Old 01-30-2015, 08:47 AM   #26
Andy4639
Old member
Andy4639's Avatar
Talking Re: truck intake cover idea
Looks nice. Should set off the motor when installed for sure!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-16-2016, 06:50 AM   #27
mcmlxix
Collector of Projects
mcmlxix's Avatar
Has anyone tried something along the lines of a mini L88 scoop as a cover?
Rich
1972 K5 Blazer CST Click HERE
Old 05-16-2016, 02:14 PM   #28
XwalkerX
interested to see some other cover ideas.
im just not a fan of that tiny vortec cover and even less of a fan of going no cover.
XwalkerX is offline   Reply With Quote
Old 05-16-2016, 02:40 PM   #29
Robznob11
Robznob11's Avatar
Here is the finished product with the homemade BBC coil covers.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-16-2016, 03:01 PM   #30
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: truck intake cover idea
Sweet! Looks like it was made for it!
Old 05-16-2016, 05:28 PM   #31
Custom 68
Custom 68's Avatar
Nice detail work.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-18-2016, 12:39 AM   #32
mcmlxix
mcmlxix's Avatar
That cover looks great Rob. Where did you get the 6.0L emblems? Are the GM or eBay specials and how the quality?
Rich
Old 05-18-2016, 06:24 AM   #33
Robznob11
Robznob11's Avatar
EBay specials. They are nice. The chrome one's are thick and heavy metal. The others Are made of thin aluminum also very nice.
LED TAILS
Old 05-18-2016, 08:38 PM   #34
Andy4639
Old member
Andy4639's Avatar
I like your M/T's too man nice touch. Do you have any close ups of them?
Old 05-19-2016, 11:47 PM   #35
Robznob11
Robznob11's Avatar
Here you go Andy, you can kinda see how I cut BBC covers. I marked the plugs 1st and used a 1" hole saw to drill 4 holes in the side. Then I drew my lines and used a cut off and grinder to trim them down. Cleaned them with a flap wheel and removed the oildrippers on the inside. Wetsanded and polished the fins. Then I taped them and painted them. The emblems look cool but also cover the dead space on the cover as well as the original breather holes. Basically I got some 1" deep nuts from the hardware store and some Allen head bolts that would thread in them. I then just put 2 nuts over 2 of the studs that stick up on the coil fastners. I just tacked them in place. That way I had threads to screw the Allen heads into to fasten them to the coil bracket. The driver side is trimmed on back because I set my engine back and reworked my firewall. If you look close you will also see my booster is relocated and my steering column is moved up 3" this was all do to channeling the body down 3" over the frame. A body drop looks cool but space becomes scarce. Lol
LED TAILS
Old 05-20-2016, 08:20 AM   #36
Andy4639
Old member
Andy4639's Avatar
Cool! Thanks man. Love the look.
Old 05-20-2016, 09:44 AM   #37
66ChevyMax
66ChevyMax's Avatar
I love the coil covers, great job now you have a 1 off!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 05-20-2016, 10:56 AM   #38
Robznob11
Robznob11's Avatar
Lol! Thanks! A lot of my truck is one off!
LED TAILS
Old 05-22-2016, 02:03 AM   #39
vics stuff
After seeing what you had done with the big block valve covers . I think that I will look at doing the same .
Thanks Vic
vics stuff is offline   Reply With Quote
