01-09-2018, 01:18 AM | #26 |
All about them K’s
Re: Pa. state inspection failed.
I don’t miss emissions or safety inspections at all... nope not one bit. I do however still keep up with the maintenance and repairs on what we drive. I sometimes wonder how many people around me on the roads do the same.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-09-2018, 02:51 PM | #27 |
We no longer have vehicle inspections here in SC. Thank God for that. Cars that are found in violation of any safety equipment laws and cited by police provide more revenue for the state than the inspection stations ever did. The inspectors in the last two years before the law was repealed would find ANY reason not to pass you. Now there is no more way for them to extort more money from customers. And we have never had an emissions law.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
01-10-2018, 12:22 PM | #28 |
Location: Formerly MD and San Diego, now loving life in Arizona
I remember those Maryland inspections, not too bad if you were aware enough to get things right before the inspection. Back when I grew up in Maine we had yearly inspections, mostly safety gear and steering tightness along with no "thru" rust from exterior of body to interior.
In Guam, the inspections consisted of a light check, a horn check and an alignment check where the vehicle was slowly driven over a set of plates, with hands off the steering wheel, and gauges attached to the plates were monitored to prove good alignment. If the gauge needle deflected past a certain point, you failed. Now living in Arizona, there are no vehicle inspections, but the county I reside in has emissions testing on everything 1967 and newer. We have tried to change the law to a more typical 25 years old and newer type rule, but the nay sayers refuse to budge making our emissions testing worse than Kalifornia.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
01-12-2018, 11:24 AM | #29 |
Just a follow up, I finally got around to pulling the gauge cluster out and checking the bulbs. High beam bulb was missing, easy fix. rigth turn signal bulb holder has a broken brass prong, I used another one from just the dash light section. I cleaned copper circuit board connections where the holder locks in. Every thing is working now, I just need to get another bulb holder at the junk yard for the missing one I used.
01-12-2018, 12:22 PM | #30 | |
Some counties do have/require inspection..my neighbor sold a truck to a friend of mine from Chattanooga....it wouldn't pass their inspection..she brought it here and registered it... we do love Tennessee...!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-12-2018, 01:18 PM | #31 | |
Daily Driver: 1972 K20 Project: 1967 Buick GS 340 |
01-15-2018, 11:52 AM | #32 | |
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-15-2018, 12:10 PM | #33 | |
The Older Generation
While you are doing that, check the ground wire for the cluster and make sure it is connected and making good contact. Wiggle the clip back and forth or pull it off and re-install it to make sure the teeth are biting into bare metal. LockDoc
