Old 01-31-2022, 07:49 PM   #5101
Chopped53
Re: What did you do with your truck today, Part 3
Originally Posted by mick53 View Post
That seat is cool. Did you make that?
I got it from a company called TEA's Design Inc.. They do some nice stuff. I was happy with the quality of the materials and workmanship.
Here's the website: https://teasdesign.com/
Chopped53 is offline   Reply With Quote
Old 02-13-2022, 09:29 PM   #5102
fauXGT
fauXGT's Avatar
One step closer to being done with the mods to the bed. Then move back to the cab.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 02-16-2022, 02:42 PM   #5103
mick53
I needed to add the rest of the holes in my oil pan. It has a 1/2" flange and I'm sure the 3 bolts down the side and the 4 corners would be fine. I'm running a vacuum in my crankcase. I don't like empty holes for housekeeping reasons and I need all the holes for the girdle. It's a little scary cutting on my $1800 oil pan. I used transfer punches to make the holes and then flattened the welds on the mill.
mick53 is offline   Reply With Quote
Old 02-17-2022, 02:19 PM   #5104
G&R's57GMC
G&R's57GMC's Avatar
Walked by it and made sure that nothing has changed in the last 5 years by its self sitting there in it's corner of the garage
Although a couple of days ago I took a picture of the seat to door area and posted it here. (that will teach me to not be laying down on the job)
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 02-18-2022, 11:03 AM   #5105
Rickysnickers
Would you stop posting the same twisted photo?? HAHAHAHAHA!!! Only kidding
Old 02-21-2022, 10:19 AM   #5106
my56chevytruck
my56chevytruck's Avatar
with the snow still around here, I started it up the other day and listened to it purr. Can't wait for spring in NW Indiana.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 02-22-2022, 11:43 PM   #5107
mick53
I live in Warsaw where are you?
Old 02-23-2022, 03:27 AM   #5108
R&B51
mick53-I never get tired of seeing pics of that engine-amazing work!
You’ve gotta be really enjoying the process. What’ll you do with yourself when it’s all done?
fauXGT-I really like your work on that exposed filler inside the bed-did you fab that yourself? If so, how did you make the curved trim around the base?
R&B51 is offline   Reply With Quote
Old 02-23-2022, 08:47 AM   #5109
mick53
I'm almost 65 years old. I have put off my retirement to finish this truck. I bought my truck in 1980 when I got out of the Navy. I'm trying to build the ultimate drag and drive truck. If I live long enough I'm going to drive the wheels off her. I got the 20 A/N radiator hose fitting for my mechanical water pump. I also have a hortazontal drag radiator with an electric pump going between the frame rails. Water pump is finally done. One piece at a time. I'm an*l about buying American but I couldn't find the 20 A/N fitting for the radiator hose American made so it came from Australia. My electric A/C also came from down under. Thank you for your time.
Old 02-23-2022, 12:16 PM   #5110
R&B51
I’m right behind you in age and I hope I live long enough to see a video of that engine ripping down a track with fermented American dinosaur juice, raging compressed winds and a blue bolt of lightning inside each cylinder head exploding to rip rubber off those American made tires as you go! (Maybe post Old Glory in the bed and watch her fly horizontally as well).
I’m naïve to possibilities, I’m not trying to get sappy or blow wind up your a** but your engine build is beyond what I know or realized was done. Never saw AN fittings that big- good old Army Navy.
Old 02-26-2022, 10:36 AM   #5111
my56chevytruck
[quote=mick53;9041839]I live in Warsaw where are you?[/quote
Hebron, IN
1940 Ford Dlx Coupe
1969 Mach1
Old 02-26-2022, 10:39 PM   #5112
mick53
[quote=my56chevytruck;9043453]
Hebron, IN
Hebron is about 85 miles west of me and I have never heard of it before. I have lived here for about 45 years of my life. Maybe I should get out more.
Old 03-04-2022, 01:33 PM   #5113
mick53
I'm getting closer to finishing the polishing on the inside of my blower scoop. This is a bit harder than expected. It was pretty rough on the inside. This is a quality piece from The Blower Shop. I have a friend in top fuel that always teases me for polishing my parts so I told him I was porting it.
Old 03-04-2022, 10:41 PM   #5114
duramax55
mike 53 that's a lot off dirty work but nice job. will need really dark sunglasses to look at that motor in the sunlight
duramax55 is offline   Reply With Quote
Old 03-04-2022, 10:50 PM   #5115
mr48chev
mr48chev's Avatar
Mick, you are going to be able to give Andy Tant a run for his money in the polishing game .
My ongoing truck projects:
Old 03-05-2022, 09:24 AM   #5116
mick53
This is the last piece and then the blower is done. I'm really getting tired of polishing. It should warm up here soon and I can get to work on the chassis and maybe grow some fingerprints back.
Old 03-05-2022, 11:34 PM   #5117
mobileortho
mobileortho's Avatar
Mounted the fuel rail and some of the connectors. Figured out that the injector wiring harness was not included in the “kit”.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 03-11-2022, 10:06 PM   #5118
mick53
I'm getting closer on polishing the inside of my scoop. I'm about 2/3 the way done blocking it with 220 grit. For me hand blocking it flat makes all the difference, That's also the most work. I have an artificial wrist compliments of the VA so I can only do in about 1 hour spurts. The nice thing about this forum is that people are not rude and make fun of me. Not that it phases me. Thank you for your time.
Old 03-11-2022, 10:44 PM   #5119
fauXGT
fauXGT's Avatar
1.
Thank you for your service.
And 2.
A nice smooth air 'intake' is fantastic. But once it comes to combining fuel and air together, a slightly rougher surface can cause a ventury effect blending the 2 together for better fuel and air mixture... and more power.
Nice to see the shine inside and out though, being most would ignore that detail.
Chip
full Rusto-Mod
Old 03-12-2022, 06:53 PM   #5120
Oldtruckwelder
Oldtruckwelder's Avatar
Welded (14 ) 1/4 x 1-1/2 studs on polished stainless steel bed angle strip covers So the screw heads won’t show. Now the task of polishing begins.
JT from SC
Oldtruckwelder is offline   Reply With Quote
Old 03-12-2022, 08:23 PM   #5121
mick53
JT from SC
I feel your pain.
Old 03-12-2022, 10:27 PM   #5122
Johns327
Johns327's Avatar
Well I did it last night but I went to the Friday night street drags, what a blast. First time ever on a drag strip, a bunch of fun!
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
Old 03-13-2022, 06:48 PM   #5123
fauXGT
fauXGT's Avatar
Done with the tailgate fitment.
Now to move the bed outside so I can work on everything else.
Chip
full Rusto-Mod
Old 03-24-2022, 12:29 PM   #5124
Chopped53
Picked up truck from upholstery shop (the one thing I didn't have the guts to try myself). I think they did a great job. Shout out to Old Iron Kustoms near Calgary Alberta. Hurry up Spring and arrive already. I wanna drive this thing.
Old 03-24-2022, 08:17 PM   #5125
_Ogre
_Ogre's Avatar
dang, nice looking interior
shop air compressor timer
