Old 04-04-2014, 08:08 PM   #26
mud.man.rj
mud.man.rj's Avatar
Re: 86 GMC, Porterbuilt Mild front and rear
Be extra nice to see the gauges lit up I bet.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 05-14-2014, 11:05 PM   #27
bigguy
I haven't been able to get much done lately, I've been dealing with a broken ankle. Anyways, I did find a bunch of pictures from the first build of my 86!Name:  017.jpg
bigguy is offline   Reply With Quote
Old 05-14-2014, 11:08 PM   #28
bigguy
Old 05-14-2014, 11:19 PM   #29
bigguy
This is how the truck looked when I first bought it.
Old 05-15-2014, 12:53 AM   #30
mud.man.rj
mud.man.rj's Avatar
Easily twice the truck now than the before pic, which was still nice.
5.0 4spd std.
7" lift w 35's.
Old 05-15-2014, 02:43 AM   #31
tinydb84
tinydb84's Avatar
Do you have any pics of you raising the bed floor? Or closer up pics of the mounts??
Truck looks amazing.
David
Instagram: myfabguy
Old 05-15-2014, 08:25 AM   #32
bigguy
Thanks Mud Man. Tinydb84, I can get you some pictures of the bed floor. It was pretty simple. The floor unbolts from the sides and bulkhead, then there are several spot welds at the front. I measured how high I needed to raise which was 7 1/2", and welded in a support at the front of the bed (tailgate side). I welded the floor to the sides instead of bolting it back in, but you can always just drill more holes and run bolts. As for the tubs, I cut 1/4" off the inside that mounts to the bed side. This makes it fit flush with the bed sides, then bolted it back to the bed floor. Seam sealed and raptor lined.
Old 05-16-2014, 05:29 PM   #33
tinydb84
tinydb84's Avatar
Thank you for all the detail. I have seen pics of people doing it but haven't got any details.
I am leaning towards welding it. Did you do a series of tacks or beads? I don't want to tack 20 feet of metal but don't want to warp anything.
More pics would be awesome.
David
Instagram: myfabguy
Old 05-16-2014, 07:24 PM   #34
bigguy
I plug welded where the bolts used to be. It's pretty thick metal so no worry about warping. I did bolt it back to the bulkhead tho. Then I made some spacers to mount the bed. I will take some pictures tomorrow.
Old 05-16-2014, 07:33 PM   #35
tinydb84
tinydb84's Avatar
Awesome man. I appreciate it!
David
Instagram: myfabguy
Old 05-17-2014, 12:11 PM   #36
bigguy
I used self tapping screws to hold in place when I welded. I need to coat the underside. The yellow stuff on the bed is pollenName:  20140517_112400.jpg
Old 05-17-2014, 06:26 PM   #37
tinydb84
tinydb84's Avatar
Thank man! Helps a lot. Doesnt look as much work as I thought it was going to be.
David
Instagram: myfabguy
Old 06-07-2014, 10:04 PM   #38
bigguy
Got some work done today. Cut off the pinch weld and made a firewall filler panel. 16ga steel, rolled on my beefed up harbor freight bead roller.
Old 06-08-2014, 08:18 AM   #39
northeimcustom
northeimcustom's Avatar
awesome build! in the picture in post #25, do you have air gauges mounted in the upper part of the dash? what size are they?
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 06-08-2014, 08:53 AM   #40
bigguy
Thanks! The gauges are 2" dual needle. I cut a piece of aluminum plate to fit the opening were the a/c vent was.
Old 06-08-2014, 10:23 AM   #41
bbbc10
Diggin The SquareLife
looks good!!! I need some of them firewall panels been thinking bout getting a beadroller but never used one before
bbbc10 is offline   Reply With Quote
Old 06-08-2014, 01:29 PM   #42
bigguy
I hadn't used one before either. Just gave it a shot. I had my wife turn the handle while I kept the panel straight. There are a few imperfections, but nothing that can't be fixed.
Old 06-10-2014, 09:14 PM   #43
rip2174
Nice looking truck
rip2174 is offline   Reply With Quote
Old 06-16-2014, 08:04 AM   #44
bigguy
Thanks rip2174! Got started on the firewall this weekend. It's hard to see, but I used aircraft remover to strip the paint. Name:  cid_575.jpg
Old 06-30-2014, 01:34 PM   #45
bigguy
Tubz!
Old 06-30-2014, 02:16 PM   #46
79azc10
Looks great
79azc10 is offline   Reply With Quote
Old 06-30-2014, 07:43 PM   #47
rip2174
can you post more pics of the tubz. thinking about buying them. they pretty easy to install
Old 07-02-2014, 08:34 AM   #48
bigguy
If you tell me what you're wanting to see, I can take pictures for you.
Old 07-02-2014, 11:17 AM   #49
rip2174
looking from the hood in?
Old 09-23-2014, 07:17 PM   #50
bigguy
It's been a while since I've worked on the truck. Here's a shoot from the top of the tubs. I have been building a small garage for it as well. Name:  20140920_190252.jpg
headers, steering
