Old 01-13-2018, 11:23 PM   #26
Robertc10
Re: drum to disc brake conversion
Lots of info here.
Sounds like you have a 67-70 frame.
Without pics it’s hard to tell.
If there’s no indent behind the steering box it a 67 frame.
If there is it’s a 68-70 frame.
These trucks are old.
Lots of parts have been changed.
Please post several pics of your suspension.
Steel brake lines connect to the rubber hose behind the crossmember on 67-69 trucks..
In front of the crossmember on 71-72 truck.
I’ve been preaching “63-70 conversion spindles” for many years now.
I’m not sure why this info is not getting out.
There’s no need to use 71-72 or 73-87 spindles.
These conversion spindles are the same price and require no balljoints or tie rod changes.
Buy from places like Summit Racing that offer free shipping.
I like ECE (www.earlyclassic.com) for 67-72 parts.
But wilwood, mcgaughys, western chassis, belltech, and even CPP make good spindles.
Hope this helps.
Get the word out to use Conversion spindles!
Thanks for the reply lolife99 I will try to get some pics tom. it is currently 14 degrees and about 6" of snow out here now and dark lol I do not have a garage but do have a carport I am working on the truck under. I would much rather buy the correct year model conversion spindles to start with that is why I have put it off for so long now doing my research.
Robertc10 is offline   Reply With Quote
Old 01-14-2018, 05:20 PM   #27
Robertc10
Without pics,... all this info could be wrong.
I remember trying to help a member through many pm’s back and forth for many days before he finally took some pics. In the end, his truck already had drop spindles, and it had been changes to 73-87 parts by the previous owner.
But I’ll be glad to help with any questions you have.
We just need to figure out what’s on your truck now.
Old 01-16-2018, 10:03 AM   #28
Robertc10
Lots of info here.
Hope this helps.
Here are some pics https://imgur.com/a/fD9Uz
Old 01-16-2018, 11:05 AM   #29
lolife99
67-72 parts collector,…
lolife99's Avatar
Everything looks original.
Can’t tell about a frame dimple behind the steering box, but I would guess a 68-70 frame due to the location of the rubber brake hose connection point behind the crossmember.
Upper balljoints are original.
I still recommend 63-70 conversion spindles.
I’m guessing someone did a cab swap to this older frame.
I would look at rebuilding the front suspension also.
Keith
Convert to disc brakes.
Old 01-16-2018, 11:31 AM   #30
Robertc10
I'm thinking the same thing. I will try to get some better pics but I wouldn't think drum brake spindles would work with 71-72 tie rods and ball joints if they are different correct me if I am thinking wrong? The truck does have power steering if that makes any difference in determining anything. I thank you for all the help! I have a long way to go I bought a auburn limited slip rear carrier and 373 gears I have to install soon and the trailing are pads/seats on the rear diff housing are about rusted off so I still have plenty to buy. The previous owner already bought rear lowering springs I think 3" but heated the front now I need to determine what springs to buy for the front if I go with the 2.5" drop spindles. I do not really want it slammed just lowered to my liking so I got a lot of figuring to do lol I do have plans of rebuilding the complete front end just buying a few parts at a time as I save the money!
disk brake conversions, drop spindles, drum brakes, spindles
