Closed Thread
Old 09-24-2013, 12:21 PM   #501
KJSR
KJSR's Avatar
Re: The Official John Lee Jr Thread
Originally Posted by Sharps40 View Post
And if that's the cure I might just replace the entire linkage set with a heim jointed assembly for these old clutches...no more worn shafts or egged out holes. Course, the only set I've seen like this is from LMC and I don't know what the quality might be like....I'll have to continue shopping.
I used the linkage set from LMC. I was skeptical since it was from LMC but they were the only place that had it. In the end I was very happy with it and the clutch is tight. Freeplay at the pedal is actual freeplay!
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline
Old 09-24-2013, 12:32 PM   #502
Sharps40
Well then, I will have to buy it. Does it use the original winged nut at the fork?
Thanks for the feedback.
Sharps40 is offline
Old 09-24-2013, 12:49 PM   #503
aggie91
I'm just glad to be here!
aggie91's Avatar
Here is a site that I have had good service from in the past. I have gotten my rod ends form them and they are top quality. Looking over the site I found this page for the rigid rods that are drilled and tapped on each end for Male threaded rod ends. I chose 3/8" size because that rod looks about that diameter in your pictures and from what I remember from my '65.
If you know or can measure the distance betwen the centers of the ends of the current rod, you can find the cut rod that is would work on this table...
http://www.midwestcontrol.com/series.php?id=98
Here are the rod end options for that rod:
http://www.midwestcontrol.com/part_family.php?id=8
They also offer the jam nuts too. I put together this package with a 12" rod (13.58" to 15.126" center to center) and came up with a total of $34.20 for steel parts. The jam nuts are real high at over $5 each, but givent he way it would be installed a single right hand regular nut would work on just the one end and not allow the adjustment to change...:
http://www.midwestcontrol.com/cart.php
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 09-24-2013, 01:43 PM   #504
KJSR
KJSR's Avatar
It does use the original wing nut.
I thought about making my own as well but it came down to lack of time and motivation.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline
Old 09-24-2013, 02:24 PM   #505
Sharps40
Cool I'll have to look it and the other link over and decide what to do. Might could mod the linkage now and have those bugs out of it before the T5 install.
Sharps40 is offline
Old 09-24-2013, 05:01 PM   #506
Lugnutz65
Lugnutz65's Avatar
Yer blog has a straight stick added on to the S10 shifter. Looks like a decent temp solution if it'll clear a bench seat. Gives me time to look around and fab up some stuff after the trans is in and I can drive it while fabbin.
Here are just a few thread links for shifter ideas. A little of everything, just to make your head spin.
I see no reason why you couldn't remove the shifter shaft with the Hurst style bolt connection from a FORD assembly, then swap it into the S10 assembly. You'd then have the correct base plate for bolting onto the S10 tailhousing. Basically a hybrid of the first 2 links below. Forget the cutting and drilling of the FORD baseplate. Just reassemble with an S10 baseplate. Don't forget, you are NOT putting FORD parts into your Chevy - No . . no . . no! . . . . it's all Borg Warner stuff. I've included a pic of my $9 salvage yard shifter handle that I pulled from a 67-72 Chevy truck. It will replace the straight S10 shifter you saw on my T5 page.
Tech article showing how to make your own short throw shifter.
H.A.M.B. thread for modifying a FORD T5 short throw shifter.
Aftermarket Short Throw Shifter for $94
T5 shifter that's been straightened in a shop press.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 09-24-2013, 05:37 PM   #507
aggie91
aggie91's Avatar
Thanks. pretty complicated tables to weed thru though. Might be over my head!
Yeah thats pretty frustrating. Prolly a glitch but even when selecting inch rod ends it only provides metric selections.
Oh well, plenty of time to figure it out.
Tell me how long it needs to be and what size for the bolt for the rod end and I will do it for you! Can't get easier than that...
Karl
The LST Challenge:
aggie91 is offline
Old 09-24-2013, 07:41 PM   #508
Sharps40
Dayum, that's the shape, just havn't decided flat or round stock.....but don't Borg Warner parts have cooties on em after bein in a ford? Sorta like my grandkids grabbing cookies outta the jar after pickin their noses, I don't eat the cookies, boogy fingers ya see. But yep, might be the easiest.
So, the big question, Tom put in a short throw shift...what is that, the bolt on shifter lid or something inside the trans case?
If its in the length of the shifter rod that's on there now, based on the postion of the cross pin, I'd be inclined to mod that rod vice replace it with one that might have a longer throw.
PS how tall is that 72 and up shifter and whats the thickest diameter....I might could beat one into shape and weld on the top of the old shifter for the taper and the threads, or just cut some threads.
Sharps40 is offline
Old 09-24-2013, 07:43 PM   #509
Sharps40
Thanks...gonna check local boys too. We got a Fastenall in town...I think if I show em under the truck we might get a CounterGal innerested and pullin parts for me.....Love them CounterGals!
Sharps40 is offline
Old 09-24-2013, 08:22 PM   #510
Lugnutz65
Lugnutz65's Avatar
A short throw shifter has the pivot pin a bit higher on the shaft. If you follow along on that 1st link, you can see he moved the pivot pin up one inch. The added one inch aluminum spacer then keeps the lower end at the same level as before. Results are, there is less movement of your hand on the shifter knob to get the same shift travel on the business end of the shifter. Nothing inside the tranny is changed.
Yes you could. I was just presenting options I'd run across since I still have not gone down any path yet.
My shifter diameter is 5/8" round and 17" tall without the ball and 18.25 with ball. The flat part at the bottom is 1" wide by 3" tall and 5/16' thick. The shaft starts a gentle taper just about an inch below the threads for the knob.
Old 09-24-2013, 08:43 PM   #511
Sharps40
Done, 5/8 bar steel or Alum is easy to bend and flatten and drill and tap! I can use my RCBS reloading press and sometime anvil. Woo Hoo! Thanks. I'll make one I think, no sense in me messin up Mr Langdon's good work by swapin in more parts and tryin to figure it out on the fly.
Sharps40 is offline
Old 09-24-2013, 08:44 PM   #512
Sharps40
Done, 5/8 bar steel or Alum is easy to bend and flatten and drill and tap! Woo Hoo! Thanks.
Sharps40 is offline
Old 09-24-2013, 08:50 PM   #513
Sharps40
But then again, I don't have to flatten out the S10 shifter.....just trim it to length and make a concavity in the lower shaft of the new stick.....that could be forged or even ground in. Forging might be loads of fun....it involves fire and hammers and beer and as long as I got a fire goin I could heat it up for the bends and get some smooth curves. Hmmmm, I gotta go find my Redback Spider shift knob.
Sharps40 is offline
Old 09-24-2013, 09:00 PM   #514
Lugnutz65
Lugnutz65's Avatar
How about this . . . . I will trace the shape out on paper and send it to you, OK?
Old 09-24-2013, 09:12 PM   #515
Sharps40
Very cool. I'll pm ya an address. Meantime....
Here, I found the short thro part of the shifter, nice towering big doughnut of a metal thingie on toppa the trans.....
And here's Mr. Redback, sent to me from Down Unda and first installed on a T5 car I bought back in 1994, my first ever Ford Mustang.....many a shift under that spiders butt....I think I can get the Ford cooties off it for install in John Lee. Bad Ass Spider Blues now!
Over the years his, well actually her red stripe faded and is white now but takes on the yellow cast from the resta the knob from time to time and depending on angle. But still pretty cool. GoodWife hates it and refused to drive the stang, so....maybe it still has majic in there.
Well, that's two tranny swap parts acquired....tranny and shifter knob....about a bazillian parts and ideas to go. Sure glad its not a tomorrow morning project.
Sharps40 is offline
Old 09-24-2013, 09:31 PM   #516
Sharps40
Nice, got out the FFF compound for spiffing up gunstocks and polished my knob. All them old scratches are gone and it looks brand spankey new.....Ol Redback butt just a shinin and ready for shiftin.
Sharps40 is offline
Old 09-25-2013, 01:20 AM   #517
PaysonBolter
<- Stupid jealous...can't wait till I get further along w/ Patsy to play with the big boys...
PaysonBolter is offline
Old 09-25-2013, 08:46 PM   #518
Lugnutz65
Lugnutz65's Avatar
See . . . .? I used my Super Power Laser Vision and drew you a picha! Squint your eyes a little and it looks like it pops right off the page. Coming to a mailbox near you (soon).
Jay
Old 09-25-2013, 09:14 PM   #519
Sharps40
Awesomeness! Now I'm cookin. Might not grind away on my shifter, just shorten and sleeve. Top cover on the short stroke shifter is welded on and so no easy disassembly at this point, at least not unless some significant repair is indicated. So, I'm thinkin a two diameter sleeve, 3/4" id for the T5 spud, cross drilled/pinned and drop in the shank of the 5/8" shifter rod....also pinned....
Easy piezy and I can swap out as simple as bending up a new shifter or changes by makin up new adapters, like a round to flat, etc. We'll see, brains just a cookin.....
Sharps40 is offline
Old 09-26-2013, 02:42 PM   #520
Sharps40
My idea for a simple (steel tubeing/no weld/no grind the shifter stub) shifter adapter for the S10 T5.
Cut off the T5 stub where ya want it.
Bend up the shifter rod the way ya like it.
Slip the large end of the adapter on the T5 stub....cross drill and tap or just add nuts.
Slot the top half of the adapter tube....
Install the 5/8 diameter shifter lever just made...cross drill and pull the leaves of the adapter up tight with bolts.
Paint.
Add shifter knob.
Go drive....
Get tire of the shifter shape/height, bend up a new one and install in top of the adapter.
Love the shifter? Weld it to the adapter.
Sharps40 is offline
Old 09-26-2013, 06:20 PM   #521
shok
Sounds fine to me, more than one way to skin a cat.
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline
Old 09-27-2013, 07:50 AM   #522
Sharps40
Got my first windshield crack. A shotgun blast of gravel to John Lees face on the way home yesterday. Mudbogger Boy darted around me (I was 65 in a 55 zone and in the right lane), guess I wasn't fast enough, but, his RR tire decided to unload a double handfull of mud and river rock into the driverside of my windshield. I seem to recall seeing at least 5 stones hit the windshield in my line of sight, nice circular shotgun blast pattern.
I wound up with one bullseye and 1/2 inch crack in the 11 oclock position of my vision, just at the bend of the windshield from flat face to piller.
Oh well, Off to Oreillies for the Permatex Small Crack Repair kit and we'll document its use here...and in about a month we'll see how it holds up goin from warm garage to cold driveway.
I spect it'll crack again eventually and give me the impetuous to replace the windshield with an upper tinted one and slide out that frosty back glass for a Slider Window.
But, maybe it'll buy me just one more season with the original glass.
Sharps40 is offline
Old 09-27-2013, 06:04 PM   #523
shok
I hate that, its happened to me many times and it seems to suck just a little bit more when its a new car. I think I have the most gravel damaged 3 yr old car in this part of Cali.
When windshield replacement time comes will you do it yourself or have it done?
shok is offline
Old 09-27-2013, 08:28 PM   #524
Sharps40
This havin limited GoodWife (she's off takin care of Mother in Law for the week+) leaves me lots of opportunities to eat Taco Bell and work on guns and trucks and stuff. Tonight was truck night....and what a night it was.
First, fixin or at least patchin up a bullseye and crack in my ancient windshield after yesterdays MuddBoy Gravel Shotgun Blast to the face.....Coulda gone to Safeglass or whatever they are called but that's no fun....so, bought a crack fix kit at Oreillies...$12 instead of an estimated $150. Lets see how it works.
From the inside, heres the crack, bout 11 oclock just outside my straight ahead vision area...(by the way, out of coke tonight but Dr Pepper and Jack Daniels is a pretty tasty reward for a hard evenings work).
I cleaned the glass, pretty good with Zeiss lens wipes and dry paper towels. Been putting TurtleCrap Ice on the windshield and wanted to get that mostly gone for the fix....three Zeiss wipes and break out the contents of the repair kit.
Per the instructions, pick out broken glass bits with the enclosed tack and I cleaned it with another Zeiss wipe.
Stick on the vacuum thingie centered over the bullseye in the glass.
Stick the syringe holder thingie to the vacuum thingie...
Pour fixer sauce into the syringe holder thingie and put in the syringe and draw a vacuum for at least 10 minutes....
After 10 minutes, remove the syringe, let in air, compress the syringe to create pressure for 20 minutes.
Remove all the other stuff, put a drop on the yellow pad thingie and stick it to the windshield....move out into direct sunlight for 15 minutes or cloudy days 1 hour for the whole mess to cure....
After one hour on a cloudy day remove the yellow thingie....sauce has cured by UV light in and on the windshield....
Scrape off the excess sauce and though it don't show in the photo, the chip out is smooth and about 80% disappeared...much less noticeable than the bugs on the glass and with luck sealed up enough I'll get another season or two outta the glass.
Sharps40 is offline
Old 09-27-2013, 08:34 PM   #525
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice truck and awesome that you were able to fix your windsheild!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Closed Thread
