04-20-2014, 11:13 PM | #26 |
SWB 4x4 Collector
Re: Project: Big Grapefruit
I think I may change my frame plans and rob the 4x4 pieces off mine now to this one.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-21-2014, 10:38 AM | #27 |
Long wheel base 1 ton frame would get my vote! Would you build a dually 4x4 going this route?
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
04-21-2014, 01:04 PM | #28 |
Comin' along nicely, nice idea on the frame.....
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-21-2014, 07:04 PM | #29 |
SWB 4x4 Collector
It will still be a crew short bed 1 ton srw.... Looking it over I might be able to get away with chopping the frame at the back end and scooting the up the spring perches. It will be close. Trevor
05-04-2014, 09:58 AM | #30 |
Just like to part out trucks!!
Your doing awesome Trevor!!!!!!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
05-06-2014, 02:34 PM | #31 |
Did you decide on what your going to do for the headliner(s) Trevor? Project is looking good man! Nice work!
05-06-2014, 07:46 PM | #32 |
SWB 4x4 Collector
Hey jamie, thanks for your pics again. The way you have yours is how I had it imagined in my head, but I have also thought about stretching the cab to 2 full doors on each side and finishing off both doors in the truck curve but have the squared off burb front. That way you could use factory trim and I could run two front door panel setups. If I go that route, I may stretch the headliner to one larger single headliner and fab up the custom factory looking trim. Trevor
05-06-2014, 07:48 PM | #33 |
6>8 Plugless........
Awesome work on your cab! I think my next project for the winter will be the same thing. But I'm thinking DRW and using my 72 for the rest. Going with that 1 ton frame is a good idea too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-06-2014, 08:21 PM | #34 |
TNT-MOTORSPORTS
Looking like a super start ...... !!!! I vote for full size rear doors.... That is how I want to do one.
05-06-2014, 09:01 PM | #35 |
Junk Yartist
Man, I love these crew cabs!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
05-06-2014, 09:41 PM | #36 |
X2, that is how I plan to do mine or like a mega cab.
05-07-2014, 10:07 AM | #37 |
Luv the Crewcabs
Great Start,Along for the ride............
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
05-07-2014, 04:11 PM | #38 |
I'll ride along. What size lift and tires are you going with this one?
05-11-2014, 10:17 PM | #39 |
SWB 4x4 Collector
No new pictures yet, but did acquire my new c30 157" frame and my new srw axles. Progress will be slow between working on my brother in laws 76 k5 converted to a 73-75 convertible, this truck, and my busy season at work. That's what you get when you are your own fabricator and body man. Trevor
05-11-2014, 11:02 PM | #40 |
The full size (or nearly so) doors do change the look visually a lot.
The 157" numbers out very close for a 42" stretch cab (Scott-Bilt style) and a short bed. Need to remember that the axle kickup is higher on a 157" frame than a 133", 3" IIRC. Something I had looked into wanting a 149" wb C30 frame. PM me you email for a couple of drawings to reference. Now here is an unknown assumed period crew cab conversion I found that appears to have the modifications you are debating. IIRC it was on the board here, my thought is it might be a Stageway and if I can locate the post I'll link it. Finally here is a quickie "what if" chop I did years ago before we out grew a shortbed.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-12-2014, 08:41 PM | #41 |
SWB 4x4 Collector
Thanks Tim, after measuring the kick up, the top of the rails measure about 1 1/2" above the half and three quarter ton frames. I still think it is the best platform to use for length and strength for a diesel crew. This one is huge. Those 8" rails are massive and the frame is every bit of 20 ft.
05-12-2014, 08:59 PM | #42 |
Can't agree more. The 157" frame is the king of the LD truck frames (8.18" section height, 2.97" flange width, 0.224" thick, 7.29 section modulus).
Numbers work out to about 99% stiffer than a K20 frame, but then even a C20 (127") frame is about 8% stiffer than a K20. Don't remember the kickup being that minimal but go with what you see. If you are doing a 4x4 conversion I have some thoughts I'd like to run by you.
05-12-2014, 09:33 PM | #43 |
SWB 4x4 Collector
Hey Tim, I'm all ears, so shoot away or pm me. I ran a straight board across the top of the highest part of the rear frame and measured down to the middle portion of the frame. It was about an 1/8" from being 7" of kickup and measured my 3/4 and it was if I remember right, 5-5 1/2". I'll remeasure that tomorrow. Trevor
05-12-2014, 10:36 PM | #44 |
what level of effort will go into this frame to make it work for your needs? the reason i ask is from my own experience. if i was to start over and i wasnt working on a truck that was of some sentimental value, i would just scratch build the frame. i dont know if you have looked at mine or not, but i have boxed the K20 frame front to rear. given the amount of work that was vs the end result of building a frame, i would go full custom fab next time.
05-13-2014, 06:26 AM | #45 |
SWB 4x4 Collector
Hey Ryan, I'm going for more of a stock build with my truck. Trying to incorporate the strongest parts offered. I don't plan on doing any unnecessary boxing of the frame. The drive train will be a stock duramax, after much back in forth thinking, and tied to a nv4500 and np205. I feel pretty confident this frame will withstand my light abuse and be more than capable to tow with. My modifications will include removing all 4x4 specific brackets and rereviting them to this frame and if I need to add any cross members along the way. This is definitely more beef of a frame compared to a longhorn c30 frame or 3/4 ton frame. Trevor
05-13-2014, 07:26 AM | #46 |
sounds good! what are you plans for hooking the 4500 to the duramax? i have no idea if they offer that BH, or what pattern the Dmax used or any of the details there.
05-13-2014, 07:12 PM | #47 | |
05-13-2014, 08:14 PM | #48 | |
05-18-2014, 12:13 PM | #49 |
I'm on board. Great looking work so far!
05-18-2014, 12:31 PM | #50 |
Got my attention here too.
