Old 02-22-2012, 08:19 PM   #476
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: My 57 Pro Street
Looks nice Kim.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 02-22-2012, 08:26 PM   #477
oldman3
oldman3's Avatar
Looking real good....Jim
oldman3 is offline   Reply With Quote
Old 02-23-2012, 08:00 PM   #478
65Pickup
65Pickup's Avatar
Originally Posted by Kim57 View Post
6.0 LS2 with a 4L70 out of an 2009 SS Trailblazer. It only has 18,000 miles.
These are rated at 395 HP and around 400 Ft Lbs of torque.
Comes with all the accessories, computer and harness for the engine and trans.
Kim
Nice choice Kim, I probably should have gone this way also. I'll be watching the developments.
65Pickup is offline   Reply With Quote
Old 02-23-2012, 08:07 PM   #479
poncho_villa
poncho_villa's Avatar
Just thinking about the result of this build makes me grin
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 02-24-2012, 01:17 AM   #480
Kim57
Kim57's Avatar
Thanks for the compliments guys.
Hoping to get the engine and trans in next week.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-24-2012, 02:00 AM   #481
squirrely_1
Your build is very inspiring ! everything looks great!
squirrely_1 is offline   Reply With Quote
Old 02-24-2012, 09:59 AM   #482
usmc_butler
usmc_butler's Avatar
x2 Cant wait to see the 6.0 LS2 in this ride. Got me tossing around the idea of putting some sort of LS motor in my truck next winter, amazing power and good reliability!
"I'm as confused as a baby in a topless bar"
57 Fleetside Build Thread
usmc_butler is offline   Reply With Quote
Old 03-06-2012, 06:44 PM   #483
Kim57
Kim57's Avatar
Here's a little update on the engine/trans fitment.
I had it in with the frame stands in the way they came from the factory and my oil pan was hitting my cross member. Swapped sides with the stands hoping it would move the engine back far enough to clear and ran into other problems so switched the frame stands back and plan on raising the engine about 1.5"s.
I'm making some brackets now to do that and hope to try getting the engine in again later this week.
Here's the new brackets I made to raise the engine up.
The last pic is some DOM that I will weld to the brackets that wrap around the original frame stands. I'm going to place the engine in on top of them before I weld them to be sure they're in the right position.
If I need to go any higher I can just put some steel plate between the DOM and bracket before I weld them.
Kim
My build thread
Old 03-06-2012, 06:47 PM   #484
Kim57
Kim57's Avatar
I also had to make some brackets for the transmission cross member as my frame is fully boxed.
I will weld them to the inside of the frame once I get the angle of the engine/trans set.
Kim
My build thread
Old 03-06-2012, 08:44 PM   #485
hotrod1
56 - autocross
hotrod1's Avatar
Nice fab. Looks like it came with it and better.
How come u just don get another pan instead? There are a few good pans out there that will accommodate low clearance issues. They are not too cheap though.
hotrod1 is offline   Reply With Quote
Old 03-06-2012, 11:35 PM   #486
Rods57
Rods57's Avatar
Hey those are pretty cool. Nice work, the little holes always make it look better.
Rods57 is offline   Reply With Quote
Old 03-06-2012, 11:40 PM   #487
Kim57
Kim57's Avatar
Thanks.
I had to replace the pan that was on the engine as the Trailblazer pan is specific to that chassis. The research I did said the CTS pan would fit my front clip but would hang a little low. The slope on the pan made it hit the cross member so raising it is the best option.
I've already got $200 in it and the only pans I've seen that come close to fitting without any mods are in the $600 range. Holley makes one that is $400 but I couldn't find any info that said it would fit. They even say there may be some modification for it.
Kim
My build thread
Old 03-07-2012, 12:06 AM   #488
jimig1
jimig1's Avatar
Looking good. Your fab skills are awesome!
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 03-07-2012, 12:37 AM   #489
oldman3
oldman3's Avatar
Looking just great, nice job.....Jim
Old 03-07-2012, 02:40 AM   #490
65Pickup
65Pickup's Avatar
Great fab Kim, I'm sure you've considered it, but why not notch the x member or pan?
Old 03-07-2012, 03:05 AM   #491
hotrod1
56 - autocross
hotrod1's Avatar
I am not sure about you application, but I have looked at these below. I have a camaro pan (lsx) is is a little thick. I need to get the engine as low as I can for better handling.
http://www.autokraft.org/products/ scroll down on the page
http://www.kevkoracing.com/wetsump_chevy.htm
I know that milidon makes some nice ones as well but they are a bit more expensive.
Anyways, it looks like you have the problem solved with your ingenuity.
Old 03-07-2012, 07:54 AM   #492
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looking good! I can hear it running now!
ChuckDriver is offline   Reply With Quote
Old 03-07-2012, 10:20 AM   #493
Kim57
Kim57's Avatar
I did consider notching the cross member but figured this would be a little easier. I also didn't like the pan hanging below it as I'm lowering the truck.
As far as modifying the pan I have no experience welding aluminum.
I would probably ruin it in the process.
I know raising the engine isn't ideal for handling but I won't be road racing it anyway.
Those are some nice pans and I did look at them. I wanted to stay with the cast aluminum.
The "A" body pan needs to be modified to fit in my front clip.
Kim
My build thread
Old 03-07-2012, 03:50 PM   #494
Fat Mike
Fat Mike's Avatar
Man Kim, you always seem to amaze me in the fab mods that you do. I always am waiting to see whats up your sleeve next. Can't wait to see more!!
Fat Mike is offline   Reply With Quote
Old 03-07-2012, 04:00 PM   #495
hotrod1
56 - autocross
hotrod1's Avatar
Me too. I like to learn from fantastic fab guys.
Old 03-07-2012, 09:27 PM   #496
Kim57
Kim57's Avatar
Thanks for the kind words guys.
Kim
My build thread
Old 03-08-2012, 12:04 AM   #497
OKGMC4
OKGMC4's Avatar
Everything looks awesome and I'm happy another tri five truck is being turned to the dark side. (injection) I just can't wait to see it in the engine bay. I HAD to use a camaro pan on my 5.3 because the truck pans are hella deep. In the engine section of this site there is actually a sub category for LSx swaps. Have you tried posting on there to see if anyone has any good suggestions on the pan issue?
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-08-2012, 12:49 AM   #498
65Pickup
65Pickup's Avatar
Saw this on one of 67Chevy's posts, but I know the money is more the issue, these pans ain't cheap and your solution looks sound. Good info though.
http://www.ls1tech.com/forums/conver...-oil-pans.html
Old 03-08-2012, 01:22 AM   #499
Kim57
Kim57's Avatar
I've been in that thread. The biggest problem I had with my set up is that I have a chevelle clip. There is a ton of very good info in there though.
I've read that thread. It has a ton of good info on the different pans.
Kim
My build thread
Old 03-08-2012, 01:23 AM   #500
drivea55
drivea55's Avatar
Man Kim!
your fab work is really nice!
soon we shall see the power plant installed eh?
keep up the good work
Brian
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
