Old 04-21-2013, 04:28 PM   #476
focusedontheprize
focusedontheprize's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
Truck is looking great. You'll be driving that sooner than you think.
Those Xenons give that truck such an unique look - I really like it.
focusedontheprize is offline   Reply With Quote
Old 04-24-2013, 11:39 PM   #477
Atommik
Atommik's Avatar
As I get closer to "start up", the money spent is piling up!!
Just bought plugs, plug wires, more electrical connectors and heat shrink,electric fuel pump, carb cleaner, carb rebuild kit, fuseable link.
It's getting closer!
Atommik is offline   Reply With Quote
Old 04-25-2013, 09:47 AM   #478
oldman3
oldman3's Avatar
Moving right along...Jim
oldman3 is offline   Reply With Quote
Old 04-25-2013, 11:04 AM   #479
xpickup
xpickup's Avatar
Atommik, Yes, you have all the big stuff bought and you think you are doing good money wise. Then you buy all the small stuff and it nickels and dimes you to death. It is amazing how all that stuff adds up so quick. Truck is coming along great.
Shannon
xpickup is offline   Reply With Quote
Old 04-25-2013, 11:36 AM   #480
rambler
MOVE OVER
rambler's Avatar
very nice... look forward to interior work..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 04-26-2013, 11:23 PM   #481
mknittle
mknittle's Avatar
Originally Posted by Atommik View Post
Last week my boss gave me this T shirt. He saw it at Tractor Supply and thought of me. He didn't know it was 2 days before my birthday!!
That's pretty cool! truck is really looking great!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-27-2013, 05:58 PM   #482
Atommik
Atommik's Avatar
Thanks for all the comments!!
I got the "AC" installed today...my cowl vent!! A new gasket from LMC and a little adjustment and it works like new!!
Wired and installed the headlight switch. It's new from a 80 chevy truck. All of the lights turned on and blinked as needed!! All the wiring is now done except the gauges and heater. Haven't bought the gauge refacing kit yet.
So do I convert the temp and oil pressure gauges to electic, or convert the senders to mechanical?? Any opinions??
Also installed the 1951 to 1991 s-10 converted fuel filler neck. Found the filler cap after I took the pic.
Installed the left side running board for the last time!! Did a little more adjusting of the front sheet metal. Finally happy with the gaps!
Next up...carb rebuild, fuel pump install and steering shaft. Should be getting the steering parts and Lokar shift cable on Monday.
Couldn't resist the urge to quickly turn the key to the start position to make sure the starter turns. It does!!
Old 04-27-2013, 08:12 PM   #483
Daze57
Daze57's Avatar
what a sharp lookin truck !!!
Daze57 is offline   Reply With Quote
Old 04-27-2013, 10:02 PM   #484
99 to Life
99 to Life's Avatar
gas neck came out nice. oh what a great feeling to give it that kick over with the switch! congrats, its all coming together. The little things eat up sooo much time and brain space, I think we all forget about it until we dig back into a build like this.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-28-2013, 12:13 AM   #485
oldman3
oldman3's Avatar
Nice going, keep it up...Jim
Old 04-28-2013, 07:48 PM   #486
focusedontheprize
Been out with strep throat for a month...hell it has been, but I did want to respond to you as I was in the same mindset.
So your gauges...I would keep the mechanical setup. I wanted to keep mine, however I am running a 1970 292 so I had to make sure all the hook ups were there. The only thing I converted was the fuel gauge from 6v to 12v. All the rest hooked up (temp, oil, and battery). So moving to the speedometer, I am running a 5LM60 (NV3500) transmission and that is running an electronic speedometer and my truck is mechanical. When I was searching the Internet I came up with this article (http://www.jalopyjournal.com/forum/s...t=vintage+tach) so there is hope at the end of the tunnel for me to keep the speedometer.
I tried to do a little searching for you and came across this:
http://www.camaros.net/forums/archiv...p/t-37084.html
Do you have these locations they are discussing about?
Also I am running the EZ Wiring harness, I think you will really like it.
J
Old 04-29-2013, 07:57 AM   #487
Atommik
Atommik's Avatar
Focused,
I have the oil sender at the rear, near the dist, and the temp sender on the drivers side near the exhaust ports. If my 216 mech senders will fit in there, then I'm all set.
Thanks for the help!
Old 04-29-2013, 08:11 AM   #488
focusedontheprize
Focused,
Ok great. For my temp sender on my 292 I needed a reducer http://www.classicparts.com/1941-54-.../#.UX5jb7Up_To to make mine fit.
Old 04-29-2013, 12:02 PM   #489
skymangs
skymangs's Avatar
Looks great! I used that exact harness in the kids truck, and I couldn't be happier. Very simple to wire, and very small fuse block.
I also did the same with my filler neck. Looks SWEET!
skymangs is offline   Reply With Quote
Old 04-29-2013, 09:26 PM   #490
Atommik
Atommik's Avatar
Focused,
Thanks for the link to the reducer...that will be just what I need.
Old 04-30-2013, 11:08 PM   #491
Atommik
Atommik's Avatar
Fed Ex brought the Lokar shift cable and DD shaft and U joint. Looks like it will be a busy Saturday!!
Old 05-04-2013, 03:14 PM   #492
Atommik
Atommik's Avatar
So...Todays progress...I got my steering shaft figured out and installed. It is a tight fit but actually worked out like I hoped it would. I never could have done it with out the S10 V8 swap headers!! I had to remove the brake lines coming down from the master cylinder and reroute them towards the back and along the firewall to avoid the header on that side.
It's a close fit from header to inner fender. I will put a small heat shield in between to keep the paint from cooking!!
Also installed the Lokar shift cable. Nice kit, good directions. Although the nice billet aluminum bracket that goes on the front end of the cable and attatches to the column, would not work on my set up. So I made a simple steel bracket. That's probably the one part that makes the kit cost so much!!
Also finished bolting up the pass side running board, filler and rear fender.
Carb is also getting rebuilt this weekend!
Old 05-04-2013, 04:58 PM   #493
99 to Life
99 to Life's Avatar
nice, how much those joints run you? crazy how much companies ask for those. I used some out of a chevy van, a little bulkier lookin tho.
Old 05-04-2013, 09:58 PM   #494
Atommik
Atommik's Avatar
The u joint was Jegs brand, $60. Seems like good quality...
Old 05-05-2013, 09:50 PM   #495
Atommik
Atommik's Avatar
Also started putting on the blue anodized aluminum valve covers that I got for free...I didn't like the look of them on the motor. So, I stopped at the local parts store and got a nice pair of chrome valve covers! Also picked up a battery, and throttle cable. Gas pedal was ordered last week, should be here soon!
Old 05-08-2013, 10:00 AM   #496
OLDIRON69
Great build, but beware of the cheapy chrome valve covers from the parts house. They are prone to leak. I probably would have opted to paint the aluminum covers.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 05-12-2013, 10:22 PM   #497
Atommik
Atommik's Avatar
No work on the truck this weekend. My brother and I took our mom out for breakfast Saturday, then quality time with my wife and kids on Sunday!! Hoping for more truck time next weekend!!
Carb is ready for install, gas pedal and throttle cable ready for install, fuel pump and battery ready for install. I need some 48 hour Saturdays!!
Old 05-12-2013, 10:25 PM   #498
Atommik
Atommik's Avatar
It wasn't just the color...they are "hidden bolt" valve covers so they are wider and longer with a thicker sidewall. The pass side was almost touching the firewall! I bought Edelbrock valve covers so hopefully they will work out well.
Old 05-17-2013, 06:47 PM   #499
Atommik
Atommik's Avatar
I had a little down time at work today so I got a head start on tomorrows projects!
Installed the battery tray and battery,(still need to make a hold down). I decided to put the battery under the bed floor. I will have a removable section for battery access.
Installed the new valve covers and got the rebuilt carb installed.
When I got home, my radiator had arrived (early) from JEGS! Also gauge re-facing kit and chrome bezels for the gauges from LMC.
Old 05-18-2013, 11:34 AM   #500
99 to Life
99 to Life's Avatar
sweet, get that baby fired up. word to the wise on that carb, run a fuel pressure regulator and no more than 6psi. I know you were asking about temp senders. Do you have room in your head and intake? I run my gauge off of the intake and my efan sender in my head, works well.
