12-02-2016, 09:02 AM | #476 |
Still Learning
Re: 85 GMC Sierra "Scarlett"
Excellent work as always Ken! Keep the pictures coming....
12-02-2016, 01:04 PM | #477 |
Happy to be here
Thank you sir. I managed to get some shop time in last night. I will have updates later tonight.
12-02-2016, 02:54 PM | #478 |
Great work man, truck is looking swell
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 |
12-03-2016, 12:01 AM | #479 |
Happy to be here
The past few nights I have been working on restoring the seat. The cover has been recently replaced with a nice quality kit, but it needed some fine tuning. I decided while I was at it that the vinyl color didn't really match anything since I had dyed all the interior plastic Napa red. I also had plans to reconditionthe seat slide tracks.
I pulled the slide tracks and scuffed them down with Scotch Brite, followed by several light coats of satin black. While the slides dried, I cut all the hog rings on the seat back and pulled the cover off. I'm not happy with the way it fits, so I'm working on a plan to make improve the fit. I masked the cloth cover and prepped the vinyl by cleaning it thoroughly with brake cleaner. I gave it a couple of coats of Bulldog adhesion promotor then several light coats of SEM Napa red. Here's where I ended things tonight.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-05-2016 at 11:43 AM. |
12-03-2016, 02:38 AM | #480 |
Yeah I wouldn't have like the way the back of the seat looked either. I've been doing some seat re-covering/restoring myself. And like you, I have taken the seat rails off and made them look nicer.
I like seeing that the dye is working out. Can't wait to see it all back together.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
12-03-2016, 10:47 PM | #481 |
Happy to be here
My seat project has been slowly moving forward. Last night I got the last pieces painted and dyed. This morning I focused on improving the looks of the back of the seat. I decided to build a panel to insert in the foam recess to give it a ore finished look, and tighten things up a bit.
With that issue resolved it was time to assemble everything. Chris came by and helped me line everything up. We tightened all the bolts and called it done.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-05-2016 at 11:45 AM. |
12-03-2016, 10:54 PM | #482 |
Happy to be here
Those look excellent. Did you clean and lubed the slides? It really make a difference.
12-03-2016, 11:06 PM | #483 |
Happy to be here
Countdown to Throwdown! It's about to get quite in here. After a lot of research I decided to change brands of sound deadner to @silentcoat . I really like the results of testing compared to other big name brands, and @silentcoat costs so much less.
After talking to Roy at @silentcoat and Brent at @sculptgarage I was convinced it was the way to go.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-05-2016 at 11:46 AM. |
12-04-2016, 09:18 PM | #484 |
Happy to be here
Countdown to Throwdown! My shipment of @silentcoat sound deadner arrived yesterday. Today Chris and I did the install. WOW! This stuff is fantastic to work with.
The pre-cut squares have gridlines that make it very easy to lay out and cut. The foil cuts easily with a utility knife and the lines allow the deadner to expand and mold to contours. The adhesive is unique in that it allows you to lift the sheets and reposition them easily. Once they are rolled flat the adhesion kicks in and the sheets are locked in place. I am confident this is the easiest install we have every done. We had the cab done from firewall to the back in about 3 hours including a lunch break. Thanks again to Roy with @silentcoat and Brent at @sculptgarage for everything.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-05-2016 at 11:51 AM. |
12-04-2016, 11:25 PM | #485 | |
Wow, that seat turned out great!! Awesome job on the dye.
12-05-2016, 12:00 PM | #486 |
Happy to be here
After lunch we wrapped up the Silent Coat install and worked toward getting the interior back together. We test fit the carpet padding, and carpet. I trimmed the padding so it no longer goes over the step up behind the seat.
The carpet needed to be adjusted and the holes properly cut out for seat brackets and seat belts. We also cut a piece of MDF to go behind the seat. It is the starting point for a storage shelf and amp rack.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-06-2016 at 11:22 AM. |
12-05-2016, 01:44 PM | #487 |
A guy with a truck
Looks like a quality product. Do they require you to tape the seams?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-05-2016, 05:09 PM | #488 |
Doesn't this drive you nuts? That alone makes me prefer the 73/80 dash.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
12-06-2016, 01:20 AM | #489 | |
Happy to be here
12-06-2016, 02:00 AM | #490 |
Most all the 81-87s look like that to me. The trim and dash pad don't have the same angles
12-06-2016, 10:57 AM | #491 |
Happy to be here
I have an NOS pad that the trim fits better. I paid a premium price for it s I'm keeping it for a truck that needs a replacement.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-06-2016 at 11:23 AM. |
12-06-2016, 11:15 AM | #492 |
Happy to be here
Last night I squeezed a couple of hours of shop time in. Chris had helped me pull the headliner so I focused on making the inner skin acoustically dead. Research tells me it's not necessary to cover the entire panel so I tested that theory.Since the liner board is a tight fit around the perimeter, I concentrated on the center mass areas. I was very pleased with the results.
My thump test reveled that the roof skin now has the same dull thud when tapped with my knuckle as the rest of the truck. I plan to insert a thin foil liner to add additional heat resistance as well.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-06-2016 at 11:25 AM. |
12-06-2016, 12:35 PM | #493 | |
12-06-2016, 12:39 PM | #494 |
You might know this already, but you can get the storage trays that were originally in the trucks. I got one and put the speaker/amp carpeting on it.
12-06-2016, 02:37 PM | #495 | |
Happy to be here
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-06-2016 at 02:45 PM. |
12-07-2016, 11:44 AM | #496 |
Happy to be here
I had to work late and do some Christmas shopping last night. When I got home I had a delivery from my buddy Jeff Drew (Bigblock73). He had shipped Scarlett her first Christmas present. For those that dont know Jeff, he runs www.73-87.com a site thats dedicated to the history of our beloved squarebody trucks. Jeff also designed and sells a line of premium quality 73-87 cab corner speaker mounting brackets. He has sets for 67-72 and 47-55 as well.
I did a bit of mocking up last night, and I can tell you these literally fall in place. No doubt that they work exactly as intended. Scarlett says thank you Jeff, and Merry Christmas.
12-07-2016, 12:32 PM | #497 |
How did you secure the MDF to the back wall?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
12-08-2016, 10:51 AM | #498 |
Happy to be here
On my 84 build everything fit very tight and we used screws hidden in each corner. I do everything possible to avoid drilling holes that go to the outside. I don't want to encourage leaking or rust.
Jeff Drew had an ingenious idea for installing the back panel. He used Velcro stripped in each recess along the back panel. He says it's solid as can be and no holes drilled. I love that thought process.
12-08-2016, 11:00 AM | #499 |
Happy to be here
Another long day so I got a short stay in the shop. I managed a bit of time early this morning too I do have some progress on share. I marked and drilled the mounting holes for the speaker plates.
This is no easy task for the bottom two screws. I drilled and tapped the top hole, then stood on my head to mark the bottom holes. Trying to use a punch in the tight confines of the cab corner is a test of will too. My suggestion is install these with the seat out. It was raining outside or I would have pulled mine to gain access. Regardless of how you do it, these brackets fit very well. Thanks for creating such a fantastic solution to mounting speakers in the cab corners Jeff. www.73-87.com
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-08-2016 at 01:30 PM. |
12-11-2016, 12:22 PM | #500 | |
