Old 12-15-2014, 10:44 PM   #26
jhama78
jhama78's Avatar
Re: Project Simple Green - Lucille - 1967 C10 Porterbuilt/AccuAir
Sub'd.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 12-16-2014, 11:08 AM   #27
sixSEVENcTEN
sixSEVENcTEN's Avatar
Kinda surprised you didn't replace the old dizzy and coil with an upgraded unit.. but the rest looks nice!
Well i just wanted to get everything working like it did back in '67. I'm 99% sure i'm going to swap over to HEI sometime before show season next year.
Kelley
1967 C10 LWB Fleetside - Original 283, Muncie 3-Speed on Column -Porterbuilt Stage 1 Front / Stage 2 Rear Accuair E-Level iLevel - GM Transit 22s w/ '52 caps
Project Simple Green the build of Lucille - http://67-72chevytrucks.com/vboard/s...d.php?t=650871
sixSEVENcTEN is offline   Reply With Quote
Old 12-16-2014, 11:30 AM   #28
sixSEVENcTEN
List of parts either refurbed, replaced, serviced while at Shop #1 (my buddy's place with the old scissor lift):
Motor rebuilt (.060 over, Comp Cams Thumper Cam, Edelbrock Intake, Holley 4-Barrel, Headman Headers)
Rear Diff Serviced (open, 3.73 and staying that way)
Shifter Linkage/Bushings Refurbed
New Clutch and all associated parts
New U-Joints
New Driveshaft Bearing
Front Manual Drum to Power Disc Conversion Installed
Rear Drums Rebuilt
Front upper and lower Control Arms Refurbed
Heater Core Replaced
New Radiator
New Alternator (100 amp if i remember correctly)
2.5" Lowering Spindles
22 GM Transit Wheels and 265/30r22 tires
The Ol' 3-Speed, 283 (well now a 292) ass shot!
Vitals:
Here it is when I got it back to my folk's place. Came home about 15 miles with headers dumped through about 2 feet of pipe!
Where the rest of the work is going to happen:
Kelley
Old 12-16-2014, 12:01 PM   #29
sixSEVENcTEN
Appears to have been a workhorse back in the day. Won't be needing the spare or overload spring anymore.
Time to get to the rear suspension! Porterbuilt Stage 2 Basic (bolt-in notch, adjustable panhard bar, bags, cups, rear crossmember). Too sweet of a view, always good to step back and soak up a little sense of accomplishment (yeah taking the bed off is a milestone!).
Removing Old Rivets with an Air Chisel (best method by far IMO). Thanks to Porterbuilt for designing things such that they re-use old rivet holes!
Kelley
Last edited by sixSEVENcTEN; 12-16-2014 at 12:14 PM. Reason: added one more underbody pic
Old 12-16-2014, 12:17 PM   #30
sixSEVENcTEN
Work continues:
Kelley
Old 01-11-2015, 12:54 AM   #31
kitsbeach
kitsbeach's Avatar
Show us some more..!!
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 01-11-2015, 02:37 PM   #32
Willys47
Willys47's Avatar
I'll watch as well
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 01-11-2015, 07:59 PM   #33
mooseknuckles
mooseknuckles's Avatar
hurry, I'm having withdrawals...
mooseknuckles is offline   Reply With Quote
Old 01-19-2015, 04:50 PM   #34
sixSEVENcTEN
Notch and Crossmember Installed (minus lower shock mount and Panhard Bar):
Rear Bag Installation:
Due to the fittings that came with my PBFab/AccuAir package I had to modify the cups slightly.
BEFORE Porterbuilt Tank/Compressor Mount:
AFTER Porterbuilt Tank/Compressor Mount:
(Temp Rear Air Plumbing sticking through in this shot. Hard to find a quick-connect schrader valve set-up. GET A COUPLE FROM AMAZON.com in advance and save yourself from some local begging which is what my Friday afternoon consisted of)
Rear Done (Minus Lower Shock Bar):
Stage 2 Getting DOWWWWN! No bump stops, cheating a little!!
I dont mind showing off my Year of Manufacturer Plate. SCDMV was awesome to deal with. I literally had the lady at the DMV on the phone while I was browsing eBay deciding which vintage plates I could use. I'd say "what about this?" and she'd yay or nay it. Pretty cool process.
Kelley
Old 01-19-2015, 05:26 PM   #35
sixSEVENcTEN
Front Bag Installation:
Just remove the u-bolts holding the inner shaft of the lower control arm, made it really easy.
Go ahead and remove the lower bump stops, they will contact the bag! Got them off pretty easily with the air chisel after drilling the spot welds.
Shock mounted:
Front Aired Out:
Ready to go get the exhaust on!
Kelley
Old 01-19-2015, 07:06 PM   #36
RRR18
RRR18's Avatar
Love it! I'm interested to see the headers you used that I think you said fit horribly?
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 01-20-2015, 11:56 AM   #37
lowlyfec10
IN! love the mint green patina!
lowlyfec10 is offline   Reply With Quote
Old 01-20-2015, 12:05 PM   #38
Justin@EntropyRad
Justin@EntropyRad's Avatar
Originally Posted by RaceAGMC View Post
Hi from Charlotte...I frequent Mooresville all the time. I'll be checking on this build.
He really does..I've seen him do it!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 01-23-2015, 12:58 PM   #39
sixSEVENcTEN
****'s a mess in these pics, but should give you an idea. They are Hedman Headers, can get the part number if needed. The driver's side contacted the frame and required some massaging of the frame (Photos 1 and 2). The passenger side flange had to be cut due to contact with the crossmember (Photo 3).Bottom line is that i love the look of them, aged instantly and the metal tag/label on them is awesome looking. They sound great as well.
Kelley
Old 01-23-2015, 01:00 PM   #40
sixSEVENcTEN
Thanks lowlyfec10! 503 Green is a pretty sexy color!
Kelley
Old 02-21-2016, 03:40 PM   #41
SKT
SKT's Avatar
Sharp looking truck - any updates?
SKT is offline   Reply With Quote
Old 02-21-2016, 08:18 PM   #42
RRR18
RRR18's Avatar
Watching....got family in Statesville and Mooresville.
'67 BAD IDEA
Ryan
accuair, c10, patina, porterbuilt
