Old 03-19-2018, 04:13 PM   #26
Devilman
Re: 1976 CCSB Duramax Project #trucknamedsue
Originally Posted by RADustin View Post
Thanks man. I checked out your work, looking nice!
kicking around the idea. that was the plan with making everything bolt on, is eventually offering it as a kit. It's a TON of work to make what I've done so far. I feel like I could do an entire frame quicker. I'm not sure what the future holds, I just want to get this first kit done and on the road for some testing. We'll see after that.
Not all GM AAMs are the same. I'm using the LML variant, 2011+. It's a little wider than the earlier 2010- AAMs. Not sure what AAM you have?
Bolt pattern has been a major topic lately with the end decision to keep the 8x170 everywhere. So I will be machining the rear hubs for it, and drilling the rotors. Also going to be swapped to the 60tooth ABS tone rings in the rear to match the front. Basically my front D60 will be bone stock and the rear will have all the modifications to work. I'd rather have drilled rear hubs(non wear item) than drilled front unit bearings(wear item). It sucks the rotors will be 'custom' but it's not the end of the world.
The difference in width between the axles is 0.394" per side, with the front axle being wider. (71.496" vs 70.709") I attached a pic as well to show.
I've got an 08 dodge dually AAM rear. But I can get my hands on an 11+ axle easily. I'd do way with the abs and use a free-spin kit with a 8 on 6.5 bolt pattern on the front 05+ axle.....that was my thought process anyways on having everything the same bolt pattern.
Devilman is offline   Reply With Quote
Old 03-19-2018, 05:28 PM   #27
Devilman
the free spins are just $$. Especially considering the units are plenty strong and already there.
But it certainly is an option.
That was my only option to retain the 8 on 180 if I wanted.
A '14 Dodge AAM is 71.574".
Oh yeah they're definitely expensive, only reason I'd use a free-spin kit is I've already got one for the ford axle, found it on Craigslist for less than a grand so I jumped on it.
Fab work is looking awesome bud, let me know on the suspension & engine mount kit, I'm ready
Old 03-20-2018, 11:54 AM   #28
RADustin
man that's a steal!
yep- for sure I'll let you know. I can't bring myself to sell anything though until I've beat the crap out of it personally and I know it's 100%.
When that happens you'll know.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 03-28-2018, 10:25 AM   #29
RADustin
Moving along.
Front axle side 4-link ends bent up, fit, welded, and tac'd to bars to hang front axle. I will have to take the ends back off to finish welding everything but I wanted to fit up the front axle before I got too far.
swung the D60 underneath.
I wanted to check a bunch of different things next. The body mounts I made, the engine/trans fitment, and the front wheelbase. So I need to get my cab off the donor and ready to go.
The donor '76. C35, true camper special with 10,000lbs title. The bed is wrecked, but I won't use it. Only using the cab and front clip, plus interior items.
I didn't touch the mechanical systems. I'm hoping to sell the frame as a roller, running.
cab getting cleaned up, vacuumed out. It's real clean. I only found 2 rust through spots, under two of the cab clearance lights. I further stripped the firewall to nothing. I won't be using the stock AC or anything.
to get the 4x4 tunnel in and effectively convert my 2wd cab to a 4x4 cab, I started by laying the weld in half in and marking around it.
then I offset the marker line with tape to make the cut line. also mapped out the front bolt in half.
cut out the rear half and cleaned the bottom of the lip. This was terrible work. I use weld thru primer on the weld in parts lip and the cab side lip to help prevent rust. I'll also seam seal everything later on.
drilled for plug welds and celco'd in the weld in half from the bottom.
welded in. I perfer to TIG the rosette welds so I can heat everything up, fill, then keep the heat on letting it all flow. Also cut front half. I didn't cut front and back out of cab at once to keep as much material in there at all times.
test fit front bolt in piece.
Then I was able to test fit the cab. It fits perfect. I'm very happy. The ride height is a little low for what it'll be final, but its close. and ofcourse the final tires will be bigger.
to get the bed ready, I needed to remove the center crossmember from the bed floor. from my research, some beds got this piece and some didn't. My bed floor had it, but it would be in the way of the gooseneck, so I removed it. Drilled the spot welds and popped it out-
since I used a small pilot hole and a 3/8" annular cutter to drill out the spot welds, I had the small pilot hole to fill in the bed floor. I drill my pilots all the way through. So I TIG'd up these little holes and smoothed top and bottom.
and that's caught up with current. I hope to test fit the bed and check rear wheelbase soon. I need to order lots of parts and figure out steering and front track bar. Also have some engine items to handle.
Update again in a few days.
1949 Chevy 3100 P/U
Old 03-28-2018, 12:33 PM   #30
Devilman
Oh man it looks perfect!! Im leaving mine a dually and love the ride height you have now, maybe slightly taller to clear 37s. What tire/wheel size are you going with?
I might be interested in the dually bed if the floor is good, the floor in my bed is junk.
Where'd you find the back section of the tunnel? I've already got the front bolt in section (well the 2wd manual version which I think is the same minus the transfer case shifter hole) I could easily fab up a full tunnel that'd clear but I'd like to stay with stock 4wd parts.
Sry for all the rambling questions I'm just really digging your build! Lol
Old 03-28-2018, 12:52 PM   #31
RADustin
my bed is toast. Since you're in Dallas you're very near to Texas Square Bodies. He will have nice beds.
I'm going to run 35x12.50s. The current height is probably an inch or two low. Give or take. I am a little concerned I may be too high. We'll see.
the 2wd high hump is different than the 4wd. you'll need the 4wd bolt in tunnel and a donor cab section. I got my parts from azpartslocator.
see the attached PDF. It shows the different in humps.
1949 Chevy 3100 P/U
Old 03-28-2018, 01:08 PM   #32
Low Elco
Great work! I gotta ask, Do you just have your own warehouse? This thing's gotta be taking up a bunch of room!
Low Elco is offline   Reply With Quote
Old 03-28-2018, 01:31 PM   #33
Devilman
I forget about Texas Square Bodies, I'll holler at him about a bed.
I had thought there was a difference in the tunnels but didn't realize they're that different. Thanks for the pics and I'll check out azpartslocator. Do they have new 4wd crew tunnels or take outs? You know of anyone making a new replacement tunnel or the entire 4wd tunnel front and rear? I've searched but haven't found any.
Old 03-28-2018, 01:35 PM   #34
RADustin
Thanks.
I work out of a flex warehouse my Dad has to support his automotive shop. Sometimes I have lots of space, sometimes nearly none. But no complaints as it's a nice spot.
Most of the truck parts are on a huge pallet rack I access with the forklift. So the footprint of the project is smaller than you'd imagine.
no replacements. You need to source good used parts. There was a front bolt in piece that just sold on here a few weeks ago. Check ebay.
I like the OEM route because you have to cut through the main crossmember of the cab. So it's nice to have a sturdy part to put back in that would be kind of a bear to fabricate.
1949 Chevy 3100 P/U
Old 04-16-2018, 10:18 AM   #35
LT7A
This is phenomenal to watch. I feel like I'm sitting in on a build at some sort of a GM skunkworks.
Old 04-20-2018, 10:52 PM   #36
Devilman
Bump for some updates!!
Old 04-24-2018, 12:10 PM   #37
RADustin
probably the coolest words spoken about the truck yet
Wouldn't it be the coolest if GM directly sponsored some of these old truck builds by opening up their old drawing packages and full from the bins of previously design parts? Maybe that's just my dream but I think it'd be sweet.
yep!
So I lost about a 10 days of any progress ~2 weeks ago. Got randomly really sick, bad vertigo. So no 3D model progress, no nothing. but, been moving along well other than that.
got the bed dropped on. Wheelbase looks good, but bed to body lines are off considerably. Still not exactly sure the problem, I think it's the aftermarket bedsides. Either way, I'll find a way to get everything in tune.
put the rear bumper on to make sure I cut the frame correctly. It isn't adjusted, but the stick out is right from the back of the bed. so that is a good.
downpipe fits well.
so then I switched gears for a bit. I needed some major 3D model progress on the front suspension. Although the axle was hung on the 4 link, that is as far as I went with design. So I ordered up a redhead box, specific for what I'm doing. Ordered a pitman, all the stuff for the rebuild on the front axle, and some other nic-nac to add into the model. I'll make a seperate update on just model stuff.
Box of goodies from Rockauto. They are the best.
So anyways, been back round working on 3D model, while also pushing forward on fab.
The core support has been lingering. I been avoid it to be honest. I knew it was going to be toughest part of my swap. I wanted it to look fairly OEM, use stock LB7 parts, use mechanical fan and OEM LB7 fan shroud. OH and I didn't have any of these 3D models, so everything was going to have to be figured out shop level.
Initial fit up, the cooling stack from the LB7 is much more massive than anything the squares came with. The lower intercooler mounts are basically right on top of the core support mounts, so I knew it'd be fun to figure all this out.
I laid out all of my cuts, and made some of them. I wanted to build the new vertical posts first before I cut the meat out, so I can align everything prior to cutting out the center. Going a full 48" wide of opening.
The new posts will spot weld in like factory. And they wrap around the backside on the opening to give a very finished OEM look.
used my level to ensure everything is on the same plane.
for the outer halves I hammer formed the lip. So made templates and cut lots of MDF. One pattern brought the lip to 90, and another to 135°. So two forms for each side. Also my brake I wanted to use is short, so I had to two each half in halfs. Lots of pieces here.
hammer formed lip follows the contours of the headlight bucket nicely.
once the verticals were tac'd up I braced up the bottom of the support to cut the center.
I machined locators for the stock mounting pickups so I can retain the angle and position. They have a raised face that fits the stock hole tight.
center removed.
to terminate the ends of the new center to the old outers I made some offsets out of 1x2x16ga tube. Very angular to match the shapes well.
The new frame mounts are cups made from 1.5" HREW with plates welded on the bottom. After welding I machined the weld with a little radius so they look nice.
things getting fit up. The spanner tube is again 1x2 and is flush with the outside of the new verticals. This is how the offsets fit.
mounting cups finished out and fitted to jig.
marked crossbar for cuts. cut and fit in mounting cups.
trimed cups, fitting back in place
I welded things in a very specific order to minimize warping the support. So basically I welded in the cups, then straightened the spanner bar, then welded the bar in.
re-fit radiator in place with full shroud. everything looks good except I'll have to shade the radiator to the drivers side to make the fan shroud line up. I completely forgot during my engine mount design that GM offsets the engine to the drivers side about 5/8".
once the refit was done I took tons of measurements and ordered some material to make the upper radiator mounts from. In the meantime I started forming the lower intercooler mounts. They will also brace things considerably.
I'll keep working on these this week until I leave for Talladega. But hopefully the core support will be finished soon.
I'll make another post about the model updates.
1949 Chevy 3100 P/U
Old 04-24-2018, 01:42 PM   #38
RADustin
3D model updates.
As I mentioned earlier, the front looks alot more complete than it is. So I set out to get that finished up so I can officially have a roller.
The coil towers where sort of drawn early on, but setup for 8" Kings. I change them for the 10" Foxes. I also added a cross over bar, over the top of the duramax to connect both towers to keep from rolling the frame rails.
The factory Ford panhard mount wasn't going to work, so I removed that and designed my own. I ordered a Reid Racing high steer knuckle for the 2005+ Ford D60. Also steering box from redhead and a jeep TJ pitman. I'll be using GM 1-ton TREs on the drag link and the factory ford tie rod. Using all the dimensions of the selected components, and physicals of the redhead box, I sized the length and position of the TRE on the Reid high steer knuckle. The steer arm bends over to line up much closer to the king pin axis so that the truck will steer the same left as right. The ratios are set so that the steering wheel angle will give similar road wheel angles as the stock LML truck. This is so the ABS system and stabilitrak will work. I will be mounting a steering wheel angle sensor to the column to monitor this.
so anyways, lots of fun design work. challenging to get all the fitments right, keep it looking nice, and making sure it'll function correctly with all the fancy LML electronics.
I did 3D scan the drivers inner fender and steering box. I'll work on cleaning up the inner fender more and get it 'mounted' as close as I can to real so hopefully I can pull some templates out the model when it comes time to cut it up for the coil towers. The steering box was done to ensure fitment.
I'm just starting to finish sorting the rear out. Looking to get the spare tire under the bed [hopefully!] and get a hitch out there. But, the spare tire fitment is VERY tight. The hitch shown is from the LML and just for kicks while I think about it. I'll probably run a class 3/4 hitch and not the 5 that the LML is. I don't really tow heavy bumper pull trailers.
I'll progress this in the coming days. The plan being that the remainder of everything can be cut in one more laser order. Then just small nic-nacs after that my brother can cnc plasma for me.
1949 Chevy 3100 P/U
Old 04-24-2018, 03:13 PM   #39
Low Elco
This is gonna be so awesome.
Old 04-24-2018, 04:08 PM   #40
Great looking build! I am looking forward to seeing more on it.
Old 04-24-2018, 09:29 PM   #41
Dads79GMC
Dads79GMC's Avatar
Wow, again!!!!!!!!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-25-2018, 12:25 AM   #42
Dukagora
And when I find threads like this, it makes me wonder if I should really stick with my C20, or find a K20 crew cab, before I have a bunch of time and money invested.....
If I found an easy way to convert to 4x4 I would!
Dukagora is offline   Reply With Quote
Old 04-25-2018, 03:35 AM   #43
Jaysonb
Jaysonb's Avatar
That's amazing!
Jaysonb is offline   Reply With Quote
Old 04-25-2018, 05:34 AM   #44
AJC
Looks good. what are you using to 3d scan?
AJC
AJC is offline   Reply With Quote
Old 04-25-2018, 08:31 AM   #45
RADustin
thanks
thanks, I'll keep the updates coming
Originally Posted by Dads79GMC View Post
Wow, again!!!!!!!!!
thanks
easiest/cheapest way to convert a C to a K is a frame swap. Don't let anyone tell you different. Just depends what you want though. I wanted newer axles, 4 links and load sensing rear. So I went custom... I really thought about just frame swapping an early body when I was planning everything out. I'd probably be done by now if I would have!
Originally Posted by Jaysonb View Post
That's amazing!
I use structure sensor. It works well enough, and I'm still learning how to best use it and post modify the meshes. I wish I could afford/justify a Faro but it is orders of magnitude more expensive.
1949 Chevy 3100 P/U
Old 04-26-2018, 10:21 AM   #46
NastyBuzzard
NastyBuzzard's Avatar
You should check out cut bros on facebook. A 4wd bolt on conversion kit exits for 1 tons and crew cabs.
I do agree that just doing a frame swap is the easiest though, if you can find a frame.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 05-01-2018, 08:07 AM   #47
Advanced Design
Advanced Design's Avatar
Impressive design and fabrication! I will be tagging along for the rest.
Advanced Design is offline   Reply With Quote
Old 05-01-2018, 08:26 AM   #48
RADustin
ORDs kit would work as well. But a little bit of welding.
There is a few out there now, finally the squares are getting the support the 67-72s have, and even more in some cases.
sweet! glad to have you
As mentioned above, the space I work in is flex space for my Dad's business and fairly new to him. He wants to paint the floor though so I'll be under a 1 month crunch to make the truck a full roller. Lots of long nights ahead... I'm hopeful for plenty of progress.
1949 Chevy 3100 P/U
Old 05-01-2018, 03:44 PM   #49
LT7A
Wouldn't it be the coolest if GM directly sponsored some of these old truck builds by opening up their old drawing packages and pull from the bins of previously design parts? Maybe that's just my dream but I think it'd be sweet.
Could you imagine? My favorite way to think about these trucks is to imagine the parts that would best suit the use of the truck. It would be so fun to have access to all of the lightest, best performance parts, or the most heavy-duty, robust parts, depending on the intended use. I like thinking about using the best that was available for the era and combining it to fit my vision. Your truck is combining the performance and heavy duty parts from several eras and manufacturers. I'm glad you're taking a lot of pictures along the way. Much of the beauty of the design and thought that went into the truck will be hidden once it's assembled.
Old 05-23-2018, 12:45 AM   #50
Indyfab
Indyfab's Avatar
After going through your build a third time or so, what are you thinking for towing mirrors? I have 81 cc I’m building, and want very usable towing mirrors that don’t look out of place, that aren’t west coast/camper style. I’d like something that functions like a late model but looks right on these trucks.
Indyfab is offline   Reply With Quote
