Old 02-09-2017, 12:19 AM   #26
MP&C
MP&C's Avatar
Re: 1947 Biederman Truck Fender repairs
Doing a test fit of the Biederman fender....
Was going to do a little bit of touch up on the front weld seam, needs more shape..
The fender spans about 53" at the bottom, where it wouldn't fit in the wheeling machine sitting on the floor. We added a lift kit under the legs, except for one which needed to be open under the leg..
in process....
https://www.youtube.com/watch?v=IvsAkBLlG2o
Needed to wrap the wire edge....
Note the genuine John Deere anvil...
The flange was hammered over using various hammers and dollies (anvils) with the final wrap tightened up with a pair of vise grips modified with smooth jaws...
Robert
MP&C is offline   Reply With Quote
Old 02-09-2017, 05:45 AM   #27
Advanced Design
Advanced Design's Avatar
Nice work Robert. I like the John Deere anvil. The owner must be really pleased.
Advanced Design is offline   Reply With Quote
Old 02-15-2017, 11:51 PM   #28
MP&C
MP&C's Avatar
Thanks, I hope so!
The rear flange for the Biederman fender is cut out of some 12 gauge steel and tacked in place..
This flange bolts to the front of the running board..
The front mounting flange is cut out of 12 gauge steel and tacked in place..
This flange bolts to the filler panel behind the front bumper.
With them tacked in place, we'll do one more test fit and then finish the welds.
Robert
Old 02-17-2017, 08:28 AM   #29
MP&C
MP&C's Avatar
Test fit the Biederman front fender to insure we had no clearance issues..
Rear flange to running board:
Front flange to bumper filler panel:
Looks like we're ready to finish welding...
Robert
Old 02-17-2017, 09:29 AM   #30
flashed
Looks great ,cant wait to see more .
flashed is offline   Reply With Quote
Old 02-20-2017, 10:28 PM   #31
MP&C
MP&C's Avatar
Thanks!
The flanges were TIG welded in place, welds dressed, and then worked to remove the remnants of the old filler panel. The old spot welds were removed using a cut off wheel in a die grinder. When the upper panel gets thin, the heat turns it blue. When you see shiny metal again, you have found the second layer, so stop grinding!
This video explains the process a bit better...
https://www.youtube.com/watch?v=nb49MgRPzvY
Next to clean all the rust that was hiding between the layers. A tight squeeze!
The filler panel we fabricated was positioned, and drilled for some 1/8" cleco's. Then another test fit:
https://www.youtube.com/watch?v=evBQvi5dsnw
Robert
Old 05-12-2017, 06:42 AM   #32
MP&C
MP&C's Avatar
Been away for a bit across the pond, finally back to some metal work.
Had a fenderless trailer showed up at the shop Wednesday night, needed some welding... Good time as any to try out the new clamps. Two held the fender nice and tight to the frame.
Last night we worked on the fender patch #2 for the Biederman truck, 16 gauge fun!
https://www.youtube.com/watch?v=VXjl...ature=youtu.be
Missed the in process pictures, I'll try and do better next time..
Robert
Old 05-12-2017, 07:17 AM   #33
GR8-68
GR8-68's Avatar
Sweet build, love the fab work you have done
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-07-2017, 11:19 PM   #34
MP&C
MP&C's Avatar
Thanks Larry!
Some more progress on the Biederman fenders, here's where we left off last time...
On the passenger fender, we removed the cleco's holding the filler panel and John (the owner) media blasted the flanges where the panels overlapped..
Cleco holes were enlarged on the filler panel flange to accommodate plug welds and the two parts welded together...
After grinding the welds, John brushed some SPI epoxy in the lapped panels to seal them up..
Back on the driver's fender, time to trim off the rusted and bent front edge....
The door skin removal tool is used to unwrap the wired edge...
Once the wrap is broken free, the top is scored with a cutoff wheel and then peeled around. No cuts on the wire as this may weaken it..
Trimmed and clamped in place for a test fit..
Robert
Old 06-08-2017, 11:10 PM   #35
MP&C
MP&C's Avatar
This evening we took the passenger fender over to John's so we could mock it up on the truck and locate/cleco it to the lower hood side..
The wing nut cleco's used in about four spots to hold things good and snug....
Back at the shop, we'll get this plug welded on Saturday..
Robert
Old 06-12-2017, 12:19 AM   #36
MP&C
MP&C's Avatar
tried to make some headway on the Biederman. John is taking it to the truck show in Macungie PA so we're trying to get the fenders complete so he can bolt them on and answer questions all day about their bare finish..
With the lower hood side cleco'ed to the passenger fender using wing nut clecos to pull things up nice and tight, lets get some plug welds done to join all three parts together...
Passenger fender lapped seams then had SPI epoxy brushed in from both sides to seal in case he runs into rain. We he returns they'll be ready for media blasting and paint..
Next onto the Driver fender, the remainder of the flange from the old filler panel is removed, a cut off wheel is used for releasing the OEM spot welds..
Next, we had a rub issue where the fender was a bit close to the cab....note the flat area, as well as a rust through. So we'll just trim this out and replace..
Robert
Old 06-12-2017, 12:30 AM   #37
MP&C
MP&C's Avatar
Today I finished up the TIG welding on the rust repair...
This area has a recess so it doesn't rub the side of the cab...
Next to clamp the front repair section, the vise grips tend to rotate after clamped and allow the weld joint to open. So to fix the gravity issue, we broke out the painters tape..
16 gauge sheet metal wiring, gotta love it!
Next time we'll get the filler panel added to the Driver's fender..
Robert
Old 06-12-2017, 07:05 AM   #38
flashed
Love this build ,thanks for sharing with us here .
Old 06-12-2017, 11:32 PM   #39
MP&C
MP&C's Avatar
Thanks for your comments!
This evening's progress, the bolting flanges were cut out of 12 gauge steel, and tacked in place using the TIG. Then welded and dressed..
Next to trim the front of the fender, a laser is set up 13-3/4" above the table holding the fender. This is the differential we measured off the truck from the bumper filler panel down to the running board. all four corners on the table are checked to insure the laser is set correctly. Then the laser line is transposed to the fender and trimmed..
The height was adjusted by sliding the blocks forward/backward in the fender.
Front mounting flange TIG welded in place and welds dressed..
Filler panel fitted to the fender and plug welded...
Test fit onto the truck, aligned to the lower hood side and cleco'ed in place.
We'll get the lower hood side welded on tomorrow evening, holes drilled, and fenders bolted up to the truck.
Robert
Old 06-13-2017, 10:33 PM   #40
MP&C
MP&C's Avatar
Tonight we got the lower hood side plug welded to the driver's fender, then the lapped seams were brushed with SPI epoxy primer from both sides to seal out the elements. John will be taking this to a couple shows with the fenders in bare metal, so we needed to seal those areas.
With the fenders all one piece again, we took them to John's shop for re-assembly. First order of business is to add some welting to the fender area adjacent to the cab's lower cowl area...
..then bolted up the fenders and battery tray.. This should give John a head start on the finishing touches tomorrow before loading it up for the Macungie Truck show.
Robert
Old 06-14-2017, 06:54 AM   #41
flashed
Very nice work .
Old 06-16-2017, 10:48 PM   #42
MP&C
MP&C's Avatar
Thanks!
John got the Biederman out into the sunshine Wednesday after a long hibernation, getting it ready to take to the truck show in Macungie PA.
Loaded up and ready to go....
Today's pictures from the show, the Biederman makes its debut. Still needs a bit more paint on the front end, but John said he's had a ton of interest in the truck and the bodywork 0 Guess I should have sent him up with business cards.
Robert
Old 07-30-2017, 11:45 PM   #43
MP&C
MP&C's Avatar
Stopped by John's shop today, he had dropped off the front fenders to his painter after the Macungie show for media blasting and a epoxy primer to protect them until we can get the hood resolved. Then he'll get all the new parts painted blue at one time...
Here's the newly installed fenders with an epoxy finish..
Robert
Old 07-31-2017, 12:21 AM   #44
truckster
truckster's Avatar
That is absolutely amazing. I am awed by the skill some people have working with metal. I don't know whether to be inspired to try new things or discouraged that I have nowhere near that level of skill.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-31-2017, 06:47 AM   #45
flashed
Very nice work .
Old 07-31-2017, 04:50 PM   #46
Russell Ashley
Russell Ashley's Avatar
Not even a question for me, I know I have nowhere near that level of skill, LOL. I read all of MP&C posts to see all of the cool things that I don't know how to do.
Russell Ashley is offline   Reply With Quote
Old 08-05-2017, 10:49 PM   #47
MP&C
MP&C's Avatar
Thanks for the comments guys! I'd say about ten years ago you wouldn't have seen me tackling these fenders. If this looks like something you want to do, there are metal shaping classes available in many parts of the world...
Robert
Old 04-20-2018, 08:53 PM   #48
MP&C
MP&C's Avatar
Today we started fabricating the new hood for the Biederman truck. During restoration John had bought a replacement cab with less rust issues that was a couple years newer, and unfortunately slightly wider as well. Since the original hood did not sit down where the bead details aligned, we're going to fabricate a new one that will fit correctly.
Doesn't look like these are going to fit either. Me and dominoes..
Hood is removed and a paper pattern taken for starting point of the new one. Slight bit more material will be added for good measure..
pattern laid out on 16 gauge cold rolled steel.
A straight edge finds the start of the radius on either side, marked with tape, and measure to find the center of the radius. Then the radius center and widths get marked onto the new panel.
the panel was wheeled to add a slight bit of crown prior to switching to the go kart slick for adding the corner radius.
Both sides formed, ready for trimming..
Video version:
https://www.youtube.com/watch?v=xBiwtrWioFs
Robert
Old 04-20-2018, 09:36 PM   #49
mongocanfly
Post Whore
mongocanfly's Avatar
once again...amazing...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-21-2018, 09:03 AM   #50
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I’ll repeat, amazing!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
