05-25-2015, 03:11 PM | #476 | |
Re: 64 C10 Stepside "Jaybird"
05-26-2015, 10:58 AM | #477 | |
I scored a bunch of gauge cluster parts last week from another member who had sold his truck, so I now have another cluster lens, I believe both are originals… The only questions still remaining are… Am I right in assuming you polished both sides of the lens with the product you mentioned, and did you take any special precautions concerning the markings? And if you consider re-setting your odometer, give me a call, it's a rather easy process...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 05-26-2015 at 11:00 AM. Reason: Add Comment |
05-26-2015, 08:53 PM | #478 | |
Post up a pic of yours to confirm. But the original one I had the lettering is a paint and light greenish like the gauges. If you run your fingers across you can feel it. The other one I had the lettering was an off white and obviously printed as one swipe and it was gone. I started out slow on the original and the applied more pressure until I was sure it wasn't going to come off. I polished the front side 4 times and the back once and then finished with a coat of wax. Here a before and after. Most of the nastiness was on the outside. DSCN7483 by bjohnson388, on Flickr DSCN7484 by bjohnson388, on Flickr It still has some imperfections and deep scratches the polishing won't take out but I think it looks much better than before and it is saving an original part. The worst scratch on mine is to the left of the oil pressure gauge. You can still see it in the pic. It has polishing compound in it.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
05-26-2015, 10:19 PM | #479 |
good job on the oem equipment save, I just finished the same project.
05-27-2015, 08:39 AM | #480 |
Great job on the wiring and the cluster & cluster lens!!!!! Makes a huge difference in appearance.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-27-2015, 10:42 AM | #481 |
Bret, here is a pic of the 2 I have, both are OEM Survivors…
The printed sides look to be in pretty good shape and the outer sides are decent as well, both have a couple of decent scratches that I hopefully can buff out... IMG_3392 by Donald Olivo, on Flickr I'm going to refurb this gauge cluster prior to install so as I spot others doing this I'm gathering as much info up front as possible, Thanks again... One more question… did you use a buffer as in one to do paint work, or would a buffing wheel on a bench grinder work also? I sure don't want to destroy either of these...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 05-27-2015 at 10:45 AM. Reason: added comment |
05-28-2015, 07:52 AM | #482 | |
Got these from this forum but lost the thread they are from
05-28-2015, 10:18 PM | #483 | |
06-04-2015, 08:55 AM | #484 |
Truck is looking great and awesome job on the wiring! That's one job I'm not looking forward to!! LOL
06-06-2015, 08:21 PM | #485 |
Thanks Mike.
06-06-2015, 08:46 PM | #486 |
So I am on vacation as of today and have a long list of stuff I want to get done. I put in 9 hours today this is what I got done.
Ran rear body harness Ran gas gauge and courtesy light Hooked electric choke into engine harness Hooked up all the wiring for MSD box Ran horn and front harness to core support Installed firewall pad and inside heater duct Hooked up heater hoses. Need to buy a new 5/8" one Bumped engine over to tdc and installed dist and plug wires(my wiring is good so far) Cleaned ash tray handle Got all the parts rounded up for sandblasting I need to blast. Firewall pad installed. Bought this from Carandtruckshop. Its made in USA. I was very impressed with how well it fit. I bought the tool for installing the fasteners and had no problem. It was kind of tricky to get the very center above the hump to fit right but finally got it in there. For anyone buying one from them it comes with fasteners. It doesn't say it does so I bought them separately as well. And it comes with 11 pcs but I only used 7. I installed the inside heater duct after the firewall pad. 20150606_091420 by bjohnson388, on Flickr 20150606_091422 by bjohnson388, on Flickr 20150606_091435 by bjohnson388, on Flickr I ran all the wiring in convoluted tubing and secured with rubber clamps or electrical tape. 20150606_165453 by bjohnson388, on Flickr I'm not crazy about how the firewall pad fasteners poke thru but what can you do. For anyone who buys the AAW harness I did it came with this grommet for the rear body harness. I bought the 6pc firewall grommet set from Carandtruckshop and it didn't include this one. 20150606_165440 by bjohnson388, on Flickr Installed the temp sender and ran the wire to it. 20150606_165508 by bjohnson388, on Flickr Ran front harness and hooked up horn. Only thing left to plug in under hood is the heater blower wire and the park lamps harness. This tubing is just sitting there. Will get it all straight when I get clamps for it. 20150606_165515 by bjohnson388, on Flickr Courtesy light and gas gauge wire. I left some extra just in case. I ran a wire fish to get this installed. Ran the fish up to the hole and the pulled the wire through from top. Got it the first time. 20150606_165654 by bjohnson388, on Flickr 20150606_165658 by bjohnson388, on Flickr MSD Distributor and plug wires installed. (I'm a little scared the distributor dropped right in on the first try and even lined up with the oil pump drive shaft. That never happens to me). I robbed all this from my Caprice. I painted the cap black to disguise it as a points distributor but the wires kinda of give it away. I need to adjust some of the wire holders the headers on the truck are different than the ones on the Caprice. So I need to take some slack out of the wires. Still need to tidy up the batter cables maybe buy some longer ones so I can tuck and hide them better and secure them with rubber clamps. 20150606_173027 by bjohnson388, on Flickr 20150606_173032 by bjohnson388, on Flickr 20150606_173038 by bjohnson388, on Flickr
06-07-2015, 12:07 AM | #487 |
Post Whore
Looks sweet BJ! Awesome work!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-07-2015, 08:05 AM | #488 |
wow Bret... you had a great day. everything looks fantastic. you should take more vacations.
06-08-2015, 05:55 PM | #489 |
Very nice work!! Looks great.
Ryan. |
06-08-2015, 10:26 PM | #490 |
Super Clean...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
06-08-2015, 11:40 PM | #491 |
Looking great
06-09-2015, 09:12 AM | #492 |
Starting to come together real nice. Looks great!!!!
06-10-2015, 08:10 AM | #493 | |
Thanks TJ.
Thanks Ryan Thanks Don Thanks Jeff
06-10-2015, 08:15 AM | #494 |
Thanks J.
Yesterday finished repairing the steering wheel. It is ready for some High build primer coats. Want to get it as smooth as possible. I didn't have any high build primer so I decided to strip the grille of all its parts and paint. I didn't strip the paint from the mesh part because I am going to cut this out to make it look like a C60 grille. 20150609_151424 by bjohnson388, on Flickr 20150609_151433 by bjohnson388, on Flickr 20150609_151458 by bjohnson388, on Flickr 20150609_151505 by bjohnson388, on Flickr I saw a truck with one of these Corvair van grille inserts in it. Looked pretty slick but it was a chrome grill. If I were to get one and strip it of chrome an paint it white wonder how it would look. Either that or get the bowtie from a C60 grille. Or a whole C60 grille would be cool. Screenshot_2015-06-09-16-12-59 by bjohnson388, on Flickr Worked in the woodshop last night and got 4 drawers installed. Only 12 more to go! 20150609_193337 by bjohnson388, on Flickr
06-10-2015, 10:16 AM | #495 |
Diggin' the woodworking...
I also saw the corsair van grille insert and really liked that too...
06-10-2015, 01:20 PM | #496 |
Looking good Bret! I like the Corvair insert Idea on the grill.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
06-10-2015, 01:22 PM | #497 |
The steering wheels coming out nice. Like I mentioned on FB, I've done 3 so I know the tedious work involved, but it'll look great once painted.
And like everyone above.....nice score on the grill insert.
06-10-2015, 04:00 PM | #498 |
I like the grille insert idea. I think it would look good.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
06-10-2015, 08:57 PM | #499 | |||
Hope to find out soon.
06-10-2015, 09:05 PM | #500 |
Here is where the steering wheel is at. Two coats of high build and still needs a few places feathered around the hub. That area is real tricky to get smooth.
20150610_151536 by bjohnson388, on Flickr Cut the center mesh out of my grille. Wanted to mock it up to see how it looked but I took the buckets off can't mount it. DOH!! 20150610_121725 by bjohnson388, on Flickr Grille is in really good shape. Has a couple of small dings across bottom part that I was able to knock most of out. Will finish with a little filler 20150610_121741 by bjohnson388, on Flickr Sanded and CLR'D the back of the grille and grille support and sprayed all the rust left with Loctite Rust neutralizer. 20150610_151543 by bjohnson388, on Flickr They will be ready for some primer and paint in the next few days! By the way does anybody know what color the headlight cups are suppose to be painted? They look like they might have been anodized. Probably will paint them aluminum. 20150609_133840 by bjohnson388, on Flickr
