Old 10-21-2013, 08:17 PM   #26
wwillmon
Re: Extreme or Mild Dropmember
Man I just need 3 trucks so I can do all 3, well really 4 now haha. How long until that new option is available?
And good to know about tire size, I wasn't sure if the air bag install limited that or not.
And one more question, can the tubular a-arms be upgraded later? Thinking about going ahead and ordering my front dropmember with all upgrades besides the a-arms and then ordering the arms later on, if possible.
wwillmon is offline   Reply With Quote
Old 10-22-2013, 09:04 AM   #27
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes. Nate designed his suspension systems to work with the stock arms. You can always add the tubular arms later.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-22-2013, 10:21 AM   #28
PBFAB.COM
PBFAB.COM's Avatar
Ken-
I need to clarify this a little... the Extreme version Dropmember will work with factory uppers from 63-87 and factory lowers from 73-87 C10 only.
The Mild and Touring variations MUST be run with our tubular control arms.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-06-2013, 01:19 AM   #29
CLTBurban
CLTBurban's Avatar
Originally Posted by Bennett68C10 View Post
Yes I'm using bags and Nate never told me it should only be used for coilovers. If he did I would have just went with the extreme. I felt the touring was just a better option for me personally. Just a note, I'm also running his 1" narrowed arms to narrow my front track width. So with my touring and the 1" narrowed arms my track width is narrowed 1.25" per side, the same as the extreme with regular arms.
I'm running the identical setup on my 72 Suburban as Bennett68C10. Exact same "touring" dropmember, tire height, narrowed PB arms, etc... so I'd have plenty of clearance for my LS 6.0 and 4L80E without having to change more than the tranny tunnel to the big block version. I can confirm what Bennett stated. My set up lays frame with the 28" front tire on 20's, no problem. In fact, my setup is about the exact same phase as Bennett's last picture. Nicely done!!!
'72 GMC Suburban 1/2 Ton (Red)
'68 C10 Short Fleet (OG 503 Light Green and Patina)
'70 C30 Dually (OG City of Charlotte Welding Truck)
Past 67-72's Chevy Trucks
'68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS)
CLTBurban is offline   Reply With Quote
Old 11-06-2013, 01:29 AM   #30
CLTBurban
CLTBurban's Avatar
This is from a month or so ago. Again, that's a PB Touring front dropmember, 2.5" drop spindles, 1" narrowed tube upper and lower PB control arms, bags of course, and 20" wheels with 28" 255/40 20's. The pic speaks for itself hopefully, and that's just on jack stands with no weight on top (engine). All I can say is I LOVE my PB stuff!!! In fact, I'm already saving up for my C30 dually build where I'll be doing pretty much the same setup. My '68 C10 in the picture will be last. She's gonna be something a little special.
Old 11-06-2013, 06:52 AM   #31
Bennett68C10
Bennett68C10's Avatar
Nice setup CLTBurban, your frame looks sweet
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-06-2013, 08:06 AM   #32
CLTBurban
CLTBurban's Avatar
Back at ya my friend!!! Looks like we have the exact same taste!
Old 12-08-2013, 01:47 PM   #33
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Porterbuilt Street Rods View Post
Ken-
Nate
This is news to me. Can you expand on why they won't work? I was under the assumption you were ok to run factory arms unless using coil-overs?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-08-2013, 10:23 PM   #34
PBFAB.COM
PBFAB.COM's Avatar
There is rack to bushing pivot tube clearance issues with the factory lowers on the Mild and Touring DMs. The bushing and stamped steel surrounding it will contact the rack housing on the driver side.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-08-2013, 11:49 PM   #35
gringoloco
A guy with a truck
gringoloco's Avatar
Ah, ok. Thanks. Good to know
-Chris
Old 07-11-2014, 12:33 PM   #36
King Cary
I don't want to let the cat out of the bag yet... but I am also working on an airbag variation that will set the frame just under 1" off the ground as well. For those guys that love the lowered ride height but don't want it to be able to lay the frame all the way on the ground as well.
I know... I threw another option at you. Probably shouldn't have done that.
You can't go wrong with any of the versions... our most popular is the Extreme... second most popular is the Mild.
Nate[/QUOTE]
Hello Nate, I wanted to know if you ever finished the new number 4 top secret drop member? I spoke with Dave a while back on a mild but started thinking about going with an extreme. You have me now thinking about this 4th drop member because I don't really care to lay frame but at ride height on 24's I would love to have the stance of rwade's red and white C10.
King Cary is offline   Reply With Quote
Old 07-21-2014, 11:24 AM   #37
King Cary
Bump
Old 07-21-2014, 02:58 PM   #38
PBFAB.COM
PBFAB.COM's Avatar
Nate
Hello Nate, I wanted to know if you ever finished the new number 4 top secret drop member? I spoke with Dave a while back on a mild but started thinking about going with an extreme. You have me now thinking about this 4th drop member because I don't really care to lay frame but at ride height on 24's I would love to have the stance of rwade's red and white C10.[/QUOTE]
I am not able to dedicate the same amount of time on this forum as I used to. I have one of our team members that monitors private messages and forwards them to the appropriate PB team member. SO if at times I don't respond to posts in a timely manner.... or at all, it isn't intentional.
The best and most efficient way to get a question answered is to use our direct email. Sales@pbfab.com or tech@pbfab.com.
To answer the question, this new DM is close to being released. Feel free to email us for more details if necessary.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-10-2014, 07:27 PM   #39
slowcpe
slowcpe's Avatar
I'm going to bring up this old thread. I've about decided to go ahead and pull the trigger on the mild DM. With a complicated steering linkage am I going to fun into any issues? Has this been changed since the thread started? Any issues with the steering linkage and headers?
Also I'm now curious as to what this new DM entails? Like I need another thing to look into but I don't want to order the mild and regret not waiting for the new DM.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-10-2014, 08:39 PM   #40
Jayschevy
I just recently installed the Extreme Dropmember. I too started out higher but got the itch and had to go lower.
I haven't driven my truck yet but so far I'm happy with the install.
One thing that I will mention that if you do the extreme setup, you will probably have to do electric radiator fans. I'm not sure about the mild DM but the extreme DM raised my engine too high to line the stock fan up with my stock radiator sthroud. I don't know if this applies to a mild DM or not.
I also had to get new headers. My Hedman headers no longer worked because they hit the bottom front of the cab.
Jayschevy is offline   Reply With Quote
Old 10-19-2016, 01:18 PM   #41
ol_skool_chevy
ol_skool_chevy's Avatar
I went with the touring front and extreme rear and I am very happy with my decision. It still will lay frame front and rear depending on your front tire height and what drop spindle you use. I'm running a 28" front tire with 2.5" drop spindles. Right now the front of my frame by the transmission is sitting 1/2" off the ground due to my deep tranny pan laying on the ground. Going to have to change that back to a stock pan. The reason why I went with the touring front is because I'm running a big block/th400 drivetrain and didn't want any clearance issues. Nate told me the extreme would work but I would have more clearance with the touring. I haven't gotten to the steering shaft but I'm confident with the help of some pics and instruction that Nate sent me I can conquer it. A pic of how mine sits.
I wish they would have said there would be clearance issues with mine
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-19-2016, 02:57 PM   #42
bbbc10
Diggin The SquareLife
What you mean clearance issues
bbbc10 is offline   Reply With Quote
Old 10-07-2018, 05:10 PM   #43
nlped
nlped's Avatar
Okay, bringing back an old thread, but I need some help. I have the 5th version Mild dropmember and I’ll be running a 468/700r4. What headers will work with this combo? I searched and didn’t find an answer.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-07-2018, 10:42 PM   #44
gringoloco
A guy with a truck
gringoloco's Avatar
Chevelle big block would be my first choice. Try emailing PB and see what they have to say
-Chris
Old 10-09-2018, 08:16 AM   #45
nlped
nlped's Avatar
I did that, but am still awaiting a response. I may just buy a set of chevelle headers to see if they fit. I can always return them if they don’t work...just out the shipping.
Carter
Old 10-09-2018, 04:10 PM   #46
lolife99
67-72 parts collector,…
lolife99's Avatar
I would assume that’s Chevelle “mid-length” shorty headers.
No long tubes.
At least that’s what works in small block applications.
Keith
Convert to disc brakes.
Old 10-09-2018, 04:14 PM   #47
nlped
nlped's Avatar
^^^ Keith, what’s the issue with long tubes? Remember, I’ve got a mild DM, not an extreme.
I heard back from Nate, but he didn’t actually answer my header question yet, as he wants a few pictures.
Carter
Old 10-09-2018, 05:47 PM   #48
lolife99
lolife99's Avatar
Most long tubes hang below the frame rails
I’m not sure how much the B.B. engine gets raised, from the factory position, with the mild or extreme Dropmember
Keith
Old 10-09-2018, 05:49 PM   #49
lolife99
lolife99's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=533692
Keith
Old 10-09-2018, 06:46 PM   #50
nlped
nlped's Avatar
Thanks Keith, I’d already read that thread and that was one of the reasons I was leaning towards Chevelle headers. Just hadn’t seen a definitive answer on them with this DM. I just heard back from Nate and he confirmed they have been used by others. So, I ordered a set of Flowtech 31130BLT’s. I should know by Thursday evening if they’ll work.
Let me clarify, I bought blend directly from Holley for half price.
Carter
