Old 04-23-2018, 04:46 PM   #26
BBPanel
Re: Need Parts please!
Anyone used Auto City Classic for their one-piece door glass - how did it fit? I'm wanting tinted glass for all pieces and feel like I need to get them from same vendor to get consistent shading. Thanks. -Bob
BBPanel is offline   Reply With Quote
Old 05-20-2019, 10:46 AM   #27
LDO
LDO's Avatar
Originally Posted by ptc View Post
I finally got my doors to a place; THANK YOU DAZE57!!!! ----- where Im ready to start assembly of the window power regs, guide channels and felts all into place.
I ordered from Restoration Specialties and Jeff is the best guy to talk with about this stuff he knows what it requires EXACTLY....
to answer the question below : the original setup used 3/16" glass - many of the new kits are using 1/4" tempered glass that is available already cut from many sources now, so that felt is wrong, then the 10M96 is also a very hard fit to get into place, its real snug and can pinch the window as it goes up:
Then ----- IF you are using the wing window division bar and cutting it down to fit as the front glass guide, then it requires a DIFFERENT FELT than the rear felt. If your not doing this then disregard this whole thing.
The DIV BAR is only .58" wide x .55" Deep channel - you need 2' of this felt
The Rear and top are .75" wide x .50" Deep channel- you need 6' of this felt
Jeff will set you up with whatever you need but this is the setup and he provides the wiper felts also. Once I receive them Ill post them up.
Any updates on the channels and felts?
LDO is offline   Reply With Quote
Old 05-20-2019, 11:58 AM   #28
Daze57
Daze57's Avatar
ptc
You are more than welcome .......glad things worked out !!!!
Daze57 is offline   Reply With Quote
