Old 06-22-2020, 04:42 PM   #501
cwcarpenter98
cwcarpenter98's Avatar
Re: Frankentruck
Originally Posted by pdxhall View Post
Nice patch work. you're really getting in to it now.
Thanks man, I'm still learning!
Originally Posted by jhrusk View Post
Looking good Christian👍👍
Thanks Jay! I'm happy so far with how it's turning out. Going to keep it patina'd for a while longer, just getting the cab back to being solid
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-22-2020, 06:27 PM   #502
flashed
Re: Frankentruck
Keep it up and I know who will be doing patches on Ma Bell .
flashed is offline   Reply With Quote
Old 06-22-2020, 09:32 PM   #503
cwcarpenter98
Re: Frankentruck
Just as long as I can do it in your shop These afternoon showers are killing my progress
Christian Carpenter
Old 06-22-2020, 10:52 PM   #504
flashed
Re: Frankentruck
You can use my shop anytime you like , I dont need to be there .
Old 06-23-2020, 07:58 AM   #505
cwcarpenter98
Re: Frankentruck
Thanks John, I appreciate it. One day I'm going to have a shop, but for now, the shade tree gets it done
Christian Carpenter
Old 06-24-2020, 05:22 PM   #506
cwcarpenter98
Re: Frankentruck
I got the engine bay side of both inner fenders painted today. Fought through the rain, but was able to get it done.
They are inside the garage drying
Christian Carpenter
Old 06-25-2020, 10:27 PM   #507
cwcarpenter98
Re: Frankentruck
Will I get the truck back together for the Georgia C10 Club meet on Saturday? I sure hope so, but it's looking promising.
On another note, so far, the new TriPlus core support from AMD has lined up real nice and I have not had to whaller out a single bolt hole yet. All the other sheet metal that will be going on is original GM stuff
Christian Carpenter
Old 06-26-2020, 10:48 PM   #508
cwcarpenter98
Re: Frankentruck
Looking like a truck again! Got everything pretty much buttoned up, just a couple bolts left for in the morning. Should be able to drive it to the Georgia C10 Club meet tomorrow!
I replaced the grille support panel that was busted and rusted with a decent, rust free one. I also got my fan shroud on, but I will need a shorter fan spacer
Christian Carpenter
Old 06-26-2020, 11:43 PM   #509
flashed
Re: Frankentruck
Looks great Christian
Old 06-27-2020, 04:48 PM   #510
cwcarpenter98
Re: Frankentruck
Thanks John. It drives much better too! Less rattles
Christian Carpenter
Old 07-03-2020, 10:13 PM   #511
cwcarpenter98
Re: Frankentruck
Today was a good day.
Met up with MikeN to get a fan and fan clutch from his 65 Impala. It ended up fitting almost perfectly with my new shroud. The old fan was too far into the shroud once I moved the radiator to the correct, v8 location and installed the shroud. Thanks again Mike!
After getting the fan, I went and picked up a 60 hood. It's got the usual rust, but I think I can fix it eventually lol. It's one of those things that I just couldn't pass up.
Yesterday, I got a switch so that I could completely turn off power to the overdrive system whenever I want to drive it in lockout. I used on of the holes already in the bottom of the dash, so I didn't have to drill any extra holes. I plan to pull a few trailers, so I probably won't be using the overdrive when I do that.
Happy 4th!
Christian Carpenter
Old 07-04-2020, 01:06 AM   #512
flashed
Re: Frankentruck
FrankenTruck is still one of my all time favorites simply because you are building and repairing it as you go yourself . Christian , that truck is like you , Awesome .
Old 07-04-2020, 07:22 PM   #513
cwcarpenter98
Re: Frankentruck
Thank you for the kind words John. I've still got a long ways to go, but I'll get there eventually. Your 70 stepper is going to be much nicer than my truck though!
Christian Carpenter
Old 07-04-2020, 07:25 PM   #514
cwcarpenter98
Re: Frankentruck
Happy 4th y'all!
I like to celebrate by driving Frankentruck around and eating some good food with friends. Also, it's been 5 years now since I've had Frankentruck. Hopefully many more to come
Christian Carpenter
Old 07-04-2020, 09:24 PM   #515
flashed
Re: Frankentruck
My 70 will be a different style build than FrankenTruck but not necessarily nicer than FrankenTruck . You are making huge strides with your truck yet still get to drive it . I have never driven mine at all.
Old 07-04-2020, 09:43 PM   #516
cwcarpenter98
Re: Frankentruck
You will be able to soon though! You'll probably be getting better gas mileage though
Christian Carpenter
Old 07-04-2020, 11:13 PM   #517
flashed
Re: Frankentruck
I expect it to be a year or more before I get to drive mine now , Im way behind schedule .
Old 07-05-2020, 04:53 PM   #518
cwcarpenter98
Re: Frankentruck
Mmmm, that cross pin lock bolt shouldn't be like that...
I don't think that gap should've been there on the pinion seal either.
New axle bearings and seals and a new pinion seal went in today. Just gotta find a new bolt now.
My good friend Levi helped out a ton today and I got to use his fancy mechanic tools lol
Christian Carpenter
Old 07-07-2020, 12:07 AM   #519
cwcarpenter98
Re: Frankentruck
I called up some local dealerships this morning, but had to drive an hour to find the correct part. Bought three of them since it is a discontinued part now. It was still cheaper than buying the one from Summit Racing, and I got extras. Put everything back together and went for a test drive. I think I fixed all the leaks, but it was dark when I got back, and I was sad. Everything was going great until I heard a metallic smack. I pulled over and started looking underneath the rear of the truck. There's now a visible gap between the axle pads and trailing arms on both sides. Apparently my axle is trying to leave the truck... Fix one thing and another breaks
My test drive consisted of stopping by Flashed's place and messing with the Quadrajet on his 79 square. I'm thinking the carb needs a rebuild, but I'm not sure. Time to do some more research lol
Christian Carpenter
Old 07-07-2020, 12:11 AM   #520
kehstr
kehstr's Avatar
Re: Frankentruck
At least that should be a simple fix of just tightening the ubolts
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 07-07-2020, 12:13 AM   #521
cwcarpenter98
Re: Frankentruck
I think I'm just going to end up replacing them. I didn't take the axle out to replace all the seals, so apparently the u bolts have been loosening up somehow since I took ownership of the truck
Christian Carpenter
Old 07-07-2020, 09:40 AM   #522
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Frankentruck
After getting the fan, I went and picked up a 60 hood. It's got the usual rust, but I think I can fix it eventually lol. It's one of those things that I just couldn't pass up...
Happy 4th!
As usual, great work.
Do you remember what fan you used?
Old 07-07-2020, 10:10 PM   #523
cwcarpenter98
Re: Frankentruck
Thanks man! I believe it's a factory 5 blade fan from the 65 Impala, but I'm not sure exactly. MikeN pulled it off his 65 Impala when he put a 7 blade fan and heavier duty clutch on it. It does seem to cool better than the old fan that was too deep into the shroud
Christian Carpenter
Old 07-07-2020, 10:16 PM   #524
cwcarpenter98
Re: Frankentruck
One of the driver's side brake shoes had a crack in it, so I was able to get that warrantied and replaced both sides today.
After that was done, I took the rattle gun and buzzed off the u bolt nuts. Looks like the u bolts came loose many years ago, were tightened back up, and they worked loose again. I'll be getting new u bolts in the morning
Christian Carpenter
Old 07-08-2020, 10:20 PM   #525
cwcarpenter98
Re: Frankentruck
Got some new u bolts today. I don't have a torque wrench that goes up to 230 ft lbs, but my friend brought his that goes up to 250 ft lbs. I went to get it this evening and will be installing the new bolts in the morning.
After getting the u bolts, the AC compressor clutch went out on my Dakota. Not sure what I'm going to do there.
I spent the rest of the morning and afternoon cleaning up and painting some of the under hood parts that I had not painted when I took the front end apart. Had to use the shade tree paint booth to get it done
Christian Carpenter
