and swap em over to single rear wheel setups for the rock crawlers
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 07-24-2013, 04:50 PM   #25
BONUSCAB
Re: Dually Swap?
"converting" a half ton to a one ton dually sounds about the hardest, and stupidest, way to get a one tone dually. And in the end, you won't be able to tow any more than you could if you left the truck alone. Regardless of what you do, you will never be able to tow more than the truck is rated for on the trucks data plate, what the hitch is rated for, and what the trailer is rated for. You can put all the leafsprings in the world, if the truck scales over what it's rated, you're illegal and a trooper will keep you off the road until you are legal.
What are you towing that you *need* a one ton super dually? And how have you managed to get by up until now?
Here's another thing:
Six new tires: $1200
Used 14BFF: $500
Gear lube, drums, shoes, ect to freshen up that 14B: $250
So now you're TWO THOUSAND DOLLARS out of pocket, and you still don't have a one ton super dually. And you're prolly gonna have to have a driveshaft made.
You can buy running driving C30's for $2000 all day long. Nice ones for $3000 are all over the place.
BONUSCAB is offline   Reply With Quote
dana 60, dually
